Closed Thread
Old 10-17-2009, 11:57 PM   #1291
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Originally Posted by dontfeelcold View Post
The speedy is set to the standard profile (LRP TC spec). I have tried different motors and speedies, I also tried different servo's aswell.
Is your servo horn straight up or did you leave a angle like the book said ?
King of B Main is offline
Old 10-18-2009, 03:14 AM   #1292
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
I run it 90deg. to the linkage like the manual says. I have tried it straight aswell.
dontfeelcold is offline
Old 10-18-2009, 09:00 AM   #1293
cyanyde's Avatar
Originally Posted by BigDogRacing View Post
Cyanyde, if you moved the hingepins closer to the chassis you lowered the front roll center.
Oops my bad. Was trying to say raise front center of gravity.
cyanyde is offline
Old 10-18-2009, 09:12 AM   #1294
cyanyde's Avatar
When you said you tried everything and doesn't make a difference, did it get worse on some setups? If your answer is no, then we are all as puzzled as you are. There is no way on earth you can change setups without affecting handling in a positive or negative manner...
The issue isn't the car then.
cyanyde is offline
Old 10-18-2009, 12:33 PM   #1295
dontfeelcold, Is your rear diff, belt and everything working. Is the rear putting power down to the track. How are you running drivetrain, ie. front spool oneway rear diff, middle oneway, etc. Really sounds like only the front end is pulling. Hope that helps.
Tim
TS racing
got2bqik is offline
Old 10-18-2009, 08:20 PM   #1296
Gravity RC
I think its time to start over again. check to make sure that your servo saver isnt giving out or something weird though im sure that you already have.
I would once again suggest my reedy race set up with these changes to it. make sure that you only have 2 or 2.5 deg of rear toe with that set up, and make sure the rear shocks are layed in all the way (i never change that), also instead of 500 rear oil use 400 (XRAY OIL) 40wt other brand oil is not that close. put some fresh tires on the car. 3degs of front camber and 1deg of rear camber.
Make sure to copy it all, if it still dosent steer I dont know. my car would spin out.
with what you were saying before, a stiffer rear spring and really soft front spring will usually make the car push. 2.6R and 3.0F is just the best ballance for rubber tires.
Also if your doing something like putting weight in the front of the car, Take it off. that will make it push worse.
best of luck!
maybe you will just have to send it to me
Paul L is offline
Old 10-18-2009, 10:01 PM   #1297
imprsme's Avatar
Trader Rating: 74 (99%+)
Does that offer stand for anyone??? LOL
AwesomatixUSA
eXpress Motorsports
imprsme is offline
Old 10-18-2009, 10:14 PM   #1298
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
After I personally deliver my own car, are you going to add in some driver lessons?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline
Old 10-19-2009, 01:42 AM   #1299
best of luck!
I will give your suggestions a try.
How tight do you suggest to run the diff? I usually run my diff as loose as possible (without it slipping).
Old 10-19-2009, 07:29 AM   #1300
Gravity RC
Maybe, im sure i owe you a favor by now.
you buy a ticket to milwaukee to come race at trackside and ill spend a day with you.
yup, thats how i do mine also.
thanks.
Paul L is offline
Old 10-19-2009, 07:33 AM   #1301
ToysRUsKid's Avatar
thanks.
Oh how tempting that is...I might have to take you up on that offer.
Old 10-19-2009, 07:09 PM   #1302
TimV's Avatar
Trader Rating: 49 (100%+)
Paul, what shock rebound % do you run on your foam tire car? Looking for a good starting point for this year. Didn't fool with it last year.
- - - Express Motorsports - - - MW Designs - - - Mimi Wong Clan - - - Final Thoughts Racing - - -
- - - Team AKA - - - RDsquared - - -
It's the year 2010. Shouldn't vacuum cleaners be quieter by now?
TimV is offline
Old 10-19-2009, 07:53 PM   #1303
Trader Rating: 19 (100%+)
What's this Paul Lemieux Rc Driving school?!?! So where do I sign up!
zake540 is offline
Old 10-19-2009, 08:58 PM   #1304
mtbboy's Avatar
Here you go Paulie....
$400.00 a day..
I bet you would have a huge waiting list for that.seriously.
Chase needs a new pair o shoes.
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline
Old 10-22-2009, 08:06 PM   #1305
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Paul...
Have you ran the Nemesis 17.5 motors by any chance? How do they compare to the Duo2 motors? I was getting ready to put in an order for 3 Duo 17.5's but this press release for the Nemesis motors just came out and got me excited. Would you say my money is better spent on the Nemesis 17.5's?
Syber Serulean is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
