Closed Thread
Old 10-13-2009, 07:23 PM   #1276
Hi Paul, Can you give me a ball park rollout for 1/12 with the Duo 2 10.5 on 1S, with Speed Passion esc. Also where would you set can timing and esc timing??
Thanks,
Tim
TS racing
got2bqik is offline
Old 10-13-2009, 08:58 PM   #1277
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
thanks paul always a great help!
TRXRACER99 is offline
Old 10-13-2009, 09:16 PM   #1278
Send a message via AIM to A-Ko
Originally Posted by Paul L View Post
Hi Jeff, hope all is well with you and the Baby!
Thanks. She crawls pretty fast for a kid, could racing be in her blood...?
Hope all is well with your family, we will have to hook-up sometime.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline
Old 10-14-2009, 01:17 PM   #1279
Gravity RC
Thanks,
Tim
Hi Tim. ive gotta be honest here, I have no clue. maybe EA or someone can help us here. sorry.
No problem, but as you can see above im not always a great help LOL.
great!. all is well with me right now. definately, Thanks.
Paul L is offline
Old 10-14-2009, 01:23 PM   #1280
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Thanks,
Tim
A good starting point would be 74T spur, 38T pinion. That for sure won't heat up the motor, then you can work from there. Hope that helps.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline
Old 10-14-2009, 03:14 PM   #1281
Thanks, Dorian thats what I was looking for. Also thanks Paul, you coulda been one of them guys and told me anything just to sound important.
Tim
TS racing
got2bqik is offline
Old 10-14-2009, 07:08 PM   #1282
ToysRUsKid's Avatar
Tim
No problem. I would like to take credit, but Arun from nexusracing.com helped to make sure I didn't burn up my motor when I got my 12th scale. Now that's customer service
Old 10-17-2009, 08:39 AM   #1283
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
I have definately been their. i dont think that i have ever had a car have too much steering for me on high grip asphalt.
I would moove some weight back in the car, lean the rear shocks all the way in, reduce your rear camber to .5deg and put your front camber at 2.5 for starters. these 4 changes should really help. i think the trick to asphalt is to get the car to carry corner speed, I have had good asphalt cars that push but are still fast.
try that stuff.
Hi Paul,
I tried those settings you suggested but they made no difference. It appears I have a unique problem. No matter what setup change I make, the car understeers and holds very little corner speed.
For instance I had the 2.8 springs on the front and the 2.6 on the back. I swapped them around so the 2.8s were on the back and the 2.6s on the front and it still understeered, the rear end wouldnt even step out.
I tried someone elses xray shocks with 400wt oil in them and it made no difference (in case my shocks were playing up)
I had other people check my droop, ride height, steering geometry etc to see if I was doing something wrong there but it all checked out.
Any idea of what I could be doing wrong to cause this problem? I had a HB Cyclone previously that did the same thing, the xray does the same thing for me so I assume its something I am doing wrong.
Thanks for your help
dontfeelcold is offline
Old 10-17-2009, 12:09 PM   #1284
cyanyde's Avatar
Originally Posted by dontfeelcold View Post
Hi Paul,
Just wondering if you have ever come across a situation where setup changes dont have much of an effect on the cars handling and it just tends to understeer?
Lately my car has been like that, Everything is working properly, no bent or damaged parts, drivetrain is all smooth and free (diffs and driveshafts included), new tyres running on asphalt. Running a T2 008 with the starting rubber setup on it. I tried many changes to the car but none had a decent impact on the cars handling which is making it hard to get around the track quickly.
Josh
Solved my undertseer problem by;
1. Raising the front roll center (arms closer to the chassis)
2. Softer front anti roll bar
3. Lowering rear droop (somehow this allowed the front to roll more)
4. Extend ackermaan setting at servo saver
Try them. May or may not work for you...
cyanyde is offline
Old 10-17-2009, 06:57 PM   #1285
I tried things like that, made no difference what so ever.
Old 10-17-2009, 08:25 PM   #1286
beavis353's Avatar
Im no Paul (Im much better looking) but sounds like you might have a radio or servo setup EPA adjustment out of wack.
On the other hand, I once heard someone say that if everything you change doesnt make a difference, its a tire issue. Mount up a new set and see if that changes anything.
Beavis
beavis353 is offline
Old 10-17-2009, 08:35 PM   #1287
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Cyanyde, if you moved the hingepins closer to the chassis you lowered the front roll center.
BigDogRacing is offline
Old 10-17-2009, 09:01 PM   #1288
I set my EPA's so that steering blocks just touch the chubs. I have also tried running less lock, no difference.
I tried new tyres aswell, no difference again. Even foam tyres dont help it.
Thanks for the input guys, I will take all the help I can get
Old 10-17-2009, 10:00 PM   #1289
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Are you accidentaly using a whole bunch of "push control"? That would keep the car from ever taking a good set going into a corner that requires lifting the throttle.
Why don't we endurance race more often?
Greg Sharpe is offline
Old 10-17-2009, 11:45 PM   #1290
The speedy is set to the standard profile (LRP TC spec). I have tried different motors and speedies, I also tried different servo's aswell.
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
