Closed Thread
Old 09-28-2009, 07:36 AM   #1246
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Hi Paul,
Just wondering if you have ever come across a situation where setup changes dont have much of an effect on the cars handling and it just tends to understeer?
Lately my car has been like that, Everything is working properly, no bent or damaged parts, drivetrain is all smooth and free (diffs and driveshafts included), new tyres running on asphalt. Running a T2 008 with the starting rubber setup on it. I tried many changes to the car but none had a decent impact on the cars handling which is making it hard to get around the track quickly.
Josh
dontfeelcold is offline
Old 09-28-2009, 08:27 AM   #1247
Gravity RC
Originally Posted by dontfeelcold View Post
Hi Paul,
Josh
I have definately been their. i dont think that i have ever had a car have too much steering for me on high grip asphalt.
I would moove some weight back in the car, lean the rear shocks all the way in, reduce your rear camber to .5deg and put your front camber at 2.5 for starters. these 4 changes should really help. i think the trick to asphalt is to get the car to carry corner speed, I have had good asphalt cars that push but are still fast.
try that stuff.
Paul L is offline
Old 09-28-2009, 05:06 PM   #1248
Thanks for that, I will give it a try
Old 09-28-2009, 07:01 PM   #1249
Johnny Wishbone's Avatar
Paul, a question for you.
On your setups lately you seem to be using the number 1 spot on the rear shock tower, with that, if you felt that the setup wanted the shock to be angled just slightly more (more incline), is there another adjustment within the shock, (spring,piston, oil or other(maybe a bar)) that would duplicate that "feel" but allow you to stand the shock up to position 4 and the ability to work down again?
Johnny Wishbone is offline
Old 09-29-2009, 07:31 PM   #1250
ab1105's Avatar
Trader Rating: 20 (100%+)
Paul Lemieux fans will like this interview we conducted by him at the Reedy Race for R/C Evil Empire. Paul took the time to give us some background on his r/c career and the future direction of touring car racing in the U.S. Thanks to Paul for taking the time!
http://rcevilempire.com/2009/09/excl...-paul-lemieux/
ab1105 is offline
Old 10-06-2009, 02:50 PM   #1251
Gravity RC
no problem!
I know exactly what you are getting at but Honestly, no.
good question!
Paul L is offline
Old 10-07-2009, 01:14 PM   #1252
MarkBrown's Avatar
Paul, there's no place on the T2'008/009 setup sheet for specifying the size of holes in the shock pistons. So for instance the setup you published for the 2009 reedy race does not say which piston you used in the alu shocks, just that it was 3 holes.
Perhaps you always use the pistons with the 1.1mm holes? What's the conversion between alu shocks with 1.1mm holes and plastic shocks with the same number of holes in the non-clicker pistons? Does the alu shock need thicker oil than the plastic shock to feel the same?
Another question I have on this setup is about droop. You say "2.5mms of droop after ride height". Do you measure the downtravel at the point where the droop screws hit the chassis, or the point where the tires leave the setup board? The difference can be 1mm or more, which seems like a significant part of 2.5mm. Even a 0.5mm change in droop can be significant, yes?
MarkBrown is offline
Old 10-09-2009, 07:45 AM   #1253
Gravity RC
Hi Mark, all of my set-ups right now are for standard shock pistons, even in the aluminum shock.
The aluminum and plastics do set up a bit different but i forgot what was what, i will check at the track today and let you know.
Good question, but i dont have a good answer . i suppose that when i do it is closer to when the droop screws hit the chassis. droop is so critical that their really is no good way to measure it, because ones inturpitation of 5mms ride height is a bit different than a nother and especially the same when using the droop blocks.
on the rear (only) of our car a nother way to refrence 3mms of droop is to set the springs to where they cant moove up and down but they are also not preloaded (just touching both collars). this will be very close to 3mms of droop in the rear, then adjust side to side to where its equal (should be close). then you can match the feel to the front, The front springs will end up being a bit preloaded to get the same amount.
Paul L is offline
Old 10-09-2009, 07:52 AM   #1254
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Paul...that's assuming you built the shocks to what length? Meaning when you have the the shock fully built and the rod is extended out of the shock body, what should the total length of the whole shock be?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline
Old 10-09-2009, 08:23 AM   #1255
padailey's Avatar
Paul
I hope my explaination makes sense.. I'm not the best at explaining how my car reacts unless its really obvious... so here goes.
My '009 EU is setup up straight from the stock setup. It is fast and really turns well. I'm running 17.5 indoor carpet with rubber (jaco greens) on a low to medium traction surface. My only deviation from the setup is I back off the goop on the front tires from full to half on the inside. I've never had a car with a spool turn this well but it might be a tick loose on entry. Also as I exit the corners and back on the throttle it tends to want to keep turning. None of this is very bad but it keeps me from running consistently lap after lap. So I guess maybe I just need to "tame" it down a little. Any suggestions?
Also how much would the rear diff play into this? The setup says loose to medium for tightness... how do you know what loose to medium is?
Thanks... posted this on the '009 thread also.
www.hobbyplexraceway.com
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline
Old 10-09-2009, 10:16 PM   #1256
JamesReilly's Avatar
Trader Rating: 58 (100%+)
Originally Posted by padailey View Post
Paul
I know I'm not Paul but I have done a lot of testing with exactly what you are asking. I solved the problem by putting a diff in the front, BUT I used losi brown grease in the front diff and run it very tight. Not locked but close, this got rid of the loose entry and tamed the corner out steering.
You'll also get more steering mid corner. I know everyone swears that a spool is the only way to go on rubber but give it a try you maybe surprised.
James
Reilly Paint ([email protected])
JamesReilly is offline
Old 10-10-2009, 06:04 AM   #1257
FOXY923's Avatar
Paul, do you have your T3? Can we see pics?
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline
Old 10-10-2009, 12:11 PM   #1258
RC America's Avatar
Answer to Question 1 - Maybe
Answer to Question 2 - NO!
Bryan
RC America
RC America is offline
Old 10-10-2009, 10:15 PM   #1259
Send a message via AIM to A-Ko
Hi Paul!
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline
Old 10-11-2009, 10:28 AM   #1260
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Bryan
RC America
Dang....Paul's being watched!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
