Closed Thread
Old 07-27-2009, 09:25 AM   #1171
Gravity RC
Originally Posted by da_John_wee View Post
HEllo guys
what is a "CS yellow high grip "
CS is a company in europe, they have a traction compound that works pretty well on carpet, its yellow in color and i think that is what it is called, "yellow/high grip". I only know it because whenever i race over their im always ninja style dipping in Mark or Jilles's sauce lol and sometimes that is what it is.
Paul L is offline
Old 07-27-2009, 11:44 AM   #1172
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Any chance this is the same stuff as "Accute Asphalt" from Much More? (its bright yellow) I have tried that and like it real well, but its way to pricey.
mrrcguy is offline
Old 07-27-2009, 12:23 PM   #1173
#88driver's Avatar
Paul, I've noticed on some of your setup sheets you use buggy grip as your traction compound. After doing some testing with the buggy grip, paragon, and acute asphalt, I could not get my car to feel right with just the buggy grip. How are you using it? Do you just clean your tires with it then apply tweak after letting buggy grip soak? (i tried doing that instead with acute asphalt instead of tweak and i really like my car with it)
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline
Old 07-27-2009, 03:35 PM   #1174
Default Ed the dutchman
HEllo guys
CS high grip is a sauce from CS electronic in germany it is a good tyre sauce for short hairy carpet,they have also ultra grip, this is for woven carpet(hard)
See for yourself on webside http://cs-shop.de/
I am running their brusless motors, they are the same as speed passion
Ed IJzerman
eded1 is offline
Old 07-27-2009, 04:52 PM   #1175
tenpins77's Avatar
Send a message via AIM to tenpins77
Paul,
do you have any good setups for a mid-low bite asphalt track? Our primary class is 13.5.
(most guys are using "team epic" buggy grip and then baking them with "tire tweak")
"Im on a Drinking Team, With a bowling problem"
"13th Grade Design", Web Design, Company Marketing, E'commerce Development
www.crgraphicsonline.com
tenpins77 is offline
Old 07-27-2009, 05:47 PM   #1176
#88driver's Avatar
Originally Posted by tenpins77 View Post
Paul,
Paul I hate to bust in on your thread like this but I have a setup thats good for the type of conditons your running in. Here is the link to it:http://forum.teamxray.com/xform/inde...6&setup=t2_008
We are running a flowing layout until you reach one technical section thats meant for a carpet track but whatever. I took the front way bar off to give it a little bit more aggresiveness through this tight section, but it felt like it still was understeering a tad bit. So if it feels the same way next time I may move the front quick roll center from upper inner to lower inner and try that
Colton Jaynes
rchobbiesstore.com
Old 07-27-2009, 06:59 PM   #1177
tenpins77's Avatar
thanks,
but you didnt put down what shock oil you were using? I will def give this setup a shot.
Has anyone / paul had any luck with the mid motor conversion and the "asphalt top deck?
Old 07-27-2009, 07:02 PM   #1178
Company Representative
SweepRacingUSA's Avatar
Thank you, looking forward to race with you at Jackson, NJ next month
John Lee
SweepRacingUSA is offline
Old 07-27-2009, 07:17 PM   #1179
#88driver's Avatar
thanks,
Sorry 30 wt
Colton Jaynes
rchobbiesstore.com
Old 07-27-2009, 07:18 PM   #1180
dpatterson26's Avatar
Thanks, I had a great time in portland. Made Tons of new friends!
Go Team Pop a Top!!!!
eXpress Motorsports•Sweep•Lunsford Racing•ORCA•RC Plus
dpatterson26 is offline
Old 07-28-2009, 09:34 AM   #1181
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Paul,
What are your recommendations for the ECS driveshafts? Do you recommend the 52mm or the 50mm?
Also, can we use any other brand springs with the T2 Pro or the T2 009?
Chirag Patel (San Diego, CA)
1/10 2WD Buggy: TLR 22 4.0 SR 17.5
1/10 4WD Buggy: TBD
cpatel529 is offline
Old 07-28-2009, 05:03 PM   #1182
MarkBrown's Avatar
... you can use either, I like the white pistons better, they have better edges and they should be more precise with no mold flashing's. the standard piston holes are 1mm and the white pistons are 1.1mms. but i would use the white ones. Thanks
What's the part number of the white pistons that fit the plastic T2 shocks? The only optional pistons I can find are the 308036, but the description of these says
"The new pistons have a larger external diameter and are flatter than the standard kit pistons and because of that, these pistons fits only to 308306 alu shocks specially developed for T2’008 cars."
Thanks!
MarkBrown is offline
Old 07-29-2009, 12:09 AM   #1183
Gravity RC
Thanks!
Im pretty sure that those are the ones, after thinking about it the white ones that i had were most likely prototype.
Hi everyone, Im off to a race in just a couple of hours. (great lakes classic). It seems like a horrible excuse because i am posting now but it really takes me forever to type responces because i stink at typing, (seriously) and i dont have time to get back to all of the responces right now. i will get to them all when i get home or if i find a PC and some time at the race. Sorry
Thanks, Paul
Paul L is offline
Old 08-02-2009, 09:08 PM   #1184
bigdadracing's Avatar
hey Paul just seeing if you recovered finally from the xray challenge here at Portland it was great to have you here for that race. it meant alot to the guys around the NW region . your thought on setup on my 008 was great the setup work last weekend and allowed me to win with the car .maybe at the xray challenge i was a little sleep deprived .already working on next years race can't wait to see you again .maybe we can get some of the girls from the pop a top for trophy girls next year??? good luck at the race and give Ralph a hard time for me!!!!
rcamerica/xray/ team powers/bsr tires/ slapmaster tools/ bigdads garage/cheep beer/ mykeart paint works / team pop a top
suport your local hobby shop because ebays track is hard to find !!!!!!!!
Russ Jacobson
bigdadracing is offline
Old 08-03-2009, 08:02 AM   #1185
Gravity RC
Im not sure about that, I have never used the accurate asphalt before.
I think that it really depends on the track. lately i have been cleaning with buggy grip then putting a small amount of tweak on the tire and letting it dry before i run.
Paul,
I dont have a set up that i made specially for 13.5 but my reedy race set up from this year should be pretty good with some minor tweaks. sorry.
Thanks Colton
thanks,
I have not had a chance to test the forward motor a lot yet but i think that for low traction situations it would be really good.
John Lee
Hi John, it will be fun. see you soon.
Originally Posted by cpatel529 View Post
Paul,
Hi, Normally i recommend the 52mm drive shafts for the front, you can use other brand springs. ours fit best for our shocks and spring cups but you can use Hpi springs and they will just be a little loose on the shocks, but im not sure about other brands.
Thanks, was a great time. Ill see you next year, hopefully sooner.
Paul L is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
