Closed Thread
Old 06-19-2009, 07:29 PM   #1156
adamge's Avatar
Dorian, putting extra weight on an end of the car kills cornering traction at that end. It's caused the same phenomenon that all car handling theory is based on: adding more load to a tire doesn't add quite as much more traction. Using your example of the 40f/60r, the rear end has to provide 60% of the cornering force, but the rear tires only provide maybe 57% of the car's total traction. So, the rear tires will slide more, and eventually break loose first in a corner.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline
Old 06-19-2009, 08:56 PM   #1157
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Didn't know that...thanks for clearing that up. I guess that corning force out weights the traction and you get a spin out.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline
Old 06-22-2009, 09:06 AM   #1158
Gravity RC
Originally Posted by ToysRUsKid View Post
Paul, you completely me with that one. I always thought more weight in the rear would cause a push (less steering) because the rear is heavier producing more traction???
Also, about that NT1 setup from the Capital Classic, I noticed your camber rise was different from what Drew did. I tried to figure out exactly what camber rise does, but the setup book isn't helping. Can you explain? I'm slowly picking apart your setup, trying to understand why you did what you did.
Their are exceptions to the weight placement rule, but for the most part it is true.
(NT1) Ralph and I's set up was different, I had to use more camber rise shimms because i also used a lower inner rear pin (roll center) than ralph did, so to get the same amount of camber rise i had to run somewhere around 1mm more shimming under my rear camber link. normally more camber rise in the rear gives me more steering entering the corner but seems to give up forward bite on exit. in the end both of our cars were fast so i think that their are many set ups that will work as long as you are used to driving that type of set up.
thats a really good way to explain that.
This and what you said are not really related but i think that they are both true. If you have a 60% front heavy car, only 40% of the weight can transfer to the front tires. if you have a 40%front heavy car 60% of the weight could transfer foreward, that has the possibility of 1/3rd more weight transfer than the front heavy car. more transfer forward, more steering.
If both yours and mine were not true it would not work the same for foam and rubber, which it does so their are definate truth's to both.
Paul L is offline
Old 07-13-2009, 02:22 PM   #1159
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Paul, first I want to say thanks for coming out to Beat the Heat...watching you guys run was a treat. Also thanks again for the help with my car (the FK04 "99% sure" guy pitting next to Bates). My question is what are some basic setup changes you make for a rough/bumpy track? I had a hard time finding a balance between firm enough to keep the car from bottoming out and bouncing around, and soft enough to soak up the bumps. Thanks again!
-rocky b
flatspunout is offline
Old 07-13-2009, 02:31 PM   #1160
abailey21's Avatar
Trader Rating: 36 (100%+)
Paul, rumors are flying that you'll be in Tampa this weekend, can you confirm or deny these rumors?
K.C.C.O.
abailey21 is offline
Old 07-13-2009, 06:19 PM   #1161
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Im pretty sure Paul has another Xray Challenge race in Portland Or this coming weekend.
Good seeing ya this weekend Paul. Did the pit towel make it on the plane with ya?
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline
Old 07-22-2009, 02:47 AM   #1162
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
Porland OR it was! And what a Show he gave.......
Around The Table With Paul Lemieux(RC-America/Thunderpower)-xray-challenge-portland-2009-188.jpg
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline
Old 07-23-2009, 06:18 PM   #1163
Gravity RC
-rocky b
Hi Rocky, no problem I had a good time their. I always struggle the same way that you are talking about with bumpy tracks. technicially i think that with a really bumpy track you are supposed to go to bigger hole pistons with thicker oil, even though the small hole/thinner oil may feel the same as the bigger hole thicker oil combo, it should soak up the bumps better. In the end I have never really been a shock guy atall so i dont know. an experienced off road racer could elaborate on shock pack for us im sure. I just make my car handle as well as possible then drive the bumps.
sorry, wish i could have made it.
Attachment 479260
Thanks, I had a great time in portland. Made Tons of new friends!
EA: "Revenge is a dish, Best served COLD" !!
Paul L is offline
Old 07-23-2009, 11:00 PM   #1164
rosko's Avatar
paul can you tell me how you dope (what compound, how long)/clean (with what) your jaco rubber tires on carpet. thx
rosko is offline
Old 07-24-2009, 06:28 AM   #1165
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Rosko, I'm fairly sure he uses buggy grip to clean and a very thin coat of tweak and lets it soak in as long as possible. After that, if the bite is good buggy grip only just to clean them between runs.
That may have changed, but until he confirms it, that's a good practice.
BigDogRacing is offline
Old 07-24-2009, 07:45 AM   #1166
Trader Rating: 1 (67%+)
cst 300 if he is in the mood to crush a mans spirit
Josh Hohnstein is offline
Old 07-24-2009, 03:50 PM   #1167
Gravity RC
For jacos on high bite carpet i clean with motor spray and sauce with jack the gripper for as long as possible. normally jack is the spec sauce, so we have to use it, but if you have the choice also try CS yellow high grip if you can find some.
Hi. Yes, that is how i sauce for asphalt. from what i have found that dosent work too well on carpet. Thanks
That too, LOL.
Paul L is offline
Old 07-24-2009, 04:18 PM   #1168
Johnny Wishbone's Avatar
Thats on the tires right???
Johnny Wishbone is offline
Old 07-24-2009, 04:24 PM   #1169
Company Representative
SweepRacingUSA's Avatar
HEllo guys
what is a "CS yellow high grip "
SweepRacingUSA is offline
Old 07-26-2009, 11:35 PM   #1170
Opps, sorry Rosko- didn't realize tweak doesn't work on carpet.... duh.
Just trying to help.
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
