Closed Thread
Old 04-27-2009, 02:55 PM   #1096
Gravity RC
Originally Posted by cabinetgod View Post
hey paul how's the fishing been since clevland
. LOL, I have enjoyed several delicious bass.
Originally Posted by Kropy View Post
Paul ~ What up homie
Hi Kropy, doing good. U?
Originally Posted by mickrcarver View Post
Paul,do you have a sister .
sorry I do not, but if I did my answer would remain the same, LOL.
Originally Posted by rosko View Post
i have a 009 us with a 104 spur and trinity brushless motor is it possible to get the rollout that one would run with a 17.5, or do i need a smaller spur. i saw ea running a 100 tooth spur on his 09 nats setup sheet. foam tire
Hi Rosko, I have never tried it with a 104, I think it would be really close but I would use a 98 to be safe. Maybe someone could help us that has tried bigger than 100 ? Sorry.
Paul L is offline
Old 04-27-2009, 09:53 PM   #1097
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I think the biggest you can go is 102 on the spur. I ran 17.5 in an 008 rubber and used a 102 spur with pinions ranging from 39-4?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline
Old 04-28-2009, 08:01 AM   #1098
cabinetgod's Avatar
[QUOTE=Paul L;5738864]. LOL, I have enjoyed several delicious bass.
i bet you have landed your share of amf's as well
cabinetgod is offline
Old 04-28-2009, 02:01 PM   #1099
Team Ewing's Avatar
Default Appreciation Day
Hey guy,
I met you in Jonesboro ARK at the X-Ray challenge. I just wanted to
say thanks for all the tips and what you do to help the sport along.
Best of racing to ya, Ron
Losi 22 Xceleron Tekin Pro 13.5
Team Ewing is offline
Old 04-30-2009, 07:16 AM   #1100
Gravity RC
sounds good, Thanks for the help.
[QUOTE=cabinetgod;5742416]
nobody knows what that is around here, but i will look it up if i ever go to a bar again.
Originally Posted by Team Ewing View Post
Hey guy,
Hi Ron, Thanks for the good feedback. it was a great race, I had a lot of fun.
hopefully ill see ya at a nother event or possibly that one again. let me know if you need any help. Thanks, paul
Paul L is offline
Old 04-30-2009, 10:55 AM   #1101
Hey Paul,
So you liked that AMF I handed you? I think Drew liked it as well... They are very tasty indeed!
Print this out and keep it with you at all times,
1/2 oz vodka
1/2 oz rum
1/2 oz 1800® Tequila
1/2 oz gin
1/2 oz Blue Curacao liqueur
2 oz sweet and sour mix
2 oz 7-Up® soda
Pour all ingredients except the 7-Up into a chilled glass filled with ice cubes. Top with 7-Up and stir gently.
Kody is offline
Old 04-30-2009, 12:41 PM   #1102
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Paul,
For the original T2 on rubber tires, do you recommend the new shorter black springs or something like a yellow/white spring setup?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline
Old 05-01-2009, 12:01 AM   #1103
rosko's Avatar
paul on your foam touring set ups i notice your rear shock angle is usually all the way in on the tower. please explain the reason that you run the rear all way in vs. stood up one hole.
also the rear camber link shims on the rear hub going from say 4.5mm to 5mm would be for more grip right.
rosko is offline
Old 05-01-2009, 07:12 AM   #1104
Gravity RC
Originally Posted by Kody View Post
Hey Paul,
1/2 oz vodka
1/2 oz rum
1/2 oz gin
2 oz 7-Up® soda
Thanks!
Originally Posted by Dane View Post
Paul,
the white and yellow springs have always been good springs to use. i would try running both but i would be suprised if the new springs are much better if any.
Hi, some of my set ups have the rear shocks being up one hole, lately i have been running them all the way layed in. i just felt like i wanted the rear to be a little softer and roll a bit more. it seems like as the cars got faster i started laying in the rear shocks more. for me the car seems to push more with 5mms under the rear link than with 4 or even 3.
Paul L is offline
Old 05-11-2009, 05:08 AM   #1105
xraysteve's Avatar
I have a setup question. what are some things you could try to get rid of a hook. I go around the corner and when I get on the gas the car just wants to spin the way I was just turned. It is not really loose. It just wants to keep going in a circle and not straighten up. This is on asphalt.
lazer speedway everything else is a parking lot
xraysteve is offline
Old 05-11-2009, 09:30 AM   #1106
is it possible to find a good set up for the t2 009 carpet version, to run on med to low traction asphalt ? thanks
flyin_brian is offline
Old 05-16-2009, 08:41 AM   #1107
Gravity RC
Hi, How much rear toe are u running?, make sure that you have 3degs. you can try standing up your rear shocks and see if that helps also. a nother thing that should help is using the long position for the rear suspension arms, all shimms in front of the rear arm. try that stuff and see if it has any success. Thanks
I would download a asphalt set up for the 09 rubber car and copy it to your carpet car, get a spool of course. it should work nice. I dont have any set-ups that i think are great for asphalt, look at a few from Teemu or Elliot and see what you think you might like. Thanks
Paul L is offline
Old 05-16-2009, 12:16 PM   #1108
STLNLST's Avatar
Trader Rating: 21 (100%+)
Paul L- After being contacted by Birch I will stay in 13.5 and won't switch to mod to give you a run for your money at next week's Reedy race See ya next week bro. Travel safe and tell my boy Drew I said what's up
STLNLST is offline
Old 05-16-2009, 12:20 PM   #1109
STLNLST's Avatar
Hey Paul,
1/2 oz vodka
1/2 oz rum
1/2 oz gin
2 oz 7-Up® soda
double the amounts and really have some fun
STLNLST is offline
Old 05-18-2009, 10:52 AM   #1110
Gravity RC
will do C, lol see ya in a couple of days!
Paul L is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
