Closed Thread
Old 03-23-2009, 12:06 PM   #1051
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by kendallb View Post
So as you can see, those FDR ratios are WAY out of the normal range that you would think to run in 13.5, and if you ran it with a normal ESC the car would be silly slow on the straight. But with the new ESC's that have a timing boost option, you can run a high FDR to give incredible punch out of the corners without losing any top end speed on the straight.
What ESC/Motor combo are you planning to run?
13.5 pulse from express, also maybe a 13.5 duo (goin to compare the two), and either sphere tc at first then switch to my KO BMC-1( i have both). I don't have the programming adapter for the BMC yet so thats part of why I am holding off on that one.
thanks
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline
Old 03-23-2009, 09:40 PM   #1052
adamge's Avatar
http://forum.teamxray.com/xform/inde...5&setup=t2_008
(it's easy to find because it is a featured setup)
Before this one I was running the Cleveland one, which is similar. I find this one even better. The car absolutely loves power. I got to drive it on a larger track with a 6.5t, and it begs you to enter the sweeper faster and hold more power through it.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline
Old 03-24-2009, 10:51 AM   #1053
thanks
If you are using an LRP ESC, I would start out with an FDR of 4.5 to 4.8, and leave the ESC in the normal profile. I am pretty sure the LRP aggressive profiles use boost timing. Either way, set up the car and run it, and gear for temps and speed. If you use an aggressive boost mode on the ESC, increase the FDR, and try to keep the temps around 180 after a 6 minute run.
Kendall Bennett, CEO
AMain.com Performance Sports & Hobbies
http://www.AMain.com
kendallb is offline
Old 03-24-2009, 10:51 AM   #1054
Hmm, that is the setup I was testing with also. Not sure if the problem is our track has silly traction, or something else. I will have to double check the entire setup on that car and see if I missed something.
kendallb is offline
Old 03-24-2009, 11:10 AM   #1055
rx7ttlm's Avatar
stock timing yes?(o degrees)
rx7ttlm is offline
Old 03-24-2009, 03:07 PM   #1056
Con
I noticed in the xray set up that the oil weights are 300 anf 500.Is this equiv to 30 and 50 in assoc oil??
Con is offline
Old 03-24-2009, 03:54 PM   #1057
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
100 = 20w
200 = 25w
350 = 30w
600 = 35w
1000 = 40w
2000 = 50w
I would just use the cst style though. Setups normally use 350,600,1000.
ChristopherKee is offline
Old 03-24-2009, 04:12 PM   #1058
Trader Rating: 1 (67%+)
The AE oil has the cst #'s on the bottle.
Josh Hohnstein is offline
Old 03-24-2009, 04:36 PM   #1059
Con
Con is offline
Old 03-25-2009, 10:55 AM   #1060
Start with the stock timing (which shouldn't be 0 I would not think?) and go from there. The more timing you use, the more speed, but it will get a lot hotter. Less timing needs a lower FDR, more timing needs a higher FDR. At least that is how it seems to work in practice for me
kendallb is offline
Old 03-25-2009, 10:56 AM   #1061
I would use XRAY oils, as they are actually different to most other CST oils (a bit lighter I think).
kendallb is offline
Old 03-29-2009, 11:22 AM   #1062
Send a message via MSN to Bigger Brother
Hi Paul
I'm after a bit of advice - I'm in need of some new LiPo cells, and very tempted by the Trinity ones....
Basically, I'm looking at either the 3800 35C or the 5000 30C packs. My main competitive racing will be 10.5 outdoor, with occasionally 13.5 indoor (but that's just club racing) - which of the two cells do you think would be best suited to my situation? (Or are there another you'd recommend?)
Many thanks for any advice
Oli Meggitt
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline
Old 03-30-2009, 03:04 PM   #1063
Gravity RC
Hi Paul,
I ran your setup from the Snow Birds on my T2'009 for 17.5 rubber and 13.5 rubber, and I have to say, it was DIALED! I didn't actually change anything on the car, and I think I will leave it that way for a while. So far, that is the best setup I have run on my rubber car, by far.
So, now I am about to go outdoors and run some asphalt. Do you have a good setup you can recommend for 13.5 rubber asphalt tracks? I will most likely be racing at Speed World in Sacramento most of the time, so I need to find a good setup for that track....
Hi, sorry for the delay. i dont have a set up that i am as confident in as i am my carpet set-ups. i guess that i would start with Ralph birch's set up from the reedy race last year ( he was really good at speedworld ). or i would try one of the euro asphalt set ups. wish i could help more. Thanks
Paul, I tried your Novak race mod-foam setup today. It is marvelous, the car was a dream to drive in 13.5, and it was begging for more motor.
That is great to hear, that set up has had a lot of work behind it!
Paul, what fdr would you run on a tight track with 13.5 rubber?
Just to be safe i would start at around a 5.5 for a tight track and check temp from their, 140-160 is acceptible, 175 and more is getting toasty.
Can you post a link to that setup? I ran the one from the Snowbirds but was having trouble with the rear end dumping over and unloading the inside rear wheel. So I am wondering if the Novak setup is different. I think the front end needs to be stiffer on my setup to stop the rear end from dumping over.
maybe try me most recent set up from the nationals, that track was a little nosy for me so i ended up with a bigger front bar. make sure that you have fixed pistons in your shocks (not clicker), i use the fixed pistons and they are a lot different. also double check that it is copied properly (low rear roll center, ect). normally that set up is pretty good about not lifting the inside rear tire, the difference could be something small that you missed.
[QUOTE=kendallb;5586071]From my experience, the FDR you run is entirely dependent on the brand of motor and ESC you are using, the timing you have on the motor and ESC as well as the winds of the motor. For instance the 'normal' FDR that most people would start with for 13.5 would be around 4.5 (assuming a basic fixed timing of around 24 degrees or so). However if you are running a new ESC like the Tekin (with 189 or later beta software) or the new LRP SPX ESC, those have timing boost modes built in that will completely overheat your motor at a 4.5 FDR timing.
Thanks, very true, their is no standard gearing anymore. the only thing to do is to start conservitave.
I run the Tekin 13.5 setup with the 189 beta software, and my most current setup was to run an FDR of 5.8, ZERO timing on the motor can and full boost in the ESC. My other setup that I also like is full timing on the can of the motor, boost of about 10-12 and an FDR of around 6.15.
Thanks for the input!
[QUOTE=adamge;5589029]http://forum.teamxray.com/xform/inde...5&setup=t2_008
Xray uses CST rating, this dosent mean that it is exactly the same as others but it is close, associated does have the cst rating on their bottles now. but i would suggest using the xray oils just to keep it exactly the same. now that the cars are so fast oil can make or break a set up.
Thanks Josh
Originally Posted by Bigger Brother View Post
Hi Paul
Oli Meggitt
Hi Ollie, I would definately suggest the Ip 5000 30c. honestly the C rating means nothing on the track. i dont think that we draw what it takes to make the C rating mean anything. for mod i dont care much which battery i use because we have so much power but for any limited motor class i use the IP 5000.
thanks.
Paul L is offline
Old 03-31-2009, 04:30 AM   #1064
Many thanks for that, very useful information!
Oli
Old 03-31-2009, 04:52 AM   #1065
Hi Paul
What is the effect of running the 1 degree rear hubs, compared to the same overall toe all in the arm?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
