Closed Thread
Old 01-11-2009, 08:03 PM   #1036
Moderator
yfzrider's Avatar
Send a message via MSN to yfzrider
Thanks for all the help this weekend Paul,, and congrats for killing everyone in your classes.
yfzrider is offline
Old 01-12-2009, 09:10 AM   #1037
The Evicerator
Good job this week Paulie! Hope to see you in a few weeks!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline
Old 01-12-2009, 12:26 PM   #1038
Default cleveland
YGM congratulations
Do you have the set-up posted?
Ed
eded1 is offline
Old 01-22-2009, 10:02 AM   #1039
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Paul L View Post
my rubber set-ups are normally all over the place but hopefully in the future they will be closer because I have been really happy with my rubber car lately.
Paul
Have you posted up this latest setup for rubber? I just switched to Xray and would like to try a few others out to get to know the car. I'm running 13.5 rubber (Sorex 28).
Christopher
ChristopherKee is offline
Old 03-07-2009, 02:39 PM   #1040
Send a message via AIM to A-Ko
Hey Paul hope all is well with you.
Future dates forecast are March 8 and 22 if you are available.
Should have 2-3 dates in April and the last one is a 2 day event.
I will be at Scotty's on the March 27-29 weekend.
Hope to see ya passing through.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline
Old 03-12-2009, 07:33 AM   #1041
Gravity RC
Christopher
Should be up their, let me know if its not.
Paul L is offline
Old 03-12-2009, 07:34 AM   #1042
Gravity RC
Hi Jeff, Im planning to be at trackside for the Tamiya race just to help out. see ya their.
Paul L is offline
Old 03-15-2009, 07:16 PM   #1043
Hi Paul,
I ran your setup from the Snow Birds on my T2'009 for 17.5 rubber and 13.5 rubber, and I have to say, it was DIALED! I didn't actually change anything on the car, and I think I will leave it that way for a while. So far, that is the best setup I have run on my rubber car, by far.
So, now I am about to go outdoors and run some asphalt. Do you have a good setup you can recommend for 13.5 rubber asphalt tracks? I will most likely be racing at Speed World in Sacramento most of the time, so I need to find a good setup for that track....
Kendall Bennett, CEO
AMain.com Performance Sports & Hobbies
http://www.AMain.com
kendallb is offline
Old 03-15-2009, 11:54 PM   #1044
adamge's Avatar
Kendall, are you referring to the setup from over a year ago? ( http://forum.teamxray.com/xform/inde...6&setup=t2_008 ) Because I'm not seeing a newer Snowbirds setup from Paul on the xray site.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline
Old 03-16-2009, 09:17 AM   #1045
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
His Novak setup is good as well.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline
Old 03-16-2009, 04:12 PM   #1046
No, it is his new setup from the Jan 17, 2009 Snowbirds. It is on the XRAY forums, but for some reason only shows up in the 'Featured' setups section. Try it, the setup is killer!
Here is the link:
http://forum.teamxray.com/xform/inde...4&setup=t2_008
kendallb is offline
Old 03-21-2009, 04:34 PM   #1047
adamge's Avatar
Paul, I tried your Novak race mod-foam setup today. It is marvelous, the car was a dream to drive in 13.5, and it was begging for more motor.
-Nietzsche
adamge is offline
Old 03-21-2009, 10:14 PM   #1048
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Paul, what fdr would you run on a tight track with 13.5 rubber?
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline
Old 03-23-2009, 10:24 AM   #1049
Can you post a link to that setup? I ran the one from the Snowbirds but was having trouble with the rear end dumping over and unloading the inside rear wheel. So I am wondering if the Novak setup is different. I think the front end needs to be stiffer on my setup to stop the rear end from dumping over.
kendallb is offline
Old 03-23-2009, 10:30 AM   #1050
From my experience, the FDR you run is entirely dependent on the brand of motor and ESC you are using, the timing you have on the motor and ESC as well as the winds of the motor. For instance the 'normal' FDR that most people would start with for 13.5 would be around 4.5 (assuming a basic fixed timing of around 24 degrees or so). However if you are running a new ESC like the Tekin (with 189 or later beta software) or the new LRP SPX ESC, those have timing boost modes built in that will completely overheat your motor at a 4.5 FDR timing.
I run the Tekin 13.5 setup with the 189 beta software, and my most current setup was to run an FDR of 5.8, ZERO timing on the motor can and full boost in the ESC. My other setup that I also like is full timing on the can of the motor, boost of about 10-12 and an FDR of around 6.15.
So as you can see, those FDR ratios are WAY out of the normal range that you would think to run in 13.5, and if you ran it with a normal ESC the car would be silly slow on the straight. But with the new ESC's that have a timing boost option, you can run a high FDR to give incredible punch out of the corners without losing any top end speed on the straight.
What ESC/Motor combo are you planning to run?
kendallb is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
