Closed Thread
Old 10-27-2008, 06:27 PM   #931
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Originally Posted by MikeXray View Post
Paul, what adjustments do you use most to deal a car that is traction rolling?
What type of tires and surface?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline
Old 10-28-2008, 05:45 PM   #932
Gravity RC
Originally Posted by Nuno Gancho View Post
Thanks Paul for your answers and patience, hope you have a good race in world championship.
Thanks, ill need some luck over their because i have not spent any time their prepairing.
Originally Posted by mtbboy View Post
Awsome .
Thanks again Paul.
Sorry about Celine America.
Especially the residents of Nevada.
Dave.
no problem Dave.
Hi, Paul, will it have a significante diference in using diferent lenght shafts.
Are you using the original oring for your shocks or could it be a diferent brand like MM, Hara tamiya...
Different legnth drive shafts do make a difference, lately i have been running the 52mm most of the time, the car seems more predictible for me with the 52mm. or if you were speaking shock shafts i always run the complete kit Xray shocks.
I use the stock Xray o-rings in my shocks, i have never had any complants with them. i have never tried any other brands.
Originally Posted by EAMotorsports View Post
I was walking step for step with Herrmann this weekend!! Damn you Tag!
EA
Oh well Eric, i heared that you put it on them in world GT, good job.
Hi Mike, if you are talking Foam tires its easy (just go softer rear spring with med oil untill it stops, and maybe a little softer front also. but with rubber tires it is much more difficult, softer usually helps but will not always cure it. for me their is no set way to stop it, you just want the car to roll evenly, when my rubber cars traction roll its usually because it is rolling too much over the front end or the rear, so i would start by making it roll evenly over the side. and if all else fails you could just super glue the side wall of the front tires. so basicly just start trying stuff. maybe someone else could help on here too. wish i could be more help.
Paul L is offline
Old 10-28-2008, 09:44 PM   #933
Send a message via AIM to A-Ko
Hey Paul,
Looks like the 17.5s are coming to the surface this week at the distributors.
Check your RCTech email for other info.
Thanks for your help. will let you know if 17.5s does not happen.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline
Old 10-29-2008, 03:53 AM   #934
Nuno Gancho's Avatar
Thanks Paul, You can do it in the World, just keep going
Nuno Gancho is offline
Old 10-29-2008, 05:36 AM   #935
RCknight's Avatar
Default Paul, qustion about the 008 aluminum brace?
Hey I run in the vintage class and I noticed my car seems to stop in the corners. I don't understand why. My question is should I go stiffer front springs or try the aluminum front brace?
RCknight is offline
Old 10-29-2008, 06:02 AM   #936
Kropy's Avatar
Send a message via AIM to Kropy
Paulie good luck over in Thailand!!!!!!!!!!!!!
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline
Old 10-29-2008, 06:53 AM   #937
All of these are based on the middle timing setting on the DUO motors. Adjust gearing to get the motor around 160-170 degrees. I dont like getting them much over 180 although it doesnt hurt the rotors on the Trinity motors like it does others.
EA
This temp is based on a 10 min run?
stocker is offline
Old 10-29-2008, 07:43 AM   #938
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
These temps are based on a 6 cell/2 cell lipo 5 minute run. 4 cell applications will be a lot cooler even 8 minute 12th scale. My motor at the Halloween race in 10.5 was coming off at around 120 after 8 minutes.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline
Old 10-29-2008, 08:54 AM   #939
EA
Thanks for the info. I have just under 180 at 10 mins. Is this OK for my 13.5? If at 10mins, I stop and take a break, when can I start running again? Ambient temp are hot here, I don't think I can gear up anymore though I think I am at full speed just before half the straight. Tried adding another tooth, but ended up 190+ at 10 mins!
Dang, I just found some scratches on the nice blue endbell on my 13.5 from today's run!
stocker is offline
Old 10-29-2008, 01:56 PM   #940
Paul, new N40 for 1/12 it's a 3turn ?
scarecrow is offline
Old 10-29-2008, 06:32 PM   #941
Gravity RC
Yea we will see, ill do my best, Thanks much
Thats a hard one to answer. without seing the car go i cant say exactly what to do. i would try a stiffer front spring if that helps it means that the car was diving over the front too much, but keep in mind that that will make the car a little more edgy on center. are you rinning a spool, 1way, or diff? how is the rest of the set up? thanks
Thanks Dale
EA
Thanks again for the help EA
Paul L is offline
Old 10-29-2008, 06:34 PM   #942
Gravity RC
? maybe you know something i dont. sorry im not sure what your talking about. Talk to you soon man.
Paul L is offline
Old 10-29-2008, 07:22 PM   #943
AndrewNicholas's Avatar
Default Just Wondering?
Has anyone come flying into your bathroom in the hotel while you were trying to take a dump lately?
LOL!!
Sorry man!
AndrewNicholas is offline
Old 10-29-2008, 07:34 PM   #944
Team EAM
Is there any particular reason that you run for 10 minutes? If your using a lipo be sure to be careful not to overdischarge it as it can cause damage. 180 is pushing the limit of the motors but if you have ran it there all along then it should be able to withstand it. I would wait till everything cooled down before running it again just to be safe.
EA
Contact Us
Old 10-29-2008, 08:27 PM   #945
theDover's Avatar
Hey Paul- I know this ? seems a little unusual but....What rear TC wings do you run and if they are after market, which ones do you recommend, and where could I find them? Thanks.
-Ben
TEAM ULTRALINE / RickyRacerLidz
www.ultralinehobbies.com
Ultraline Hobbies RC Raceway @ fb
theDover is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
