Closed Thread
Old 04-25-2008, 06:17 PM   #646
adamge's Avatar
racingboy, I'm not aware of an xray 12th scale.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline
Old 04-25-2008, 06:51 PM   #647
racingboy14's Avatar
Trader Rating: 25 (96%+)
opps how could i forget sorry 12th scal guys
Bk Graphics Custom Painted Bodies
Email me at [email protected] for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline
Old 04-26-2008, 04:57 PM   #648
Hi paul,
ive posted a thread about this but i thort your advice would be great!
how do you normaly set your front toe value? especialy if you run a .5 angle
thanks
Xrayraycer008 is offline
Old 04-26-2008, 09:35 PM   #649
trailranger's Avatar
Originally Posted by Steve Weiss View Post
Paul,
Can you help me dial in my tumbleweed? I tried checking out this website
http://prairietumbleweedfarm.com/
But it really didn't help me all too much although the sections on tumbleweed testing and the GIANT tumbleweeds sure are great reading!
have you tried raising the roll center? That seems to always work in getting it my car rotate more. If you are looking to go faster, shake the seeds out first...less rotating mass.
trailranger is offline
Old 04-27-2008, 02:36 AM   #650
FX Racing's Avatar
Paul
I have a old Xray T1FK04 with a 27t epic motor and my car doesnt have much grip in the rear. I changed the shock position and doesnt seem to spin as much out of the corners as it used to but still spins out of some corners if i were to move the position of the rear the sway bar would it make the spin less? Also what would be a good competitive final gear ratio for stock Im using 6.09 as my final drive ratio with a 93 spur to a 27 pinion. The track is small and tight and its asphalt. Thanks for your help and taking your time to answer my questions
FX Racing is offline
Old 04-27-2008, 10:39 AM   #651
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
Originally Posted by racingboy14 View Post
All xray needs now is an 8th scale onroad car, they have every other scale and catergory that is raced covered.
yeah, im confused why they would leave the best two classes in rc out, or maybe their just saving the best for last? Honestly, i think 1/12 and 1/8 are the purest form of racing, because you need some serious skill to keep those 1/8ths on the track, and 1/12, is a really old, 2WD racing, where its not all about new stuff, like in touring car.
Press Alt+F4 for a good time.
Ferrarimk13 is offline
Old 04-28-2008, 01:50 PM   #652
Gravity RC
ferrarimk13: Hi, as far as i know they are not coming out with anything new. the 008 is still new to me and i think with the success of the car to date they are very satisfied with it. the multi diff is out now and they have two different legnth driveshafts, so i would expect a couple of new parts but i dont see a new kit design coming. I am also wishing for them to eventually get in to those classes also.
Xrayraycer008: I normally run just a touch of front toe out, i use the hudy guages with the slide pece and im always around 0.5deg total toe'd out. you can barely see it.
Trailranger: LOL sounds good to me.
FXracing: Im not sure where to gear a stock motor, how big is the track (maybe someone could help out), sorry. Which way did you go with the shocks that helped?. I never raced that car so im not totally sure but i would try a longer wheelbase by mooving the rear arms back, that should make a big difference (hopefully for the better). I assume that you are running rubber tires, what kind?.
let me know, Thanks.
Paul
Paul L is offline
Old 04-28-2008, 01:52 PM   #653
STLNLST's Avatar
Trader Rating: 21 (100%+)
Paul
Are you coming to the Reedy warm up race? I could use the competition....LOL
STLNLST is offline
Old 04-28-2008, 02:02 PM   #654
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Originally Posted by FX Racing View Post
Paul
Gearing in the 6.8-7.0 range would probably be better also taking the rear sway bar off /or going thinner on that car would probably help, also try a softer rear spring. Those two things along with what Paul said should help if your tires are up to par.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline
Old 04-29-2008, 06:07 PM   #655
Gravity RC
stlnlst: no i wont be, wish i could but i cant.
Rkeasler: Thanks for the added help.
Paul L is offline
Old 04-29-2008, 08:04 PM   #656
CypressMidWest's Avatar
See ya this weekend Paul!!
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline
Old 04-29-2008, 09:55 PM   #657
FX Racing's Avatar
i shifted the rear shoks outwards also im using take off 27's best suited tire for our track due to the heat.
Old 04-30-2008, 10:34 AM   #658
paul when are you going to come back and run a real class?
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline
Old 04-30-2008, 02:03 PM   #659
Gravity RC
Cypress: Oh yea..
FXracing: try some of the things mentioned and let me know.
Leon: sooner than you think.
Paul L is offline
Old 04-30-2008, 05:01 PM   #660
Default swaybars
Hi Paul,
I've read thru all the posts, this thread is most informative. Just wanted to ask when do you usually use swaybars or not... and when do we use just the front or the back?
For example I run on a track with 13 laptimes for foam 200mm nitro cars with decent grip... i guess medium flowing with some technical portion...
Thanks in advance.
Joel
rccartips is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
