Closed Thread
Old 04-21-2008, 11:21 PM   #631
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Paul L View Post
Jag88: I always run a center one way when i am already running the independent front one way. but that is the only time that i run the center one way. Thanks
Jay: good pic, I hope you didnt Google Ralph Burch to find that because it would be weird then.lol
hahhaha....it's from a 1984 Team Associated newsletter that I found in my files today. There are also some rad photos of Jr and Jammin Jay Halsey from the first ROAR off road nats in there...
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline
Old 04-22-2008, 04:04 AM   #632
xraysteve's Avatar
ok the set up you posted worked ok. i took the rear sway bar off for more rear end grip. i have silver springs on the front and gold on the rear. i lade the shocks all down one hole. i have a front diff. i just could not get the spool to work. i think i might try the spool one more time now that i have the rear sway bar off. that seemed to help the most. BUT STILL FLIPING OVER!!! my camber is 2 1/2 rear and 1 1/2 front one more race left. is this a good set up for out door.
lazer speedway everything else is a parking lot
xraysteve is offline
Old 04-23-2008, 07:41 AM   #633
Gravity RC
Xraysteve: Well, im glad that you are having a little success. Keep trying stuff. for ashpalt you will most likely want to again try to run a spool and a lower front inner hinge pin (lower front roll center). you could start their for asphalt or download the General ashpalt set up on the Xray site.
Paul L is offline
Old 04-23-2008, 07:55 AM   #634
RayJ's Avatar
Default Midwest series
Hey Paul .....are you going to Cincinnati for the first Midwest Series Race? RayJ
RayJ is offline
Old 04-23-2008, 03:41 PM   #635
racingboy14's Avatar
Trader Rating: 25 (96%+)
I was gonna sk the same thing. Are you going to the send Seris Race in Cinciy I plan on going to that one!
Bk Graphics Custom Painted Bodies
Email me at [email protected] for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline
Old 04-23-2008, 09:46 PM   #636
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Paul,
On an 08 EU, (running high bite asphalt); I am using a fairly basic set-up, but Ive got an on power push that I have been fighting. Also, its killing front tires. One of the things I want to try is changing the ackermann. However, I keep getting conflicting opinions on which way to go with it. I think I should move the rack forward to #4 or #5. (currently at #2)
Does this sound right to you? Do you think this will make much difference in the tire wear?
(as I mentioned the bite is high, and the layout has several long sweepers and only one chicane)
mrrcguy is offline
Old 04-24-2008, 06:37 AM   #637
Gravity RC
Ray J, Racingboy14: Yep, hope to see you both their.
Mrcguy:I dont know that ackermann is going to be the ticket in this situation. you need to find steering, then you wont have to use as much steering throw and your front tires will wear better and not overheat as much. I get to run so little on asphalt that im not sure what adjustments will be the most effective. here is what i would play with first, rear toe, 1deg rear camber/2deg front camber, and front Kick up. you will most likely have to A B alot of adjustments and find small increments of steering in many different places.
Paul L is offline
Old 04-24-2008, 08:52 AM   #638
Regional Moderator
mrrcguy's Avatar
Thanks for getting back so quick. I here you and Shrek will be comming down to my place for the Nats Warm-Up, Im lookin forward to it, see ya then.
mrrcguy is offline
Old 04-24-2008, 09:00 AM   #639
turd ferguson's Avatar
Send a message via AIM to turd ferguson
You can't say Swreck!
TrakPower, Speed Passion USA, Pro-line, Stickit1 Racing, LiveRC.com
turd ferguson is offline
Old 04-24-2008, 09:05 PM   #640
Hey paul I bought my first xray last wek which is a EU t2 008 . they say it has alittle bit of push by the box set-up .What is they best way to get rid of this I am at the same track as mrrcguy so it is high bite asphalt ?
eflite300 is offline
Old 04-25-2008, 07:46 AM   #641
Gravity RC
Turd:lol
Eflight300: I would start by trying some of the same things that i talked about with Mrcguy above. I would try it with the standard set-up before changing much.
Paul L is offline
Old 04-25-2008, 07:50 AM   #642
Customworksking's Avatar
Trader Rating: 73 (100%+)
Turd:lol
Paul r u going to be able to make the outdoor Nat's?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline
Old 04-25-2008, 12:26 PM   #643
Gravity RC
customworksking: yea ill be their.
Paul L is offline
Old 04-25-2008, 04:02 PM   #644
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
Paul, is xray working on any new model yet, or just some parts here and there?
Press Alt+F4 for a good time.
Ferrarimk13 is offline
Old 04-25-2008, 05:42 PM   #645
All xray needs now is an 8th scale onroad car, they have every other scale and catergory that is raced covered.
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
