Closed Thread
Old 03-31-2008, 04:38 PM   #556
Kropy's Avatar
Send a message via AIM to Kropy
Paul ~ xraysteve runs at Josh's old track at the mall, Hope that help ya' out a little
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline
Old 03-31-2008, 05:03 PM   #557
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Originally Posted by Paul L View Post
Ryan14: I do sometimes, I always race 12th scale at the Worlds and other selected US races, im sure that i will be doing more of it in the future.
So when is xrays 12th scale going to be released?
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline
Old 04-01-2008, 08:56 PM   #558
Trader Rating: 26 (100%+)
paul-i saw that you use a futaba 9351 servo and if this is correct why such a slow one rated at .13 compared to a high speed with .07 transit time?
eddie10 is offline
Old 04-02-2008, 08:10 AM   #559
dj apolaro's Avatar
Paul can you call me it is DJ (305-586-6072) Thanks
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline
Old 04-02-2008, 09:54 AM   #560
Gravity RC
Xraysteve: Hi, it dose make sence to me that going stiffer made it worse. normally when traction rolling stiffer makes it worse because a stiffer spring just makes everything happen faster. Lately i have been running 4 of the same springs all the way around, in vegas i ran Xray coppers all the way around, that spring is somewhere around 14lbs. It is hard to say about the rest of the set up because it is very different with a front diff. But yes a stiffer front spring usually makes it worse. I think that you will just have to try some stuff. My suggestion would be to put a carpet/rubber set up on the car from the Xray site and dont change anything except, driveline(diff or spool), springs, and camber. Just see how far those adjustments can get you. and always run 3deg rear toe. Let me know what was the best combination of those three things then maybe we can work from there.
Thanks Kropy.
Kave: Im not sure atall, It has been talked about but i have had no instruction as to when or even if its 100% going to happen. I do think it will.
Eddie10: I dont worry about speed at all, if its faster than .17 Ill run it.
I think slower servos can be easier to drive sometimes. But right now the 9351 works good for me.
Thanks, Paul
Paul L is offline
Old 04-02-2008, 03:57 PM   #561
xraysteve's Avatar
i will use your las Vegas set up with a diff. it dos not say were to put the quick roll center adjustment. i would think high and inside. should i not be any more than 3 degrees negative camber. and no less then 1degree. i appreciate the help.
lazer speedway everything else is a parking lot
xraysteve is offline
Old 04-02-2008, 06:29 PM   #562
Gravity RC
Xraysteve: for camber you dont want to be more than 2.5 in the rear and 2 in the front, and no less than .5 in the front and 1.5 in the rear. vegas set up had high front roll center and low in the rear, this is important.
Thanks,
paul
Paul L is offline
Old 04-03-2008, 09:28 AM   #563
Ridge_Racer's Avatar
Send a message via MSN to Ridge_Racer Send a message via Yahoo to Ridge_Racer
stupid question. When installing C hubs, do the labels (4L 4R) face the front of the car or the rear?
Also, the camber link on the front right side of my car is binding. How do I go about getting the A arm and the camber link to move up and down more freely?
http://www.countdowntovegas.blogspot.com
Ridge_Racer is offline
Old 04-03-2008, 10:24 AM   #564
Gravity RC
Ridge_racer: the 4L or whatever it may be should be facing the bumper or the fromt of the car.
If i could see the car im sure i could fix theRF bind right away. Are you sure its the camber link?. if you are, the balls inside the plastic links are bound up and you may have to squeez them with a pliars. but it sound like it may be something more. When i build a car i do it by steps, first i put the arms on the car(only the arms) if that is free then i put the caster block on the arm, if that is free then i hook up the camber link. so in the end their is nothing that could be bound up, and if their is i always know exactly what is doing it. The only other thing that it could be is a bound up dog bone inside the axle. It is very rare for these things to happen with an Xray, so make sure that it is assymbled properly before modifing anything to make it free.
Thanks paul
Paul L is offline
Old 04-03-2008, 12:52 PM   #565
I checked everything before posting. A-arms first, then Caster block and wheel assembly. I make sure the whole thing falls under its own weight. Then when I put the link on, the assembly will fall but then I can push it down even more. The left side doesn't do that. I'll do the plier thing and get back to you.
Thanks Paul
Old 04-03-2008, 03:51 PM   #566
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default u
Paul wheres the next race ?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline
Old 04-03-2008, 07:38 PM   #567
xraysteve's Avatar
when you say high front roll center do you mean the top inside whole or the top out side hole. the rear should be low but bottom inside or bottom outside hole.
should i not be running any post at all being that my chassis is the us version.
Old 04-05-2008, 09:46 AM   #568
xraysteve's Avatar
Old 04-05-2008, 11:40 AM   #569
ottoman's Avatar
R/C Tech Charter Subscriber
Generally when you say High or low rollcenter with a XRay you are talking about the arm hinge pin holders. They have a dot on one end that indicates high, mid, or low roll center.
ottoman is offline
Old 04-05-2008, 04:37 PM   #570
xraysteve's Avatar
the setup sheet shows were to put the arms but do not show were to put the quick roll center adjustment. i am racing tomorrow so any help today will help.
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
