Old 12-20-2007, 08:25 AM   #1
joe of loath's Avatar
Talking Excel top speed calculator
i made this because i was bored, and because i wanted to know my top speed not my rollout. i think i got it right, so if theres anything wrong tell me.
btw its defaulted to an 'out of the box' HPI E10. and as it says, only edit the yellow cells or you'll break it
if you have no internal gear ratio, then set it to 1.
Joe
p.s i added an extra unit of speed for all you speed freaks!
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 12-20-2007, 09:30 AM   #2
gacjr0's Avatar
Trader Rating: 15 (100%+)
from what I saw, theres no Pi in your formulas anywhere, and your overall gear ratio needs to be spur/pinion * internal gear ratio.
you can fudge aerodynamic drag by multiplying by .95 or .8 or pick a number less than 1, or you could figure out/find the formula for drag
good luck
gacjr0 is offline   Reply With Quote
Old 12-20-2007, 01:01 PM   #3
hmm strange, it seems to work..... i know, i should replace diameter with circumfrence.
Old 12-20-2007, 01:06 PM   #4
good luck
i'm still not sure how to work out inernal gear ratio. i did it as 7.48 (final ratio) minus 4.25 (spur/pinion)... total bodge job!
oh and aerodynamic drag is exponential (or is it squared or cubed) anyway it isnt linear....
EDIT: a bit of trial and error later i seem to have my internal gear ratio sorted, but still no formula... it works as logn as you know it!
EDIT: it wont work.. somethings wrong :'(
EDIT: ok i got it working! there were some relics in the equations from when i was working in millimeters.
Old 12-20-2007, 02:12 PM   #5
ok it seems to work now.
btw this is just a bump TTT
EDIT: now changed tyre diameter into MM from meters
Old 05-19-2008, 11:34 AM   #6
bump, just in case someone actually cares.
p.s. IT WORKS!
Old 05-19-2008, 02:46 PM   #7
shadow102's Avatar
Trader Rating: 21 (96%+)
anybody got an idea of the RPM of a 4.5R brushless motor?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 05-19-2008, 10:53 PM   #8
SpidarX's Avatar
When trying to open the file, it says the file is corrupted.
SpidarX is offline   Reply With Quote
Old 05-20-2008, 04:38 AM   #9
Kv * volts
so for a 6600kv motor it's 6600*7.2(or 7.4 if running lipo)
WTB serpent excel mk2 mr8thscale R/C Items: Wanted to Buy 4 08-28-2007 05:20 PM
TI 89 Calculator losirunner Other Items: For Sale/Trade or Wanted to Buy 5 10-25-2005 11:47 AM
