TC4 FACTORY TEAM PROBLEM
Hi i have problem wit my tc4 ft the car the sterring is binding and i am not sure what to do to make it stop help me out.
Originally Posted by Carpetracer92
(Post 3990094)
mitchell, sounds like you may have a stripped out servo horn.
Originally Posted by loopedout
(Post 3990904)
nah servo horn is fine
what type of servo are you running?
(Post 3990928)
Are all of your wheel/diff bearings good? A bad one will cause drag and possibly the car will steer to one side. Also make sure you havnt overtightened the wheel nuts, an easy mistake to bind up the hub bearings and cause drag on that corner.
Turn the steering slowly by hand and see if you can see anything rubbing or feel where abouts the problem area is coming from. hth :) |
Originally Posted by tc3team
(Post 3990951)
I'd change them but as long they are clean and spin freely they shouldnt cause a problem.
Originally Posted by Mitchell
(Post 3990964)
on a couple of the bearings you can see the balls inside them because the case thing covering them has come off. is that bad?
(Post 3990094)
i had a similar problem. just take the whole steering assembly apart and check the every link and bearing to see if there is a binding issue with any of them. if not, when putting the steering assembly back together, make sure you don't over tighten the bolts that hold the assembly to the chassis. if these are too tight, it will bind very badly HTH |
(Post 3990990)
(Post 3990995)
It can be, as without that your bearing is more exposed to dirt and premature failure. If you can, take the bearing out and turn the inner part by hand. If it feels like it has notches its shot.
yeah they are all rotating alright
I remember when I had my tc3 if you overtightend the two steering rack nuts it makes the steering "sticky" and bind up, but I think thr TC4FT might have a different setup on it?
A bearing has to be really bad on one corner though to cause the car to run off centre, loads of drag. As a last measure, take the servo out the car and turn the wheels lock to lock and see if you can feel anything binding up, its the only true way of feeling what the car is doing when its steering. Check the pins in the cvd's are not loose and rubbing on the hubs too- that could get real ugly.... |
(Post 3991015)
ps sorry for hijacking your thread carpetracer92;)
(Post 3991015)
A bearing has to be really bad on one corner though to cause the car to run off centre, loads of drag. As a last measure, take the servo out the car and turn the wheels lock to lock and see if you can feel anything binding up, its the only true way of feeling what the car is doing when its steering. Loosen the 2 screws that hlod the steering rack to the chassis about 1/4 of a turn. then do as "tc3team" says and take the servo hrn off and move the steering. hopefully this would of fixed it. |
(Post 3991024)
sorry i was wrong there was a shot bearing. just changed it thanks all for your help:)
(Post 3991030)
Let us know how you get on, it should have helped :)
hay mitchell hows the car going
i see you bought a 13.5ss have you got it yet
i'll see you at the track
