Old 01-06-2008, 04:57 PM   #31
Evilstealth's Avatar
Send a message via MSN to Evilstealth
Hey Guys,
Still working on the PDA version, should be up soon.
Have a good new year
Adam
http://www.rctech.net/forum/electric-road/290595-new-offline-rollout-calculator.html#post5695222 - Offline Rollout Calculator
Evilstealth is offline   Reply With Quote
Old 02-04-2008, 09:05 PM   #32
Hey all,
Are there any new cars that have come out that isnt on the calculator or anything you want me to add?? Also what is the transmission ratio of the TA05MS (i think its called that)
Regards
Adam
Old 02-05-2008, 10:28 AM   #33
Regional Moderator
CarbonJoe's Avatar
One suggestion... Can you add two radio buttons to select between mm / inches? The the tire diameters could be specified in inches, and the Speed in MPH. Lots of people in the States still talk about rollouts in inches. I'd love to get this on a Dell Axim X51v (VGA resolution) Intel PXA270 processor (Strong ARM), running Windows Mobile 5.0 (WinCE 5.0).
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-06-2008, 01:57 PM   #34
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by Evilstealth View Post
Hey all,
Regards
Adam
Is the T2 008 you have listed the EURO Spec? I thought the US Foam Spec was a 1.7 ratio. Any progress with the windows mobile version? It would be awesome to be able to access this right at the track on my phone. I also am looking for an old post that some one had a rc program for setup and other things on a pda.
gonzo416 is offline   Reply With Quote
Old 06-30-2008, 10:25 AM   #35
adrictan's Avatar
What is Rollout?
adrictan is offline   Reply With Quote
Old 06-30-2008, 10:53 AM   #36
Regional Moderator
CarbonJoe's Avatar
Originally Posted by adrictan View Post
What is Rollout?
Basically, rollout is the amount the car will move for one revolution of the motor shaft. It takes in to account gear ratio(s) and tire diameter. It is obviously easier to calculate this for a 1/12 scale car (direct drive) than for a touring car, since you also have the pulley ratios to contend with on a TC. Rollout is used to help determine correct (or optimum) gearing for a given track / motor / tire size combination.
Old 06-30-2008, 10:53 AM   #37
Send a message via AIM to HenBeav
What is Rollout?
great thread resurection, this one was almost dead and you brought it back
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
Old 06-30-2008, 11:04 AM   #38
Regional Moderator
CarbonJoe's Avatar
At least give him props for using the search function like some people always tell newbies to do...
Old 06-30-2008, 02:59 PM   #39
And the ta05ms ratio is 2.25
cheers
Qatmix is offline   Reply With Quote
Old 06-30-2008, 06:32 PM   #40
adrictan's Avatar
Thanks.
Old 11-01-2008, 12:18 PM   #41
razzor's Avatar
bump !
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-28-2009, 02:17 PM   #42
Is this still available?
gezer2u is offline   Reply With Quote
Old 01-28-2009, 02:31 PM   #43
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I have an Excel spreadsheet that I imported via documents to go to my palm. You would need Palm OS to use it. From the sheet, you change your starting pinion, your starting spur (autofills the next 12), internal ratio and tire diameter and it spits out a nice table with:
Distance from Center of Pinion to Center of Spur.
Gear Ratio
Internal Ratio
Final Drive Ratio
Rollout in Inches
Rollout in Millimeters
(for each pinion)
If you want a copy, let me know.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-28-2009, 09:47 PM   #44
smilekt's Avatar
UPDATE:
Added new car "Tamiya 416"
Also i have split the program from the .Net Framework so if you are already using my program you will only have the Offline Rollout Calculator in one zip and the .Net Framework in another zip which you can download separately. (Thanks Killer)
To download the update refer to my first post or click here
If you have any errors click here to download the .Net Framework
nice ... tq very much .. very usefull
smilekt is offline   Reply With Quote
Old 03-09-2009, 04:59 AM   #45
Hey guys,
Sorry to revive this thread have been really busy this past year and haven't had much time to do anything really. Just wondering does anyone still use the program if they do i will continue updating it and make it better, i have a new idea for the whole thing taking into account all your feedback and suggestions and will also make a Windows Mobile version of the program (Now having a Samsung Omnia to test it on )
Let me know guys
Kind Regards
Adam
New Rollout Calculator and Setup Tracking dr_hfuhuhurr Electric On-Road 17 11-24-2006 01:08 PM
Rollout Calculator mike ivy Electric On-Road 4 07-14-2004 10:32 PM
Rollout Calculator Sexray Electric On-Road 3 05-15-2004 07:45 PM
Rollout Calculator Stickboy Electric On-Road 12 03-28-2004 04:09 AM
Pocket PC Rollout Calculator Software dr_hfuhuhurr R/C Items: For Sale/Trade 1 12-12-2003 10:14 AM
