Old 12-19-2007, 03:12 AM   #46
paul73rc's Avatar
Trader Rating: 5 (78%+)
Hi guys, I have ordered a Kimbrough 48P 72T Spur Gear. About AU$10. I will be picking it up from my LHS tomorrow morning. I will put it on and take it for a spin. If I get time, I will organise a cam and strap it to the car somehow and record it, lol. Have fun, talk tomorrow
paul73rc
paul73rc is offline   Reply With Quote
Old 12-19-2007, 03:13 AM   #47
paul73rc's Avatar
BTW, If I don't get to record it I will give you guys some feedback on how it went. Cheers
paul73rc
Old 12-19-2007, 03:53 AM   #48
I just did some quick maths on what you are runnin and you should have a rollout of about 32mm. I would expect to blow a 6t motor up with that rollout. your internals must be 2.125 which makes it about 27mm which is still hairy for a 6t. I would guess that your batts and motor are not in the best condition. Get yourself down to your local track and get someone to look your motor over. Epic based mods are not the best but run good at around 10degrees of timing. with the load you are putting on it I wouldn't go above that.
Dragonfire is offline   Reply With Quote
Old 12-19-2007, 04:01 AM   #49
paul73rc's Avatar
Hi there, I see you have some knowledge in electric motors lol. I am more of just a street basher, all I do is muck around, drift and go for high speeds etc. So therefore, I wouldn't know anything about the 10mm timing.
Is it fairly easy to adjust it to 10mm timing? If so, is there any sites that show you how to, because I wouldn't mind learning. Cheers
paul73rc
Old 12-19-2007, 04:45 AM   #50
paul73rc's Avatar
HI GUYS, IF I WERE TO USE A NOVAK 3.5R BL SYSTEM WITH A 48P 86T SPUR, 48P 25T PINION, 63MM FOAMIES AND A 6 CELL BATTERY IN A XRAY T1 WITH AN INTERNAL GEARBOX RATIO OF 2.125 WOULD IT REACH APPROX 120KPH? THE 3.5 DOES 10,500 RPM TO EVERY VOLT. TIMES IT BY 7.2 YOU GET 75,600 RPM. I CALCULATED IT ON THIS WEBSITE:
http://www.rcracing.com/Page.cfm?InfoID=1100
COULD SOMEONE CHECK IT FOR ME AND TELL ME IF I HAVE GONE WRONG SOMEWHERE?
THESE ARE THE DETAILS REQUIRED TO CHECK ESTIMATE SPEED:
CAR: XRAY T1
TRANNY RATIO: 2.125
SPUR: 86
PINION: 25
TIRE: 63
RPM: 75600
CHEERS
paul73rc
Old 12-19-2007, 04:54 AM   #51
Pie_robot's Avatar
Trader Rating: 17 (100%+)
Send a message via MSN to Pie_robot
do u have a t1 or an fk 05 cause they have different internal ratios.
t1 = 2.125
fk 05 = 1.70
just wanna make sure
Tamiya 415MRE- GTB +10.5- Spektrum = 19t
Tamiya F103gt - 17.5t -lipo(yah) = 2wd stock
Tamiya M03 -Spektrum - NiMh(boo)= Mini
Bodgy Brothers Racing......19t,Stock,Mini,540,2wd stock
JMP Graphics....sparkly
www.castlehillraceway.com
Pie_robot is offline   Reply With Quote
Old 12-19-2007, 04:58 AM   #52
paul73rc's Avatar
t1 = 2.125
fk 05 = 1.70
LOL, I REALISED JUST BEFORE I HAVE A T1 FK04. SORRY FOR CONFUSION. TRANNY RATIO: 2.125
CHEERS, BY THE WAY DOE S120KP/H SOUND ABOUT RIGHT I JUST THOUGHT IT WAS A BIT MUCH? CHEERS
paul73rc
Old 12-19-2007, 05:03 AM   #53
Pie_robot's Avatar
yer it would in a perfect world but the motor wont work at 100% effeciency, you also have to account for wind resistance and other things like friction and stuff
Old 12-19-2007, 05:10 AM   #54
paul73rc's Avatar
HI, DO YOU RECKON THE NOVAK 3.5R COULD HANDLE THAT ROLLOUT WITHOUT FRYING IT ANYTIME SOON? CHEERS
paul73rc
Old 12-19-2007, 11:22 AM   #55
Pie_robot's Avatar
it'll be fine esp if ur running a gtb, just make sure u check heat of motor, esc and cap and if their too hot just give it a rest. after all it will just thermal in a worse case cenario
Old 12-20-2007, 06:53 PM   #56
paul73rc's Avatar
Hi Pie_robot
I want to buy a Novak or LRP 3.5 bl setup. What is the maximum rollout you would reccomend on these setups? I was thinking about a 25mm rollout. Some people say don't go over 20mm rollout and some say max about 22. Do you roughly know what is the max rollout I should go to without frying anything? Cheers
paul73rc
Old 12-20-2007, 08:32 PM   #57
Pie_robot's Avatar
yer you should def gear it under 20, as low as possible.
but i have geared my novak 3.5 to 26 for a speed run,u have to watch out for heat esp on the cap
TI FK05 XRAY FK05 lover Australia For Sale/Trade 2 06-10-2008 07:38 PM
Xray FK05 Gav_XXXS Australia Wanted to Buy 3 07-19-2006 02:18 AM
XRAY FK05 CarissaF R/C Items: For Sale/Trade 8 06-12-2006 01:36 PM
Would you say this is overkill? californiakid Monster Trucks 1 12-30-2005 07:48 PM
