Old 12-17-2007, 05:10 AM   #1
Low_E's Avatar
Send a message via MSN to Low_E
Default tuning a pinion-diff
Hi, I'm driving a Tamiya Swift car, which is based on the M-03M-chassis.
It is Front-Wheel-Driven and has a Pinion-differential. Tamiya has a optional Ball-diff for this car but I was wondering how I could tune the original diff.
I like the fact that a pinion-diff can never slip, which a Ball-diff can.
I know a pinion-diff is used in nitro-cars, I guess for the robustness of this system. I also know that there, these diffs are tuned by using different kinds of oil in the diff, so with different viscosities.
The problem on this Tamiya-Swift-diff is, that it is not sealed so I can not use oil to tune it.
I read somwhere that someone stucked it full of grease. I tried this and indeed the diff became "stiffer" which was exactly what i search for. Unfortunatly, after some runs, the grease was swepped to the sides (and out off) and my diff was again spinning freely and very nicely.
So it is very good "lubed" but that is not what i'm looking for .
Also, I want to stiffen it, not block it. Some guys told me they filled it with silicone and therebye glued it together.
This method has three drawbacks:
  1. you end up NOT with a diff but a kinda spool (which is not what i want),
  2. this way, the Swift seems to "eat" pinions and spurwheels.
  3. This is a non-return mod.
Anyone has some tricks on how I could stiffen this diff?
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 12-17-2007, 07:05 AM   #2
Xpress's Avatar
Can't you pack the diff full of the grease you used and then silicone the gap between the cover and gear? It may help keep the grease in a little longer. Without being o-ring sealed though, I am not sure there is an absolute long term solution other than the ball diff.
Xpress is offline   Reply With Quote
Old 12-17-2007, 07:12 AM   #3
KE4PJO's Avatar
With a diff of that sort, this sounds like your best option.
KE4PJO is offline   Reply With Quote
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 11:11 PM
electric tc3 pinion and diff gears. dereklong Electric On-Road 1 07-12-2006 07:24 AM
Would switching from a 19t pinion gear to a 21t pinion make a big difference ? thahookup Rookie Zone 5 05-19-2006 01:09 PM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
diff tuning in 1/8th scale Scottmisfits Electric Off-Road 9 12-09-2004 04:51 PM
