Old 06-10-2003, 07:31 AM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default Converting Computer Power Supply. Resistors Q's
when i went down to the elctronics store to pick up some 25 watt x 8ohm resistors they said you have to special order them. but then they said that they get really really hot and you need to put heat sinks on them.
do i really need to put heat sinks on them?
http://www.magicookie.com/prodigy/psupply.htm
Calvin Ng is offline   Reply With Quote
Old 06-10-2003, 10:18 AM   #2
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
It' depend on what kind of the Resistor you ordered.
You do not need a heatsink if your using chassis mount type Resistors.
With this type of Resistor... you mount on the chassis, so the chassis will become part of Resistor's heatsink..
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 06-10-2003, 11:33 AM   #3
Registered User
Calvin Ng's Avatar
im using somethign like this
Old 06-10-2003, 07:31 PM   #4
komkit's Avatar
From the photo, I saw a bunch of a Resistor ceramic type parallel together. By parallel them Resistors together the resistance goes down but the wattage goes up.
For example, if you parallel 2 of an 8Ohm 25Watts together. The Resistance value will be 4Ohm 50Watts.
Without seeing the schematic I can’t really tell you how much current or voltage those Resistors will be handled. I guess you will have to “feel” it when you power it up with a LOAD.
Just make sure the schematic or the instruction called for 1 each 8Ohm 25Watts or a # of 8Ohm 25Watts parallel together.
Old 06-12-2003, 03:29 AM   #5
Cole Trickle's Avatar
I've done it like komkit and Calvin NG. It've worked fine for approx 3/4 year. I've placed the resistors right in front of the fan, that help a lot in keeping the temperature down.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 06-12-2003, 04:00 AM   #6
sausage_link's Avatar
Send a message via ICQ to sausage_link
i use a 1 ohm resistor, 10, and a 20 and it gives about 13.4 volts
sausage_link is offline   Reply With Quote
Old 06-12-2003, 04:10 AM   #7
WC
WC's Avatar
Trader Rating: 28 (100%+)
The PC-PS in the Magicookie article is an "AT" PSU right, not an "ATX"??
WC is offline   Reply With Quote
Old 06-12-2003, 05:11 AM   #8
komkit's Avatar
I never used the PC's pwr supply conversion before.
I just used one of this... and be done with it worry free.
Old 06-12-2003, 06:14 AM   #9
my PSU is 250 watt
and i reckon it could handle 15 amps
Old 06-12-2003, 07:24 AM   #10
Registered User
Calvin Ng's Avatar
i live in edmonton, alberta canada
does anyone else???
i cant find resistors with 25watt 8ohm
Old 06-12-2003, 06:22 PM   #11
Registered User
Calvin Ng's Avatar
now i have a capacitor question for the power supply
what kind of voltage should i be looking for with the caps?
Old 06-12-2003, 11:39 PM   #12
anything about 16 volts
a capacitor that is rated at 25 volts will do the same job as a 16 volts capacitor
but dont go under your output voltage.
Old 02-19-2005, 08:47 PM   #13
GReddy's Avatar
Send a message via AIM to GReddy
does anyone noe of any other sites that has more pics?
GReddy is offline   Reply With Quote
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
Computer power supply semper Australian Racing 79 11-23-2007 12:35 PM
Converting a PC Power supply to use with RC Charger aN4rK1 Electric On-Road 32 03-03-2006 09:11 AM
Computer power supply Losi Jet Pilot Electric Off-Road 3 06-15-2005 06:51 AM
Converting Computer Power Supply. Who got it to work? Who didnt? Calvin Ng Electric On-Road 47 02-20-2005 08:17 PM
