Best spur and pinion gear pitch >
Old 06-09-2003, 08:23 PM
jedi's Avatar
Default Best spur and pinion gear pitch
What's the best gear pitch to use for touring cars on a medium - large outdoor track? Does the 64 pitch gears really have an advantage over the 48 pitch gears aside from being able to fine tune the ratios better? Thanks a lot.
jedi is offline
Old 06-10-2003, 12:19 AM
64 pitch also has the advantage of getting stripped alot easier if tiny rocks or pebbles get logded between the gears....
johnny
Johnnytc3 is offline
Old 06-10-2003, 12:25 AM
WC
WC's Avatar
Trader Rating: 28 (100%+)
Default Re: Best spur and pinion gear pitch
re Fine tuning...
Let's assume all pinions and spurs are the same equal price each.
For a decent range say, 10x 64dp pinions and 1 spurgear.
Or you could buy 8x 48dp pinions and 3 spurs (eg 68, 70, 72) that are close together.
Do the sums and there's no change in "flexibility". Change 1 tooth on 64dp, same as change 1 pinion and change the spur on 48dp.
Same cost, and the latter would give you "spare" spurgear too.
WC is offline
Old 06-10-2003, 07:24 PM
StephenSobottka's Avatar
The 64 pitch just let you fine tuine a lot easier is pretty much all it does. I noticed it cuts down on the sound of the cars drive system too.
StephenSobottka is offline
Old 06-11-2003, 04:55 AM
its fine doing that comparison but there are some other factors to consider, usually chaning the pinion is a lot easier than changing a spur.
on my car i have to remove half the car to get access to the spur.
also 64 pitch tends to run a bit quieter than 48 but its also more likely to strip.
each has pro's and cons.
sanj
schumacher is offline
