Old 12-18-2001, 08:58 PM   #16
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
The capacitor is used primarily for MOD rather than stock. A demanding MOD can distort the digital signal. A capacitor will aid in strengthening the digital signal. Performance is increased from having a cleaner signal.
I also noticed a drop in performance when using a cap for stock. Also use smaller caps in parallel (not a series) since the smaller caps will have a lower ESR.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 12-19-2001, 12:37 AM   #17
Send a message via ICQ to JesseT
You propably mean in parallel rather than in series.
JesseT is offline   Reply With Quote
Old 12-19-2001, 02:34 AM   #18
Corse-R's Avatar
Originally posted by MattW
Any idea what values those caps that come with the worlds kit??
Not sure, but comparing with simmilar size caps seems to hold 4700mF (the big) and 560mF (the small ones), voltage not idea, but for temp rating, sure that is 105ºC (highest rating).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 12-19-2001, 04:26 AM   #19
You're right!
Parallel everyone!
V-Dezign 4.0
Old 12-19-2001, 04:30 AM   #20
Unless you run in an environment where the temperature is a concern, I know Spain can get HOT during its summer months, I would not be to concerned with the temp rating. I too have caps with that 100-110 temperature rating.
V-Dezign 4.0
Old 12-19-2001, 11:28 AM   #21
Send a message via ICQ to MattW
That was my thought as well. I suspect they may be the Panasonic low impedance series.
MattW is offline   Reply With Quote
Old 12-19-2001, 11:56 AM   #22
Rog
Signal? What signal are your referring to? Radio signal? If so, then why would the cap be soldered onto the battery wires and not the motor wires? A capacitor is used to buffer electrical current so that there are no voltage dips. These capacitors have been used in a larger scale in mobile audio for a long, long time. Capacitors buffer current so when voltage requirements become severe (like when heavy bass is being played, or full throttle from a dead stop) no dip in voltage occurs. Many people have stated that there is no effect, positive or negative, in Stock racing. However, I've found that my Quantum Competition runs much better with it on.
Rog is offline   Reply With Quote
Old 12-19-2001, 12:38 PM   #23
Rog: You solder to the battery wires. You have it right, a MOD is a demanding motor causing dips, therefore, you use caps. Not as much power is stored as thought to be, just enough to keep the signal strong.
As for the audio applications, the caps are a temporary storage for when the demand is to great for the amp and so it unloads giving the monster magnets what it needs to produce the sub-sonic sounds, sounds often felt and not heard.
I have not run across a situation where a stock motor warrants the use of a cap. I actually suffered in performance. It was very noticeable out of the turns. Once I removed the cap the burst out of the turns was very noticeable. It doesn't make since really but that is what I have experienced.
V-Dezign 4.0
Old 12-20-2001, 07:45 AM   #24
Dragon's Avatar
Send a message via ICQ to Dragon
what does a schottky diode do?...is it the same as a capacitor?
Dragon is offline   Reply With Quote
Old 12-20-2001, 08:19 AM   #25
Corse-R's Avatar
Nope, schottky and receiver cap works on the same direction but using different methods.
Schottky diodes works in the motor supressing the back off spikes caused by releasing the throttle stick and not using the brake (in this moments the motor acts as an alternator who is shorted by the act of installing the diode) producing high power spikes to the ESC.
Receiver cap works stabilizing the 5 volts supply from the esc and eliminating those high frequency ripples 'caused' by the use of high frequency ESC's.
In 'ye old days' the use of capacitors in the receiver was for eliminating glitches caused by the use of very low turn motors who cause a lower supply of energy to the receiver, acting as a little reservoir to cope with this transient situation.
Cheers,
Corse-R
Old 12-20-2001, 09:10 AM   #26
No, I don't think so. When you release the stick and you're using your motor as an alternator, the voltage it creates is still positive, but the shottky only lets reverse voltage through.
On the other hand, the speedo feeds current in pulse mode to the motor, which is inductive load. On every pulse, when the current is switched off, the motor creates a negative voltage spike that is absorbed by the shottky diode. Please correct me if I'm wrong...
Old 12-20-2001, 09:48 AM   #27
OSherman's Avatar
I have had my QComp. for several months now. Have seen others (QComp.) come and go. I guess there really are a few bad apples in every bunch. Tried the big Cap thing, but didn't really notice any difference in ESC temp. so I added a heatsink to it and haven't had one problem. The best ESC I have used to date. Still have a NOVAKtc2 in the box just in case though.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 12-21-2001, 11:58 AM   #28
Dragon's Avatar
so in simple english u mean it protects the ESC?
Old 12-21-2001, 12:34 PM   #29
Corse-R's Avatar
So in simple english u mean it protects the ESC?
Yes. In fact, I did a test with an old Tekin ESC700 (a very, very old ESC). I've fried several times the brake FET's, and since I've installed a schottky in the motor, I never fried the brakes.
Cheers,
Corse-R
LRP Quantum Competition 2.... QC2 Team Girth R/C Items: For Sale/Trade 5 06-01-2006 03:46 AM
LRP Quantum Competition Jeremy Blair R/C Items: For Sale/Trade 4 05-04-2006 07:37 AM
LRP Quantum or Quantum 2 competition Core Creations R/C Items: Wanted to Buy 1 10-03-2005 11:56 AM
LRP QUANTUM COMPETITION 2 mikep R/C Items: For Sale/Trade 6 06-30-2005 07:11 PM
LRP Quantum Competition 2 Accord Electric On-Road 14 07-30-2003 07:59 AM
