Old 12-15-2007, 05:12 PM   #1
Default cooling suggestions
TT01, Mamba Max esc, orion vortex 7.5, 8.53FDR
I believe im suffering a bit from heating issues. after a 30min run, esc hot & motor hot, but i can touch them for more than 4 seconds. I am using 2 x 25mm 3Racing fans mounted on top of the motor, but they stop spinning alot of the time.
What do you people suggest i do? I have been looking at getting 2 x 40mm 5v fans. one for the motor, & one for the esc, both directly soldered to the esc's battery tabs. I was also thinking of doing the 'hole mod' on my mamba max's base so heat can dissipate quicker.
FDR is the absolute highest i can go. and the higher the ratio the cooler the motor runs right? I also think the design of the plastic bathtub TT01 chassis does not allow for enough airflow...
Drift Demon is offline   Reply With Quote
Old 12-15-2007, 08:50 PM   #2
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
Sorry for my ignorance but you can touch them more than 2-3 second after a 30mins run I don't consider that is hot.
-KilleR- is offline   Reply With Quote
Old 12-15-2007, 11:23 PM   #3
wog....supraman's Avatar
Send a message via MSN to wog....supraman
yea, after 30mins of racing, wouldnt u expect it to be hot??
if you are concerned, get the TCS system...its xpenso, but it is supposedly really good....other than that, you could use things b4 the race to bring down the motor temps, like motor coolers and freeze spray, whether itll change the end of race temp, iunno, but itll help for the first 6-7mins or so.!
Tamiya TNX5.2R, Taniya TA05, Tamiya TB-02, Team Associated Factory Team B4, Twister CP V2, HoBao Pirate 10 MT, Tamiya TNX5.2R spare chassis x2, ebay spec submarine, HSP Rock crawler! FOR SALE!!! pm me
wog....supraman is offline   Reply With Quote
Old 12-16-2007, 08:21 AM   #4
Back off on your timing and get a temp gun.
Lazer Guy is offline   Reply With Quote
Old 12-16-2007, 08:26 AM   #5
UN4RACING's Avatar
Trader Rating: 22 (100%+)
The nature of the Mamba ESC is to be hot. SO any fan can only help. It should also help to make it more efficient.
What batteries were you running to make 30.
UN4RACING is offline   Reply With Quote
Old 12-16-2007, 09:24 AM   #6
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
best thing you can do is "not run for 30 minutes"
New to RC- Need suggestions briscoe111 Electric Off-Road 8 05-13-2008 02:25 PM
Suggestions sivob Electric Off-Road 12 02-07-2006 07:17 PM
Car suggestions Ayumi Rookie Zone 5 05-04-2005 04:13 PM
Need Suggestions for my 1st MT CAB Singapore R/C Racers 7 03-13-2005 04:17 PM
need suggestions! gspot69d Oval, Larger Scales and More 1 10-20-2004 02:08 PM
