Old 06-09-2003, 07:45 AM   #1
Default Protecting gears....
How do you protect the TC3 gears from rocks flying up from the ground? I have gotten 3 rocks stuck between the pinion and spur gears in 2 sessions.
Any ideas other than cleaning the area first?
RoadRat is offline   Reply With Quote
Old 06-09-2003, 08:55 AM   #2
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
you can use a tooth pick.
just put a peice of tape on the bottom to protect it from flying up
Calvin Ng is offline   Reply With Quote
Old 06-09-2003, 11:44 AM   #3
That will work however I wouldn't suggest it because then when the rocks come from the top they get stuck inside and aren't allowed to fall out of the bottom..... 3 times in 2 seasons isn't that bad I wouldn't worry........ Spurs should be replaced every so often even without being damaged to the point of stripping...... They are consumable items, like motors, brushes, and batteries.......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-09-2003, 12:36 PM   #4
3 times in 2 sessions....2 days, not 2 seasons. It happens a lot. At this rate, I'll be swapping out gears every week
Old 06-09-2003, 02:33 PM   #5
Sorry misread 2 sessions for seasons
there is 1 sure fire way to get rid of the rock in the spur gear blues...... all you need is to purchase 1 small upgrade kit, it's called a Losi XXX-S G+....... hey your lap times will drop too!!!!!!!
Old 06-09-2003, 05:07 PM   #6
Steevo's Avatar
Default Re: Protecting gears....
I had the same problem with my Tamiya TB Evo II.
What I did to solve it was to make a shield to protect and cover the spur/pinion area. I used the lexan from an old body that i had laying around and fabricated a shield.
I race on an unprepped parking lot with millions of tiny pebbles that at first ruined both pinion and spur after only one race.
Now I have no problem whatsoever.
If you like I can post a pic of the shield I made to give you an Idea.
Let me know if you want to give it a try.
Steevo
Steevo is offline   Reply With Quote
Old 06-09-2003, 05:35 PM   #7
Registered User
Calvin Ng's Avatar
i would like to see a pic as i would like to do something similar to my 414mII
Old 06-09-2003, 05:47 PM   #8
Thanks! I'd love to see the picture!
Old 06-09-2003, 05:55 PM   #9
Default gear protection
I put some part of a screen door that I had cut out over the gear slot and over the motor also, because a couple of times when I rebuilt my motor it had some pebbles in it sometimes
associated kid is offline   Reply With Quote
Old 06-09-2003, 07:34 PM   #10
Steevo's Avatar
OK Here's some pics of my protector.
It works very well. I think the most important area of protection on My chassis is the cut out underneath the chassis. Lots of small pebbles used to enter from here but now it is protected and trouble free.
PLEASE NOTE THAT THE PINION TEETH ARE SLIGHTLY DAMAGED BUT THAT DAMAGE OCCURRED BEFORE FITTING THE SHIELD...
Old 06-09-2003, 07:36 PM   #11
Steevo's Avatar
SECOND PIC
Old 06-09-2003, 07:37 PM   #12
Steevo's Avatar
LAST PIC
I Have used double sided tape to secure the two sides and the top deck screws secure the top..
Hope this helps some
Steevo
Protecting the paint Telnets Painting, Designs, Graphics and Photography 8 08-01-2008 08:28 AM
Protecting your chassis pracy Nitro Off-Road 6 06-23-2008 11:39 PM
Protecting your lower chassis? TGA78 Nitro Off-Road 6 07-04-2007 11:40 PM
1/10th Pan Car Setup - CORALLY C10X - Gears, Gears, Gears? paul73rc Oval, Larger Scales and More 4 04-06-2007 10:10 PM
protecting decals seasterling Painting, Designs, Graphics and Photography 5 04-04-2005 11:52 AM
