Old 06-08-2003, 06:16 PM   #1
ned911's Avatar
Default Charger Question
It is finally time to replace the old Tekin 112 A and C. Strongly considering the Integy 16x5v6 but have 1 stupid question.
Does the power supply need to produce 20 amps for the 20 amp discharge to work?
Question #2:
The tracks in Austin do not have electricity. I was thinking of getting a second battery (car or motorcycle) to run the charger, get a inverter to run the iron. Generator is out of the question. Is this how others deal with no power?
Ned
ned911 is offline   Reply With Quote
Old 06-08-2003, 07:21 PM   #2
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Default Re: Charger Question
Question #2:
Ned
No, you don't need to have a 20amps pwr supply to DISCHARING at 20amps. The capacity of the pwr supply only effect how much you can CHARGE.
Deep cycle (marine battery) or RV's battery is what you are looking for. Motrocycle's batt is too small.
I don't know how many packs you will be charging when you are out there.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 06-08-2003, 09:20 PM   #3
ned911's Avatar
Komit - thanks for the reply. We usually run 2 heats and a main. So 4, 5 packs max.
Ned
Old 06-08-2003, 11:17 PM   #4
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
hey man, not sure who you are in austin, but im in san antonio. Neways, to the point, he was asking how many packs at one time, or at least i think he was, not how many total in the night, an RV battery is very large, very heavy, but holds A LOT of power. One guy that I sometimes race offroad with will bring his out, and me and him and a total of three chargers on it charging almost all the time, and I dont think he charges that thing but once a month if that, so you'll be good to go man
=MisFitz= NuKe is offline   Reply With Quote
Old 06-09-2003, 12:16 AM   #5
How can you charge a car battary or an RV battary? In a real car when you run the car it charges the battary, but how could you charge a battary when it's not in your car?
racerdx6 is offline   Reply With Quote
Old 06-09-2003, 06:22 AM   #6
evaa's Avatar
[QUOTE]Originally posted by ned911
[B]It is finally time to replace the old Tekin 112 A and C. Strongly considering the Integy 16x5v6 but have 1 stupid question.
nope, u dont need a poer supply that's commensurate with the rate ur discharging. i use a 6amp power supply for my 30 amp orion digital discharger. i also tried hooking up my pulsar, lrp micro charger and the discharger on my 12 amp power supply still did not experiance any problems, not even a false peak on both chargers.
hope this helps.
evaa is offline   Reply With Quote
Old 06-09-2003, 08:31 AM   #7
ned911's Avatar
Thanks for the help. The most I charge now is 2 at a time (Both Tekins running).
Running the soldering iron full time was my initial concern.
MisFitz - I'm new to the Austin racing scene. Previously I've run at Mike's in DFW, Small Cars Unlimited in Jackson, MS and SRS in Phoenix. Back after a 2 year break, and my batteries show it. Got laughed at for running 2400's but finished second in TC (no Toastie, Atomic or David).
Ned
Old 06-09-2003, 08:38 AM   #8
komkit's Avatar
Same way we charged our R/C pack - we bought the charger that were made for NiCd or NiMh.
Instead of buy the charger that made for R/C - we go out and buy the charger that was made for Deep Cycle or Marine batt and charge them at the house. Assumed that you have an AC outlet where you live.
Old 06-09-2003, 04:36 PM   #9
How much does a charger for a car battary cost? Where can you buy them at? I didn't know you could buy them. Also, how much does a car battary it self cost? Thanks.
Old 06-09-2003, 05:28 PM   #10
ned911's Avatar
Car battery chargers are available at any autoparts store. This is what I originally used as a power supply for my first Tekin (BC100).
Usually takes over night to recharge a car battery.
Ned
Old 06-09-2003, 07:30 PM   #11
komkit's Avatar
Yes, ned911 is pretty much on the money. You can buy them both (batt & charger) at the automotive part store.
If you are in U.S. Sears got some nice Deep Cycle batteries and a selections of a charger. The only thing to watch for is make sure if you are buying a Deep Cycle or Marine battery you must buy a charger that capable of charging a Deep Cycle battery.
Sealed car's battery is okay. However when you left it charge overnight just be very careful.. While charging the battery can release some gases (nitrogen)... and that could be fatal and not to mention KA-BOOM!
Just make sure you are charging the car battery in very well vented area.
Old 06-09-2003, 07:53 PM   #12
Old 06-10-2003, 01:47 AM   #13
Matt04's Avatar
i have a question about chargers. would it be worth buying a cdc charger so that i could charge nimh batteries so i can run 3000 in my car?
Matt04 is offline   Reply With Quote
Old 06-10-2003, 04:19 AM   #14
Carbon_Fibre3's Avatar
yes matt, the cdc chargers are unbeleivbaly cheap from hk atm..
and they do most things u ever need.
my fav charger
Carbon_Fibre3 is offline   Reply With Quote
Charger Question Evilstealth Electric On-Road 1 01-29-2007 03:29 AM
charger question peanutbrains Nitro On-Road 9 08-22-2005 09:34 AM
Charger question RedBullRacin Rookie Zone 5 01-16-2004 01:36 AM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Charger Question Motorsports00 Australian Racing 33 10-13-2003 01:14 AM
