Stirring the Battery Cauldron >
Old 12-13-2007, 11:50 AM
Mason's Avatar
Default Stirring the Battery Cauldron
Toshiba with a new battery claiming 90% charge in 5 minutes... comes out in march. wonder whats in it..
http://www.dailytech.com/Toshiba+to+...ticle9984c.htm
Mason is offline
Old 12-13-2007, 01:08 PM
billjacobs's Avatar
Trader Rating: 65 (100%+)
Default new batteries
Recharge in 5 minutes at 50amps, I wonder if you get higher voltage with a 70amp charge? Just a quick question, who will produce a 50 amp charger?
billjacobs is offline
Old 12-13-2007, 01:09 PM
Trader Rating: 19 (100%+)
Look like there will be a run on 75a power supplies.
Advil is offline
Old 12-13-2007, 01:32 PM
Mason's Avatar
http://www.toshiba.co.jp/about/press/2007_12/pr1101.htm
toshiba's release on it.. 2.4v/cell sounds like my 12th scale solution! lol
Mason is offline
Old 12-13-2007, 02:43 PM
billjacobs's Avatar
Default new cell
each cell is 150grams and 2.4v, so 2 cells is 300grams=10.5oz (about the same as 4200 nimh.)
The size of the cells is 62x95x13mm whereas 4 cell nimh is 44x90x23mm.
Stacking 2 cells would be close in size (vertically, and length wise) to a 4 cell nimh but they wouldn't fit into any current 1/12 car. Stacking 3 cells would be 7.2v, but would also be wider and higher than nimh. When compared to lipo, these cells are more robust, but they are also almost twice the weight.
As long as the cells are cheap, they have potential.
