Old 12-04-2007, 06:51 AM   #1
part-time racer's Avatar
Default Foam Selection?
As the title would suggest, I am keen to understand what is considered to be the best foams to be used in 1/10th ep in-doors?
Also, in the past I have had good results from the TRC range but I can't remember what hardness was used.
Thanks in advance.
Richard Clarke.
part-time racer is offline   Reply With Quote
Old 12-04-2007, 07:09 AM   #2
AdrianM's Avatar
Nowadays we are running Double Pink or Magenta all the way around. Make sure to use the latest 53mm diameter wheels from Jaco, BSR or Parma.
Adrian Martinez
Old 12-04-2007, 09:06 AM   #3
You run the same hardness front and rear?
I used to use a soft foam on the back and a harder foam on front.
Old 12-04-2007, 11:56 AM   #4
I run GRP 28mm's with my Mini--works good for me
bowl806 is offline   Reply With Quote
Old 12-04-2007, 01:08 PM   #5
AdrianM's Avatar
We used to run foams with a ring of orange on the outer edge but the main compounds were the same front and rear.
All of the current setups are for same compound all around and the cars are just as easy to drive (or easier) than before.
Adrian Martinez
Old 12-04-2007, 01:22 PM   #6
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Look into the Jaco Prism or Parma Pro 53 foam tires. Like Adrian said, depending on setup and track conditions, magenta or double pink all the way around. You don't need the double pink/orange fronts.
Anthony.L is offline   Reply With Quote
I need some help with my selection ModmannLevi Electric On-Road 2 06-05-2008 08:05 PM
Car Selection Help Topher Australian Racing 20 04-19-2005 10:10 AM
rim selection beetlebz Electric Off-Road 2 09-01-2004 10:52 PM
Help with Car Selection.... jhigga15 Nitro On-Road 20 05-19-2004 06:00 PM
Foam Tire Selection for TC3, questions Cain Electric On-Road 9 03-16-2004 07:10 PM
