Old 12-03-2007, 09:58 PM   #1
Trader Rating: 38 (100%+)
Default help w/RDX gearing please
hi all ok i have a RDX that i'm looking to race, it has a 78 spur gear, NOW what pinion should i use, i'm used to setting up a car to a XXX-S and i don't think a 32 tooth pinion will work it drops the gearing to 4.35 about , anyway i'm running carpet stock motor i just need a starting point,
PS everytime i try to do a search my computer says errror,, so sorry if its a repost ,, thanks jon
waytoofast is offline   Reply With Quote
Old 12-03-2007, 10:03 PM   #2
Jeff Brown's Avatar
I would start with a 24 tooth pinion if you are running Rubber tires. If you are running foam tires I would go up one or two teeth. You will be in the ball park with those pinions. Of course the size of the track may change it more. If you are running on shorter than 90 ft straight I would gear down to maybe a 22 tooth for Rubber tire. Especially on tight and technical tracks.
Remember that the internal drive ratio changes from car to car usually. The RDX uses a 2 to 1 ratio. So it would be Spur / Pinion x 2.
Jeff
Jeff Brown is offline   Reply With Quote
Old 12-03-2007, 11:13 PM   #3
Jeff
ok this is the part i don't get :-(
thanks jon
Old 12-04-2007, 08:34 AM   #4
tc3team's Avatar
Most guys will describe the gearing in final drive ratio as its easier for anyone to calculate on their own chassis what gearing to use, because the gear ratio of the chassis will vary depending on what chassis you use. Mine for example is 2.25.
So you can use any combination of spur gear and pinion gear to get the same final drive ratio.
hth
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 12-09-2007, 08:29 AM   #5
Default I'm in the same boat
If I read Jeff's reply right, I should be starting with a 22 Pinion and a 48 spur gear. I will be running rubber tires on cement on a 50x55 foot track. Is this a correct assumtion?
Chinewbie is offline   Reply With Quote
Old 12-09-2007, 10:12 AM   #6
Jimmy Morris's Avatar
Are you running a RDX chinewbie? With rubber tires running stock or 19t, I either have a 23, 24, or 25 tooth pinion with a 78 tooth spur gear(stock spur). the RDX has a 2.0 internal ratio. so you take 78 tooth spur and multiply that by the internal ratio which is 2.0. You get 156. then take 156 and divide the pinion, lets say 24 tooth pinion, and you come up with 6.5 final drive, which is a good starting point for a co27 or a komodo dragon. You will need to go up or down depending on your track size. Gear so your car maxes out slightly before the end of the longest straightaway. Now if your running brushless...then I have no idea how to gear those things. All you need to remember is spur x internal divided by pinion.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 12-09-2007, 04:30 PM   #7
Red face I will be running brushless.
Jimbo,
Thanks for the reply. I haven't gotten my kit yet, but I want to have everything "in-house" when I get it. I ordered a Novak 5.5 brushless motor to in the Phi. I will keep looking for the correct pinion gear.
Thanx.
Old 12-09-2007, 05:57 PM   #8
Default ok ok ok
ok something is not right ,, i raced today, and i was running a co27 with a 25 pinion and a 78 spur , well i go that motor up too 255 degrees. then i put another co27 in it and and changed the pinion to a 22 tooth, well i was getting run over in the straightaways , so then i put a 24 tooth pinion on that same motor and i got about 4 mins out of it and it started smoking then i hit it with a temp gun and it was at 360 degrees, so i just changed the motor to a monster stock and put a 22 pinion and finished the main (last) but finished it, so what do i do from here ? thanks JON :-)
Old 12-09-2007, 07:55 PM   #9
Make sure you don't have a blown bearing binding your drivetrain. How big is your track? Do you have the stock pulleys or optional small pulleys?
Old 12-09-2007, 08:26 PM   #10
Default hey
that was the first thing i did the bearings are fine and there ceramic, the track is kinda big i race in stocktonrcracing.com i changed the spurr toa 64 pitch tonight 106t and i added a 31 tooth pinion, and i'll see what it can do at the next race :-) thanks for your help, JON
Old 12-09-2007, 08:45 PM   #11
That will put you at a 6.8 final. I would go to a 33 pinion for rubber tire. that puts you at 6.4 final. You are racing rubber tire correct?
Old 12-09-2007, 09:30 PM   #12
hey there yes i am RP30 , i will switch to a 33 tooth pinion ,, are you a sponcered driver ? i need parts, i cant get them anywere around here, and the last parts i ordered over a week ago i still have not gotten them ,, ok well thanks for the help JON
Old 12-09-2007, 10:11 PM   #13
superiorhobbies.com will have all the parts you need.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
