Old 12-02-2007, 10:40 AM   #1
bvoltz's Avatar
Trader Rating: 44 (100%+)
Default Calling on Brushless experts... I need help...
I have searched and searched but I'm not finding the answer to this one...
I have a Sphere 2007 ESC, and connected to it is a LRP X-11 4.5.
What I can not get this motor to stop doing is cogging... and most of the time it does not work.
Here is what I have learned after many hours of playing with this. One, you must set the mode on the batteries, this is very confussing to me but if you do not the ESC will lock into brush mode. How do I tell this you ask... Because when you pull the trigger the leds on the ESC will be in red on a brushed motor and leds are amber on a brushless motor...
You must have a freash charged battery. Less voltage, less likely to spin the motor.
I think the problem is the motor, because we dropped in a Novak 3.5 and everything work fine... go back to the X-11 4.5, and cogging... the preformance is less then a stock motor....
Just so you know I purchased the motor new... not used.. and on top of all this the first ESC was bad, so I purchased this 2007.
Any ideas what to do next? Or do I send it back to LRP to replace? I have no problem purchasing a 5.5 but if the X-11 motors have issues, I will move over to Novak motors. I want to find out if it is just this motor or a known problem with the X-11 motors...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 12-02-2007, 10:50 AM   #2
Tech Legend
Wild Cherry's Avatar
Try cleaning the sensor first ...
Sometimes oil or grease from the bearing can get on it and this can cause your problem....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 12-02-2007, 10:57 AM   #3
bvoltz's Avatar
will do... I will let you know if this corrects the problem....
Old 12-02-2007, 02:13 PM   #4
zapmike's Avatar
what i did in the same situation last year was buy a new motor, and send the faulty one back. Its a pain but you and I arent the only people who have had to do this. if you think about it this way, when u get the new one back you might want a different 5.5, or a 7.5 or something, and its usually easy to trade a new one for the other one u wana try. also, lrp is really good about customer service, but of course nobody likes to have faulty electronics out of the box, but they will take care of you. just my 2 cents
Mike
zapmike is offline   Reply With Quote
Old 12-02-2007, 02:22 PM   #5
bvoltz's Avatar
Cleaning it is did not work...
I have no problem with returning it. I just wished the local LHS had LRP product, so I could pickup a 5.5...
Just wanted to make sure it was the motor and not something I'm doing...
Old 12-02-2007, 03:03 PM   #6
replace the sensor cable.
If it works fine with the novak motor, your speedie is safe, it either the lRP motor or the sensor wire.
Besercoe is offline   Reply With Quote
Old 12-02-2007, 04:34 PM   #7
first - did you try to do the setup from the esc again? (this is not changing the throtle modes)
second - How do you clean the motor?
Third - The motor is new? Whats the gear ratio?
jorgesimes is offline   Reply With Quote
Old 12-02-2007, 04:37 PM   #8
syndr0me's Avatar
Trader Rating: 32 (100%+)
Try putting a shim on the pinion end of the rotor. If the rotor is too far from the Hall effect sensors, they won't pick up its magnetic field and the motor will cog.
syndr0me is offline   Reply With Quote
Old 12-02-2007, 05:01 PM   #9
bvoltz's Avatar
Did that and same thing with the motor...
Old 12-02-2007, 05:03 PM   #10
bvoltz's Avatar
Many times, what I found is that I had to set the profiles first then the setup of the ESC...
Motor spray completly disconnected.
New out of the box.
Old 12-02-2007, 05:04 PM   #11
bvoltz's Avatar
Ok, will give this a try...
Old 12-02-2007, 05:08 PM   #12
syndr0me's Avatar
It's possible that one of the sensors is just bad. I had that happen with my LRP 13.5, which is now off for repair.
Old 12-02-2007, 05:17 PM   #13
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I know I had a sensor go south in a Novak waaay back and it just wouldn't start if it was near that particular position. If you turned it at all (so a different sensor), it go go just fine, but if it stopped there, it wouldn't go.
Turbo Joe is offline   Reply With Quote
Old 12-02-2007, 09:17 PM   #14
bvoltz's Avatar
Well.. I think this motor is bad, so off to AE tomorrow...
Thanks to everyone for the help and tips to check next time this happens...
Old 12-02-2007, 10:36 PM   #15
Tech Legend
[QUOTE=bvoltz;3930233
[/QUOTE]
instead try .....
remove rotor from can .....
use a "Q-tip" on the inside of the hall effect sensor ...
George W. Cherry
Calling all speed control experts.............. Taylorm Electric On-Road 11 05-13-2007 10:14 PM
Need your experts advice TruckBasher Monster Trucks 13 09-13-2006 11:05 AM
Help from the experts speed6 Electric On-Road 11 07-27-2005 05:12 PM
FT B3 experts out there? Turbo Joe Electric Off-Road 7 01-08-2005 11:33 PM
OK experts... dpaton Painting, Designs, Graphics and Photography 8 10-04-2003 04:44 PM
