Old 12-02-2007, 08:34 AM   #16
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by ApexSpeed View Post
Not necessarily. MIP produced a gear diff unit for their RC10 pre-"Stealth" gearbox about 20 years ago, and they are fairly light and very reasonable for electric cars. IMO, they were the best diffs ever made for dirt oval racing. Freer and smoother than any ball diff I have ever built, and zero slip. Who says they'd need to be filled with fluid to work properly?
It CAN be done—it's been done already. With the materials and manufacturing technology we have today, there is no reason why it couldn't be an option.
There is one in this car...
Damn I had one of those transmissions back in the day and a few of those old Checkpoints. Damn those motors where fast back then to.
ST Racing Concepts (STRC)
wyd is online now   Reply With Quote
Old 12-02-2007, 08:48 AM   #17
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Originally Posted by PitNamedGordie View Post
Not to get off topic but check out that vintage Checkpoint motor with the aluminim endbell. cool!
Sidebar... dig this. Just a few.
On topic. Gear diffs =
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 12-02-2007, 09:13 AM   #18
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
WOW You are really bringing me back!!! Those were the days when I was first bit by the RC bug. I was 15 and now I'm 35 My friend had a gold tub RC10 with the black and gold labeled Checpoint just like that. I had a Twister motor just like the one you have ! I always want a Cam motor...I used to think they looked cool
OK back on topic....
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-02-2007, 09:23 AM   #19
AdrianM's Avatar
An open gear diff has ZERO limited slip effect. If one wheel loses traction that end of the car loses all forward drive. That slows you down a lot. That is why no one that was fast at the time used the MIP gear diff and it was discontinued.
I run an Mi3 and I have friends that run everything else so I have seen this first hand.
The oils (even really light oils) in nitro gear diffs keep some drive going to the loaded wheel.
I don't know why this thread is still alive. All of the current sedans have awesome ball diffs (except the Cyclone) that last forever if built properly and put in a car with a decent setup that does not lift wheels all the time.
Adrian Martinez
Old 12-02-2007, 09:31 AM   #20
squarehead's Avatar
Says you. Many of the fastest dirt oval racers in the country used and coveted that diff for a long time. It was discontinued because it wore out without any slip, it was costly to replace/repair, and you could build and service a cheap ball diff for a lot less money than produce and manufacture tiny hardened spider gears and complex center gears.
Just because you don't think it's a reasonable idea doesn't mean it isn't worth pursuing, Adrian. I suppose everyone should just stop developing everything because it's already been done before, and a better mouse trap can't be made.
Geesh.
Everything depends.
Nothing is always.
Old 12-02-2007, 09:32 AM   #21
JKA
Its alive because gear diffs offer a level of tuning accuracy and consistency that ball diffs do not. Plus the average racer would be able to more closely apply a "pro" setup to their car. With ball diffs that part is all guesswork.
JKA is offline   Reply With Quote
Old 12-02-2007, 09:50 AM   #22
Skiddins's Avatar
Originally Posted by protc3 View Post
It has been done many times but to get the full benefit from a gear diff,you want to tune with fluids like you do in 1/10th and 1/8th nitro. You can really manipulate the handling of a car this way. I am all for trying it out and to be honest,they will function better. I am just not sure how hard it would be to market being that it will need to be beefed up like a 1/10th nitro diff to handle the pressure of thick fluids
Surely there is someway of using Delrin or Nylon (or some 'self lubricating' type) gears in a sealed unit.
Perhaps a sprung pair of gears with something behind them for the spring to push them against, a bit like a full size LSD or Posi-traction?
No need for oil, the only metal part 'inside' would be the spring.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-02-2007, 09:53 AM   #23
razzor's Avatar
This would be a great idea seeing how the mod guys burn out diffs with there brushless setups
Id go for reliability any day and the fluid filled gear diffs give you a good consistent feel and tunability that is hard to get from a ball diff.
The weight is so small a difference but the benefits would be much more especially with the power of brushless and new battery technology etc....
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 12-02-2007, 09:56 AM   #24
razzor's Avatar
Skiddins
You could exactly that with various thickness orings behind the bevel gears in current gear diffs just replace them regularly or get teflon shims of diffferent thicknesses made up for them.
Casterracing ZX1.5R
Old 12-02-2007, 10:34 AM   #25
protc3's Avatar
Skiddins
THe purpose of the fluids is not for lubrication. What it is for is controling the traction at each given end of the car. Harder up front oil will yield more on power steering as like a spool. It is really nice to have. I would love to see it happen. If everyone would buy it, I think it would be better than a ball diff. The ball diff is limited to the amount of adjustment you have as opposed to a gear diff. Back in the day of the old blackfoot,frog and cars of such had weak gear diffs. You take a Xray NT1 style gear diff and that would be DIALED!!!
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-02-2007, 10:35 AM   #26
protc3's Avatar
The sweet thing about using oils is that you can rebuild your diff 1 time a year if you like. They last really long.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-02-2007, 11:18 AM   #27
I used the gear diff last weekend at the Xceed Race in the Netherlands.
Drives very well and no need to rebuild.
Times were faster with the Gear Diff.
Some other Serpent Drivers used it.. everyone with different thickness oil preferred to their driving
Rob Janssen
- Team Serpent Nederland - S400 -
robjanssen is offline   Reply With Quote
Old 12-02-2007, 11:37 AM   #28
Skiddins's Avatar
I understand exactly what your saying , I used to run 1/8 Buggies.
Perhaps the spring inside could be changed for different tensions?
Maybe this helps illustrate what I mean a bit more;
I'd certainly get a geared diff is one was available for the Mi3 and play around with it to see what a difference it made.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 12-02-2007, 11:45 AM   #29
protc3's Avatar
Skiddins
Isnt that a torsion diff?
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-02-2007, 12:11 PM   #30
JayBee's Avatar
Trader Rating: 31 (100%+)
My Mi3 diffs;
HD Spool - 21.3g
Ball Diff - 24.3g
One Way - 27.5g
Over 6g difference between a spool (the heavy duty one) and the One-way, and no-one bothers to think about the difference in weight between those two when setting up their car.
Skiddins
Good point Skidmar...oops, I mean Skiddins j/k
I would definitely be willing to have something like this for my MI3. This would take ALOT of the mysticism out of the diff-building process. I couldn't care less about the drivetrain being 7-10grams heavier. With the power of Brushless motors coupled with Lipo.....c'mon
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Mini Inferno Full Metal Gear Diffs*NEW* jla8874 R/C Items: For Sale/Trade 5 03-24-2009 05:02 PM
Metal Gear Diffs - Which vehicles. oXYnary Micro and Mini Scales 2 09-11-2008 12:30 AM
How do you guys clean your gear diffs? wstuart Nitro Off-Road 7 07-05-2008 01:15 AM
Savage 25,4 gear diffs,wing for sale or trade!! jtracker R/C Items: For Sale/Trade 3 06-14-2006 08:45 AM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 04:43 PM
