Old 12-05-2007, 09:04 AM   #31
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
Originally Posted by HB Moose View Post
Let me go check...
IB4200 with Deans 450g. Orion 3200 lipo with Deans 210g. So you need 240gs of weight. Maybe just run a second lipo
PS. IB3800 weights 423g so you can save a few grams if you don't need the run time.
Thanks moose,
Im planning to go race carpet in stockton this weekend and was going to try lipos out...
King of B Main is offline   Reply With Quote
Old 12-05-2007, 04:30 PM   #32
Originally Posted by speedsterblade View Post
I got a antique... ftTC4. Anyone still running this chassis, lol and tried any lipos?
I have a TC4 with a BMI chassis. Orion 3200 fits almost too well, it slides around a lot. I played with the AE battery strap but never really liked the way it worked. I have sinced moved everything over to my T2.
jiml is offline   Reply With Quote
Old 12-07-2007, 05:17 PM   #33
idbdoug's Avatar
Trader Rating: 33 (100%+)
2 Questions for you:
1. Did you try the 3200 Team Orion battery in the TT01?
2. Will the stock speed control handle the voltage of an Lipo or did you have to switch speed controls?
Thanks for any further information
idbdoug
idbdoug is offline   Reply With Quote
Old 12-10-2007, 05:31 AM   #34
academygaz's Avatar
Answered via PM.
Any more for the list?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 12-10-2007, 08:12 AM   #35
speedsterblade's Avatar
Yeah, I ended up taping it in and I put in some firm foam to kinda shim in the pack so it could not slide or wingle at all. I also sanded/rounded the edges of the top plate as it rubbed off some of my heat shink in a crash. We don't really force any big restriction/weigh limits etc. but the 3200 balances out my car almost perfectly. ..so I dropped 250grams! Lipos are the way to go! I will never buy another nimh pack. Put one run w/ this pack in the B4 and it's now a lipo ride also.
speedsterblade is offline   Reply With Quote
Old 12-10-2007, 05:07 PM   #36
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by academygaz View Post
I'll get some pics of my Orion 4800 and Mi3 tomorrow, but with the shorter centre track rod, the pack sits closer to the centreline of the chassis and the negative terminal is open, but sits very close to the RH bulkhead.
The track rod comes as a pack of 7, all different lengths and ackerman positions, I just used the one thats the same spacing as the original, but shorter to move the post forwards. The part number is "U3135 Centre Track Rods; Set 7 - Mi3".
If anyone wants to use the list compiled in the first post on your own forum or website, it'd be easier to just link back to this thread instead of copying & pasting, as this list will keep getting updated.
academygaz: thanks! will eagerly await the pics. i actually tried simulating the fitment using the standard track rod. i just mover it forward on hole (fo course it hit the front pulley but that was aboviously gonna happen) then checked how the fitment would be with the steering assembly moved on hole forward. yes you are right, it will move the pack very close to centerline and the negative terminal will clear the rear bulkhead (just barely though). time to get hold of those optional track rods. but still would like to see you pics if its not too big a problem to do so. thanks again and thanks for the part number too!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 12-11-2007, 03:17 AM   #37
academygaz's Avatar
Some nice dirty pics :
Connectors out, it runs close to the pinion without touching it.
Negative connector in, it does touch the bulkhead but there's another 2mm before the the pinion touches the pack so I usually take some time spacing it when I tape it in.
Shorter centre track rod.
Full right steering lock with the pack in, doesn't touch the CTR.
Old 12-11-2007, 05:13 PM   #38
TryHard's Avatar
just adding some pics of what I've done to my 3200 pack to get it to fit in my 415 MRE (this will also apply to a MSX, MSXX, and MSXX MRE 07)
I just lightly dremmelled the case in two spaces to aid clearance. The one on the back edge of the pack is deffiently required. The other (under the bulkhead "hump") isn't really required to fit properly, but it sure makes getting the pack in and out easier.
And yes, I could have dremelled the bulkheads instead... but I couldn't bring myself to cut into the blue!
regards
Ed
LiPo fitment thread-dscf0047.jpg   LiPo fitment thread-dscf0048.jpg   LiPo fitment thread-dscf0049.jpg
| THard.co.uk | Xray | MuchMore |
Old 12-11-2007, 07:45 PM   #39
RandomFellow's Avatar
Chassis used: Tamiya TT-01
Battery used: Orion 3200
Mods needed: None
RandomFellow is offline   Reply With Quote
Old 05-06-2008, 03:29 PM   #40
pH2
pH2's Avatar
Send a message via Yahoo to pH2
Default T2 008 with 3600
Is anyone running a T2 008 US with a Orion 3600, if so what modifications were required?
[SIZE="1"][B]-=pH2=-[/B]
[color=#676767]=================================================
Xray T2 '008 -- Novak GTB - 17.5 -- Orion 3600 -- Spektrum DX3R [/color][/SIZE]
pH2 is offline   Reply With Quote
Old 05-08-2008, 08:25 PM   #41
trailranger's Avatar
Chassis used: Xray T2
Battery used: Reedy 5000
Mods needed: Remove Plastic Battery nubs off chassis. Mill off nub on bulk head. Use (11) spacers under rear bulkheads. Use (4) spacers under the front of graphite brace. Use (1) spacer above the bearing for the upper steering bellcrank.
I used HPI .75mm spacers but 1mm Xray or even washers would work well.
trailranger is offline   Reply With Quote
Old 05-08-2008, 10:27 PM   #42
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Chassis used: Tamiya TA-05MS
Battery used: Orion 3600
Mods needed: battery tends to touch the center pulley rod. To remedy, you can cut a couple of pieces of lexan and double tape it to the centerline -- serves as a stopper for the battery so it doesn't shift towards the pulley rod while running. the stick pack conversion set (J-parts) for the 415 MSX might work as well.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-10-2008, 12:33 AM   #43
Suspended
403forbidden is offline   Reply With Quote
Old 05-10-2008, 08:31 AM   #44
Warren Weaver's Avatar
Trader Rating: 47 (100%+)
core 5000 in losi jrxs type r no modifications it fits good.
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 09-06-2008, 12:13 PM   #45
guinnes.s's Avatar
TRF416 with YR3600 perfect
guinnes.s is offline   Reply With Quote
TrueRC Lipo 10C and 15C 8000mah Lipo Fitment in RC10T4 or XXXTCR Cain Electric Off-Road 2 09-09-2008 08:14 PM
TRF415 Lipo Fitment Dorikin Electric On-Road 12 03-13-2008 08:16 PM
What 2wd buggies have no issues with lipo fitment Cain Electric Off-Road 17 01-03-2008 09:17 PM
Mini t and 11.1 lipo fitment ?? Gen Micro and Mini Scales 2 11-08-2007 05:38 PM
MaxAmps Lipo Thread!! omaharich Electric On-Road 89 08-17-2007 11:52 AM
