Old 11-29-2007, 06:21 PM   #1
Kyle 2.5RS's Avatar
Default Final Drive Ratio's + TA04
Hey, I just purchased a Tamiya TA04S that has basically been hopped up to R status... anyways, I'm looking to get into racing indoor on-road, but I'm a total RC newb when it comes to advanced car building like this. I need to get some pinion gears, and maybe a couple spurs depending on what I need.
Basically, what I'm looking to know is are there standards in racing that everyone runs the same gear ratio?
if so, what is fairly typical for indoor road courses?
I know the internal transmission ratio of the TA04 is 2.123, and the spurs I currently have are 48 pitch 90T, 83T, and 64 pitch 96T, and 128T. I only have a 48 pitch 19 tooth pinion, and need to get some others to make the final drive I want.
I ordered a 39 tooth pinion to go with my 128 that will give my car a final drive ratio of 7:1 according to the calculation (spur/pinion x internal ratio).
That may not be good for racing though, I really don't know.
What ratio should I have for a road course, and what may be some good combinations to get it. Probably should use 64 pitch?
I appreciate any info to help me get this bad boy going
Thanks,
Kyle
Kyle 2.5RS is offline   Reply With Quote
Old 11-29-2007, 06:27 PM   #2
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
try http://www.gearchart.com/index.cfm?f...n=chart.create
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 11-29-2007, 06:44 PM   #3
Kyle 2.5RS's Avatar
Originally Posted by surrealmaterial View Post
I did get a gearchart made, and can see lots of combonations... but I'm also looking for info on what are common final drive ratios to run when racing indoor tracks.
Is 7:1 too much?
Old 11-29-2007, 06:59 PM   #4
Branden Moody's Avatar
it depends on what motor your running a monster or co27 stock motor runs around a 7.5 to 7.6 range and a epic x stock goes 7.6 to a 8.0 for a indoor technical track. hope this helps
Branden Moody is offline   Reply With Quote
Old 11-29-2007, 07:11 PM   #5
Kyle 2.5RS's Avatar
im running a revenge of the monster 27 turn stock motor. So maybe my 7:1 ratio wont be too bad then.
Old 11-29-2007, 07:24 PM   #6
yea that should be good. good luck
Old 11-29-2007, 07:31 PM   #7
That ratio should keep motor wear down to
and welcome to rctech
Final drive ratio Starteur Electric On-Road 2 02-04-2008 07:33 PM
Final Drive Ratio on TRF 414 Arun Electric On-Road 8 03-03-2004 04:28 PM
Final Drive Ratio ??? FlyinGT Australian Racing 3 02-29-2004 12:06 AM
Hpi Mt Final Drive Ratio??? True R/C Racing Electric Off-Road 0 02-28-2004 11:10 PM
Final Drive Ratio Pandora's Box Electric On-Road 6 08-07-2003 02:13 PM
