Old 11-28-2007, 05:28 PM   #1
Branden Moody's Avatar
Default fk05 suspention binding
Hi I have a FK05 front suspention binding. I have noticed it and have taken every moving part and reamed it out but I still have the binding. I have tried every thing. please help.
Branden Moody is offline   Reply With Quote
Old 11-28-2007, 05:30 PM   #2
Trader Rating: 45 (100%+)
Did you make sure the hinge pin is not bent?
Apex is offline   Reply With Quote
Old 11-28-2007, 05:38 PM   #3
yes it is only when the camber link is on the car it binds the a arm and c hub move fine. i have no clue what is going on. its also a slight bind but noticeable.
Old 11-28-2007, 07:41 PM   #4
chris moore's Avatar
Trader Rating: 88 (99%+)
I've had that happen also, replace the plastic camber link cup/ball joint part #302662. Mine was the one on the bulkhead that got tight, you'll have to check to see which end is tight and not moving freely.
Chris
chris moore is offline   Reply With Quote
Old 11-29-2007, 11:29 AM   #5
thanks Ill try that when I get home,
Old 11-29-2007, 06:55 PM   #6
aaaaaaaaaaaaaa I cant find out what is wrong with it all ball ends are fine the cvd isnt bent the last thing is to check the hinge pin on the A arm again.
Old 11-30-2007, 07:09 AM   #7
Skiddins's Avatar
Check the hinge pins by letting them roll slowly along a piece of glass or a mirror, any slight deformity will show up far easier.
Does the suspension on those use 'quik clips' or similar?
It might be that the end of the A arm is being pinched between the pivot blocks, might require some filing to be done to the A arm.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-30-2007, 08:05 AM   #8
panther420's Avatar
Have you checked where the cvd goes into the diff? Does the cvd slide in and out easily?
You also might want to take it apart and put it back together 1 piece at a time...Put the A arm on and see if it moves freely.. Then the c hub.. then knuckle.. etc...
Mike Monteiro
Full Throttle Motorsports / www.teamfullthrottle.net
TQ Cells / www.tqcells.com
BSR Tires / www.bsr-racing.com
panther420 is offline   Reply With Quote
Old 12-01-2007, 05:52 PM   #9
i figured it out the plastic cvd cover is sanwhitched thanks for all your help!
RC Air Suspention.... khock Malaysian R/C Racers 6 05-14-2008 09:24 PM
looking for kyosho evolva rear suspention holder7mm/3.5in moy R/C Items: Wanted to Buy 0 12-14-2007 11:44 PM
Revo Suspention Configuration. The best? jatoman1992 Nitro Off-Road 3 12-13-2007 06:55 PM
xxx cr rear suspention on a xx4 Dougg Electric Off-Road 3 03-26-2007 01:54 PM
1/8 Scale Progressive Suspention Reservoirs dominator79 R/C Items: For Sale/Trade 3 01-30-2004 08:12 PM
