Old 12-27-2007, 06:24 PM   #241
MOTHER FOCAR's Avatar
Wink
WALLY I HOPE THAT WAS A MIS PRINT ON YOUR PART? AVG VOLTAGE FOR A 4 CELL PACK AT 35 AMPS WOULD BE ALOT CLOSER TO 4.90 VOLTS FOR VERY AVG PACKS... 5.0 volts at 35 amps for a 4 cell pack would be closer to the top 5% 4.70 at 35 would be closer to well ummmm trash can.....
MOTHER FOCAR is offline   Reply With Quote
Old 12-28-2007, 12:38 AM   #242
Trader Rating: 27 (100%+)
ok so has anyone use these new packs from promatch yet?
C_Money is offline   Reply With Quote
Old 12-28-2007, 04:46 AM   #243
RCMadness's Avatar
We have some of these new cells at RC Madness and thet are GREAT!! There is no question about their quality or anything else for that matter.
2012 Short Course Nationals at R/C Madness. August 3-5. Sponsored by TLR, Losi, Horizon Hobby, Futaba, AKA, Tekin, Trakpower, Castle Creations, Duratrax, HiTec. TheToyz.com, RC Driver, Spektrum, G4 Graphics, Dynamite, Proline, FullForceRC, Team Associated and MORE!
RCMadness is offline   Reply With Quote
Old 12-28-2007, 08:34 AM   #244
Trader Rating: 21 (100%+)
Default numbers
What are good number for 4600?
What would great numbers be?
Thanks.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 12-28-2007, 12:56 PM   #245
Trader Rating: 18 (100%+)
Well, hopefully I get to try these packs again tonight. Currently charging at 7amps with 3mv cutoff per cell. Pack comes off charger at 114 degrees F. Packs are taking just shy of 4600 mah when charged. I am going to try 4mv cutoff to bring the temp up just a little more and to put back 4600 mah in the cells. The numbers are coming up though, cycling at 35 amps; average voltage is 5.05v resistance is 5.1 (4-cell).
trilerian is offline   Reply With Quote
Old 12-28-2007, 01:08 PM   #246
Trader Rating: 17 (100%+)
Send a message via AIM to TMR CHASSIS
Thanks.
My Ener-G 4600 from ProMatch are 460 1.237 range. I love these cells they have great power!!!
Raymond McCoy
TMR CHASSIS is offline   Reply With Quote
Old 12-28-2007, 01:27 PM   #247
Trader Rating: 1 (67%+)
So what your saying is your cells are are 1.26 average voltage at 35 amp discharge I think you need to recheck your numbers.
Josh Hohnstein is offline   Reply With Quote
Old 12-28-2007, 01:36 PM   #248
wallyedmonds's Avatar
thats my point run ib cells a couple of times and they suck.
well they never where up there but the ener-g's are there the one pack was 5.00 ave the other 4.95.
oh these are 4200's
im getting 4600 soon.
wallyedmonds is offline   Reply With Quote
Old 12-28-2007, 02:21 PM   #249
Company Representative
Danny/SMC's Avatar
trilerian: I would reccomend increasing the charge rate while keeping the peak detect lower if you want more temperature out of your pack.
Josh H: T35s are great but they do tend to be different from one to the next. I know that I have 2 of them and they both read differently. The way you set them up for cycling a pack and the pack temperature will all have an impact on the numbers. This is why posting pack cycling numbers is pretty much useless unless the same T35 is used.
Danny/SMC is offline   Reply With Quote
Old 12-28-2007, 02:57 PM   #250
I just cycled two new Ener-G packs and the voltage numbers look great. As Danny said above, the numbers you get from cycling packs on different CE chargers will vary, so I am just comparing voltage numbers between my Ener-G packs and my IB 4200's that I cycled last night. I have an old T30 so I charged at 6 and discharged at 30.
I have two 4 cell packs of IB4200's (newest batch) that were brand new at Cleveland and now each have about 6-7 cycles on them. These were very good race packs at the champs and they came out at 4.89 and 4.90 voltage. I actually pulled wheelies with my 12th scale car at that race. Then I cycled the 2 Ener-G packs and they came out with even higher higher voltage numbers of 4.97 and 4.98. I can't wait to try these new cells on the track. I'm sure they will perform great in the car too.
I'll let you all know how they perform after racing this weekend.
Chris
cmock is offline   Reply With Quote
Old 12-28-2007, 03:35 PM   #251
Matt Howard's Avatar
Anyone know if these cells are ROAR approved? I know the next approval "window" for cells is either april or may and the carpet nats are in march.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-28-2007, 03:43 PM   #252
when cycling packs you also need to take into consideration the quality of the assembly of the pack. crappy solder ing will kill numbers. i can't say i have cycled a IB 4 cell pack with #'s lower than 4.88 at 35 amps
when you get above 4.98 you have something......if the energ cells can hold up with decent #'s for two months that would make them leaps and bounds better than a IB cell........
gfx 4 cell pack #'s for either IB or EP
this is not on new packs but packs 2 or more months old
395 run time 4.94 volts as high as 400 run time and 4.99 volts as low as 4.88 volts 378 run time.....it's the run time you realy lose if you don't keep a charge in them.i have not gotten my energ sticks in the mail yet......i will post up #'s when they get close to two months old just to compare the three cells.....that is IF the energ cells aren't a rebadged EP cell.....time will tell the tale..i realy liked how the EP cells ran on the track.... i'm talking 4 cell oval
Old 12-28-2007, 04:54 PM   #253
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I believe that ROAR is making a 1 time exception and is in the process of testing the Ener-G 4600 and IB4600 cell to be approved very soon. It was posted somewhere else.
EA
EAMotorsports is offline   Reply With Quote
Old 12-28-2007, 05:20 PM   #254
Send a message via AIM to Dawn Sanchez
EA
yes, we are making a one time exception on the 4600 mah cells - deadline for submittal is 12/31/07. We have received the IB's, the EnerG's and the Orion's per email today from the Technical Director.
This isn't going to happen again....
....we do have twice a year approvals and that is the best for our membership and has been keeping the battery wars at bay.... but, we might need to consider something else for later 2008 and into 2009 regarding weights of cells instead of mah. The 43mm can can only hold so much.. and it appears that is being pushed to the limits and is that really safe for our membership?
Dawn Sanchez is offline   Reply With Quote
Old 12-28-2007, 06:56 PM   #255
so lets make them bigger and keep using c cells
i dont see lipo for 1/12 is going to happen.
and lipo is for offroad anyways imo
SMC ener-G 4600 crabboy Australia For Sale/Trade 2 07-14-2008 03:17 AM
Brand new Ener-G 4600 6 cell packs John Tag R/C Items: For Sale/Trade 3 04-17-2008 05:18 AM
BRAND NEW XPRESS 4600 ENER-G 6 CELL PACKS Sigearhead R/C Items: For Sale/Trade 3 02-09-2008 03:43 AM
Ener-G 4600 6 cell packs John Tag R/C Items: For Sale/Trade 27 02-06-2008 03:35 PM
Ener-G 4600 6 cell pack John Tag R/C Items: For Sale/Trade 1 12-27-2007 03:32 PM
