Old 11-26-2007, 03:48 AM   #1
aussierevo's Avatar
Trader Rating: 14 (100%+)
Default 19t for Beginner
If you had a choice between a Reedy 19t Quad Dyno version or a Team Orion Element 19T V2 Spec which would you choose for a TA05. Limited budget and not sure enough about brushless yet (ie no budget for setup and lipo's).
aussierevo is offline   Reply With Quote
Old 11-26-2007, 05:44 AM   #2
tc3team's Avatar
I have a checkpoint, which im very happy with so I guess that would be my answer
If you're using it in a 1/10th car make sure you use the harder brushes. the stock brushes will burn up quick, unless you use the motor in a 1/12th car.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-26-2007, 10:56 AM   #3
tfrahm's Avatar
Send a message via AIM to tfrahm
Of the two motors you listed, I would recommend the Element V2 -- the aluminum endbell and the round brushes add up to much less maintenance. The Reedy Quad Mag motors perform very well, but I've found them to be "high maintenance" to keep that performance.
Having said all that, I would second the recommendation for the Checkpoint "Money" motor -- it is KILLER in performance and almost (but not quite) as low maintenance as the Element V2...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 11-26-2007, 01:58 PM   #4
aussierevo's Avatar
Thumbs up
that's for the info.....will check out checkpoint
Old 11-26-2007, 04:32 PM   #5
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Dont get a brushed motor...get a Novak XBR esc ($75), and Novak EX series 10.5 motor...you can get the combo for around $150 its all you'll ever need and will last you along time and be much more user friendly and easier to work with than with those brushed motors
yyhayyim is offline   Reply With Quote
Old 11-26-2007, 05:00 PM   #6
aussierevo's Avatar
Questions??
don't I need to have lipo batteries to run brushless.....would a XBR run with NimH IB 4200
Old 11-26-2007, 05:59 PM   #7
GreaseMonkey's Avatar
Brushless and Lipo are not exclusive to each other. It just seems that way because both have arrived on the market at a similar time and have been accepted by those that like the lower maintenance that both give over brushed and Nimh. You can run brushless w/ NiMh and you can run Brushed w/ Lipo. I know I do.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 11-26-2007, 07:49 PM   #8
tfrahm's Avatar
Ah -- As someone else posted, there is good news! I've been running NiMh with my brushless for about a year now... I still have to run brushed for some classes and/or tracks, but when I can run brushless, I still use my NiMh packs... Anything from the discontinued Novak SS+ to XBR to GTB ESC's... Using a GTB, I've run 13.5, 10.5, and 6.5 with NiMh without problems... I have the GTB/6.5R combo in my dirt oval truck and it HAULS!...
If you don't HAVE to run brushed, go brushless... I'm very happy with my Novak combo's... The main thing is that with either the XBR or GTB (both are good), make sure you get a sintered rotor brushless motor (bonded fades over time)...
Old 11-26-2007, 10:21 PM   #9
aussierevo's Avatar
thanks for the information.......I better do some more homework then before deciding which way to go......
beginner in rc meckbeckk Malaysian R/C Racers 0 08-03-2008 11:52 AM
TC3 Beginner help... surjer Nitro On-Road 9 05-21-2008 08:31 PM
What Car For a Beginner?? Gav_XXXS Australian Racing 10 05-14-2006 05:31 AM
Beginner jonto100 Painting, Designs, Graphics and Photography 3 04-04-2005 03:23 PM
Beginner - What do you think? kcarron Florida Racing 2 12-09-2002 10:23 AM
