One-Way For 414MII Problem??? >
Old 06-02-2003, 08:55 AM
Registered User
Calvin Ng's Avatar
Default One-Way For 414MII Problem???
i got the new one-way for my 414mII. and it seems to wiggle in between the bulkhead left and right.
anyone else have this problem?
is it even a problem?
or is it because my bulkheads are swtiched around? does it matter?
anyone have to put a spacer inbetween it
Calvin Ng is offline
Old 06-02-2003, 09:19 AM
Trader Rating: 21 (100%+)
i always used to notice a lot of side to side play in the diffs in my 414, but tamiya now has a 10mm shim set so you can take the slop out.
peter_robinson is offline
Old 06-02-2003, 04:47 PM
Registered User
Calvin Ng's Avatar
have you had any problems when it was racing on track.
Old 06-02-2003, 05:37 PM
Wilfred's Avatar
Ive noticed that side by side play too after assemble, and also on the center one way, but got no problem at all.
Peter what material are Tamiya using for the shim? Do they have also for the center 1 way?
Did you race in the Reedy Race? What happened to Surikarn? Why 19th?
Wilfred is offline
Old 06-02-2003, 06:51 PM
Registered User
Calvin Ng's Avatar
the thing is im really not using a one-way. i did and it had some wiggle in it. then i changed to a diff. because it slips
under accleration beginning the car wiggles left and right. im pretty sure its not a glitch. could it be the one-way?
