Old 06-02-2003, 07:51 AM   #1
TRF-Powered's Avatar
Adding Weight to the chassis
How do you all add weight to your car? Where do they selll those tiny weight blocks at? Double-sided tape?
As far as I know only X-ray sells weights for their car, since you can just bolt on those weights on the car.
If I remember correctly, Tamiya used to sell those mini-weight blocks for the MINI4WD. Don't know if they still have it.
Any ideas~?
Thanks!
TRF-Powered is offline   Reply With Quote
Old 06-02-2003, 07:58 AM   #2
Tamiya still sells them, and the good parst is they can easily be tapped for a 4-40 or 3mm thread so you can bolt them almost anywhere, the tape that comes with them is OK but they can still be dislodged.....
Or you could goto a Golf pro shop and pick up some self adhesive weights they come in 2 and 3 gram sizes, stick very well and fit ultra low on the chassis because they are only 1mm think.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-02-2003, 07:59 AM   #3
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Adding Weight to the chassis
Any ideas~?
Thanks!
I know that Yokomo Sells them and so does AE... But the Yokes are in Grams and the AE's are in oz
I think that they sell for less than 3 USD?
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-02-2003, 08:09 AM   #4
The golf weight... Do they sell that in sporting store like sport chalet? They are not expensive are they?.. Thanks!
Old 06-02-2003, 08:15 AM   #5
I just found some cheap stick on weights on Towerhobbies... the funny thing is due to some state law, it can not be shipped to California. That is some weird law.....
Old 06-02-2003, 09:58 AM   #6
c-lyon's Avatar
Try your local tire shop. The ones I have come in strips of twelve on doublesided tape and each weigh 1/4 oz or 7 gr. They measure about 1/2" by 1/2" by 1/8".
c-lyon is offline   Reply With Quote
Old 06-02-2003, 10:01 AM   #7
I paid like $3-4 for a pack I am not sure but anywhere that sells gold stuff should have them.....
Yeah everything causes Cancer in California!!!
Old 06-04-2003, 07:04 AM   #8
Guys, Guys,
go to your local tyre fitting depot!
Ask for the wheel balancing weights they use for ALLOY wheels, they come in self-adhesive strips that can be cut down.
The ones in the UK are in grams, they weight 60groams and the cut marks are at 5g and 10g intervals.
AND i think they should stick quite well due to the fact that they use them on real cars and they tend to stay on
Mort is offline   Reply With Quote
Old 06-04-2003, 10:03 AM   #9
iron chef's Avatar
you can get some smaller ones (1mm thick) at fishing dept at wal mart called storm suspend strips that can also be used to balance tires
iron chef is offline   Reply With Quote
Old 06-05-2003, 08:35 AM   #10
popsracer's Avatar
Default EVERYTHING causes Cancer in CA
I think R/C is the the only OFFICIAL activity that doesn't cause Cancer in CA. That's all I do anymore.
popsracer is offline   Reply With Quote
Old 06-05-2003, 05:20 PM   #11
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
lol aw man im gonnna cry. its too funny
that is so true
im still a newbie in r/c but how to you check if the car in balanced or not balanced. do you hook a string to the middle of the car and put weights till it doesnt tilt?
Calvin Ng is offline   Reply With Quote
Old 06-05-2003, 08:20 PM   #12
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: EVERYTHING causes Cancer in CA
You obviously haven't read the labels! Even the motors say that they contain materials that the State or Government has determined can cause cancer. . .
Just wait - you'll see!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-05-2003, 09:32 PM   #13
glide 1's Avatar
Default Digital Scales...
that is so true
i think a company (IRS not sure) makes digital weighing scales especially for touring cars, it is also used as a tweak station. It comes with 4 pods that you put your car's a tires onto and it will give you individual readings on all 4 corners. A little pricey though coz i would imagine that you would only use it once to get the car balanced and thats it..... $300 i think? Can someone please confirm what company and part no. if possible, thanks in advance
glide 1 is offline   Reply With Quote
Old 06-05-2003, 09:54 PM   #14
glide 1's Avatar
Default Irrgang Tweak Board
Found this at Tower Hobbies:
http://www2.towerhobbies.com/cgi-bin...=IRR&I=&G=&U=Y
For those who have this, Is it really worth the money?
Old 06-05-2003, 10:09 PM   #15
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm gonna pick up one of those weight boards, that seems like it would really pay off in the long run, get the car perfectly balanced front to back, and side to side.
Adding weight for Lipos F N CUDA Electric Off-Road 42 01-16-2008 01:34 PM
Adding Weight to Chassis shaggys40oz Electric On-Road 7 10-20-2007 04:11 PM
Adding weight to Lipos? F N CUDA Electric On-Road 18 07-12-2007 01:11 AM
Adding weight to B4 Born2Lose Electric Off-Road 10 02-04-2007 04:36 PM
53494 Tamiya Light weight Chassis. chrisman R/C Items: Wanted to Buy 2 12-26-2002 10:20 PM
