Old 11-21-2007, 08:08 AM   #1
sosidge's Avatar
Better to draw a distinction between foams and rubbers.
Rubber tyres will run acceptably with the same basic setup for tarmac and carpet. Generally a rubber car is softer in both chassis flex and suspension settings.
Foam tyres on carpet generate more grip so require a stiff chassis and suspension setup.
Spool is best suited to rubber tyres, diff is best suited to foam tyres.
However as with all things setup is as much about how it feels TO YOU instead of what someone else says is right.
If the car is EASY for YOU to drive FAST, that is far more important than whether you run a 2mm or 3mm chassis plate becasue it is on a team setup sheet!
Last edited by sosidge; 11-21-2007 at 08:25 AM. Reason: Sorry there seems to be a problem with the forum time of my posts!
Old 11-21-2007, 08:10 AM   #2
snoopyrc's Avatar
Default Set ups for Dummies
First of all I would like to ask what are the main differences in set up between Asphalt and carpet? Like which one would you rather use a stiffer chasis on? Which one would you use a spool on?
snoopyrc is offline   Reply With Quote
Old 11-21-2007, 10:54 AM   #3
Trader Rating: 27 (100%+)
I gave up on those "team" setups a while ago. You speak the truth. Whats funny is that if you cant get around the track without hitting $hit, then there is no set up that will help. By the way, my rubber/carpet car has a 4 mm chassis and my foam car has a 2.5 mm chassis, and duel diffs in both cars (i am faster with it that way (?).lol
convikt is offline   Reply With Quote
Lipos For Dummies yeahyeah Electric On-Road 6 08-04-2008 08:27 PM
Inserts for dummies fatbear Electric Off-Road 12 03-31-2008 01:37 AM
Rollout for Dummies?? RAST Electric On-Road 4 12-08-2006 02:26 PM
tc4 for dummies bignotch Rookie Zone 2 01-25-2006 04:07 PM
Gearing for Dummies. [HELP] DustinR Electric On-Road 5 08-13-2005 03:10 PM
