Old 11-18-2007, 08:35 AM   #1
macnkitty2002's Avatar
Default How do I know if a battery cell is bad?
I have an IBWC 4200 pack that I recently took with me to a race, and it is exhibiting some unusual behavior. When I put it on the discharge tray, the LED for that cell does not illuminate, and when I switch the pack around, the same happens to the other side so I know the LEDs are fine. When I charge it at 5.5A, .5A below the recommended rate, it gets really hot after about 15 minutes. The rest of the cells are "lukewarm" as typical, but this one cell is outrageously hot. Also, I noticed a little bit of greenish-grey substance on the outside of one end of cell, but not the other cells. Is this what people call venting? I have not abused these cells, I charge them maximum at 6.5A when I need to repeak 1 minute before my race. When I put the pack in my car, it runs fine for 2-3 laps, then the performance sharply drops off. What can I do? If it is bad, need I throw the entire pack out?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 11-18-2007, 08:41 AM   #2
Yeti35's Avatar
Get yourself a mutimeter and check the voltage to that cell. More then likely it is dead and nothing you can do other then replace that cell. The IB WC cells are just pure junk these days and I personally would not buy any of them. Plus if you direct solder to your packs and that is an end cell you are killing that cell quicker with the heat from soldering as well.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 11-18-2007, 09:19 AM   #3
Trader Rating: 16 (100%+)
Yes....IB4200 especially the WC version, had a period of time receive some lower then standard quality cells that is all around the market. I have 6-8 packs of IB4200 and 4 are WC version, each pack has at least 1 cells are DEAD for absolutely no reason. 1 pack has 2 dead cells.
When I ran the car at 1 time...around 2 minutes mark, the car suddenly slow down (like shifted to 2nd gear from 5th) but it is not SLOW like dumping...that explained to me there are dead cells within.
Dropped the pack to the Smart Tray, immediately see that 1 (or 2) dead cell (lights turn off immediately after) and the rest are ON like forever (cause I did not discharge them from the discharger)....cycle and try to wake up that cell, its too late...dead cell. And I have like 6-7 of them so far. All from IB.
Now...only use EP cells.
Old 11-18-2007, 09:35 AM   #4
adamge's Avatar
Charge the individual cell (alligator clips on the bars works well) at 6A. A dead cell will jump to ~1.5V immediately. Let the charger put in 500mA. Then discharge that cell at 10A with a 0.8V cutoff. A dead cell will hit the cutoff within seconds, a good cell will put out ~450mA.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 11-18-2007, 10:47 AM   #5
exactly what happened to me. can i buy an individual cell and replace it?
Losi Rock Rey
Old 11-19-2007, 05:23 PM   #6
Thumbs up
I've got a bad cell on a 3800 SMC pack. I made it work as an electrical receptor with another pack for something about 5 secs. Cyled the pack, cell back to normal!
Corally RDX PHI
Brazilian Racing Team
rafaelmm is offline   Reply With Quote
Old 11-19-2007, 05:33 PM   #7
POUNDITRACING's Avatar
it's hard to find indavidual cells these days. Charge the pack fully and put it on the tray. If you are running stock you will notice a larger drop off. You should check the voltage of the cell. Just because the cell vents dosen't meen that it's bad. I have had about 20 IB packs and only had cells go bad after 3 months of no use.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 11-19-2007, 10:57 PM   #8
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Ya, just put a volt meter to it, all the cells should read around 1.2+ wether they are discharged or charged. I recently had a EP 4200 cell take a poop. These days with these high voltages/runtime, dead cell is getting more and more common.
I was monitoring my packs performance since built it, first clue from the beginning, was,, it was only charging to 4000mah while the other packs were going at 4600mah+ I did a volte meter test to it, and it said .90, so i cycled it again and it read .50, did it again, and it was at .10 while the rest were at 1.2
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 11-20-2007, 12:21 AM   #9
asw7576's Avatar
Charge to peak
Now Discharge the pack at 30A, and use your voltmeter to check individual cell during that discharging process. Shitty cell(s) will drop below 1.2V during the first 120 seconds. Mark it, and up to you what you want to do with it.
Old 11-20-2007, 12:29 AM   #10
One question came my mind. What does that IB:s WC mean = Worse Cell?
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 11-20-2007, 12:41 AM   #11
rcstunt101's Avatar
world championship
Associated TC5R
Associated B4
Yokomo B-max4
LRP, Intellect, Futaba
rcstunt101 is offline   Reply With Quote
Old 11-20-2007, 12:42 AM   #12
BSchorr's Avatar
Kinda fits it's name, huh?...lol
Old 11-20-2007, 02:02 AM   #13
Holmenkollen's Avatar
I have two packs in which one cell becomes much much warmer than the rest. When that cell reaches 45 C the others ones are about 30 C = I must stop the charge and as a result only 2300 mah put into the pack.
What to do?
And yes, itīs WC-cells, brand new packs.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 11-20-2007, 02:29 AM   #14
radio_car_racer's Avatar
read Pack Test on this page
you don't need a Pro-Trak to do it but it helps
radio_car_racer is offline   Reply With Quote
Old 11-23-2007, 08:09 AM   #15
another thing i have noticed is that the bad cell takes a charge very slowly, while the other good cells soak up the current like there's no tomorrow.
Losi Rock Rey
Battery Lot(18R 18T/ 6 cell, 8 cell)/ALl Deans psychosupra R/C Items: For Sale/Trade 0 07-31-2008 04:30 PM
[FS] 4-cell + 6-cell Battery Packs squarehead R/C Items: For Sale/Trade 8 01-04-2007 10:28 AM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 06:07 PM
Battery Sale (4) 6 Cell (2) 4 Cell KEITH R/C Items: For Sale/Trade 9 12-15-2003 06:01 PM
12v gel cell battery Johnnytc3 Nitro On-Road 6 06-15-2003 07:02 AM
