Old 11-14-2007, 03:57 PM   #1
Diggity's Avatar
Trader Rating: 29 (100%+)
Default Diggity Designs 3D08 1/12th Racer
Diggity Designs is proud to announce that its new website is now up and running. Please refresh your browsers.
The Diggity Designs 3D08 is now available, check it out on the new website..Let me know if you have any questions
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.teamscreamracing.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 11-14-2007, 04:03 PM   #2
Send a message via AIM to $rusty$ Send a message via MSN to $rusty$
Car looks great Damon!
I'm sure it's gonna perform just as good as it looks.
Rusty Andersen
thercbarn.com
$rusty$ is offline   Reply With Quote
Old 11-14-2007, 04:28 PM   #3
chris moore's Avatar
Trader Rating: 88 (99%+)
Interesting design, how well do the lower body types work on your ride? Any problems with the battery cover hitting on a body like the speed12?
Chris
chris moore is offline   Reply With Quote
Old 11-14-2007, 05:13 PM   #4
Diggity's Avatar
Chris
Hey Chris, The Speed 12 body fit fine on the 3D12 and Im sure it will fit fine on the 3D08 since its the same placement. Most of us are still running the Speed 8...
Old 01-22-2008, 12:40 AM   #5
Diggity's Avatar
Here are some pictures of my 3Do8 with a brushless system in it. LRP Sphere comp speedo with Novak 13.5 motor. I have noticed that the old canned Novak brushless motors are harder to install, if you have the new canned (rounded edges, ribbed) then you are good to go!
Old 01-22-2008, 03:09 AM   #6
Bob-Stormer's Avatar
How is the pod balance with the BL motor in it?
I should get around to trying one of these.
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 01-22-2008, 11:41 AM   #7
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
does it use a soft spring, or is it medium? the battery placement is pretty cool, but hows the traction in the rear?
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 01-22-2008, 01:10 PM   #8
sportpak's Avatar
Trader Rating: 26 (100%+)
Looks awesome! I like seeing something fresh. Is it a chore getting batteries in and out?
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-22-2008, 01:33 PM   #9
I really like the solid side links ala CRC. It makes setting up the cars a lot less of a chore. And I like the wider links to allow the electronics to sit further back. I still have an issue with the battery mount not having enough in front of the battery to keep the battery from going through the servo. Even with my Darkside having the posts in front of the battery I still bend up screws from the battery hitting the posts very hard.
My ideal car right now would be wide links like the Diggity, rear pod and flex plates from the BMI, Battery mount from the Darkside, and front suspension from the Speed Merchant Rev. 5
Old 01-22-2008, 03:33 PM   #10
Diggity's Avatar
Hey Bob, hit me up, Im sure we can make a deal
Damon
Old 01-22-2008, 03:58 PM   #11
Diggity's Avatar
Bob: The pod balance seems to be no different from running a brushed motor. The BL motor is not any bigger but a little heavier, and the weight is in the center of the car so its not any different. We havent had to tweak the pod any differently than when we were running a brushed motor.
Old 01-22-2008, 04:06 PM   #12
Diggity's Avatar
Yes we usually run the blue side springs with the blue center spring. We are currently running .020 or .022 in the front. Rear traction is good, we run 5,000 to 10,000 dampener lube to help keep it planted. We run CRC pink rears and magenta fronts!
Old 01-22-2008, 04:07 PM   #13
Diggity's Avatar
No, its a breeze, two screws and the top plate swings to the side.
Old 01-22-2008, 04:11 PM   #14
Diggity's Avatar
InspGadgt: I agree, very easy to setup and tweak. The batteries are pretty well lodged between the chassis and the top-plate and none of our drivers have had an issue with the batteries.
The brushless speedo is only about 4-5 grams heavier than a brushed (KO) so it really hasnt made any difference in the way the car tweaks. It has been noted that the Novak brushless speedo is a little bit of a pain to get mounted, but the LRP fits like a charm.
Old 01-22-2008, 06:01 PM   #15
Hey Diggs.....
You coming to race this weekend? I wouldn't mind taking a closer
look at that new ride. Might sway me to part with my CEFX!
John Warner is offline   Reply With Quote
Diggity Designs 3D08 1/12th scale sportpak R/C Items: For Sale/Trade 6 05-11-2008 10:41 AM
Diggity Designs 12th scale chassis with 12l chassis roadrashracing R/C Items: For Sale/Trade 5 03-13-2008 08:29 PM
Diggity 3D08 brand new DavidAlford R/C Items: For Sale/Trade 8 02-29-2008 07:22 AM
Diggity Designs 3D08 gtxpro2 R/C Items: For Sale/Trade 8 02-12-2008 05:10 PM
WANTED.. Diggity 3D08 12th scale sportpak R/C Items: Wanted to Buy 0 02-08-2008 10:29 AM
