Old 11-14-2007, 08:53 PM   #16
Joel Lagace's Avatar
For the Canadians in the house:
Canadian Tire brand Brake cleaner works great! The can holds double what the rc brand cleaner holds and for less money. I been using CT brand brake cleaner for the past 10 years, at one time the posted contents and they had matched identical to the rc cleaner of the day... The key is in the product description: LEaves no residue,dries fast,safe on o2 sensors,electric motors...
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-14-2007, 08:53 PM   #17
Originally Posted by robk View Post
To everybody who recommends brake cleaner: Thanks for ruining my lungs.
Seriously, that stuff is horrible, 100% without a doubt. I have given motor spray to people just so they don't use brake cleaner. Yet, Paragon gets banned...jeez..
When i run out of Crown royal, i like some BRAKE CLEANER AND GINGER
www.rcottawa.com
Old 11-14-2007, 09:52 PM   #18
Tim W.'s Avatar
I have used this stuff it works good and is cheaper the motor spray but smells bad
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
Old 11-15-2007, 02:11 AM   #19
Mooshu Beef's Avatar
Originally Posted by billjacobs View Post
For cleaning parts, instead of brake cleaner which has chemicals that are very bad for you, use 70% isopropyl rubbing alchohol. $1 for a bottle at any grocery or drug store that will last a year. It isn't toxic, and doesn't dry out your hands. Just don't drink it.
It's not so good for cleaning motors, but for parts and bodies, it works great.
R/C racers are so quick to buy "specialized r/c products" that cost 5x times.
the other 30% of that rubbing alcohol is water, btw. So it is not really good if you don't want rust showing up on your parts.
Motor cleaner to me is a convenience. A can will last a long time and I get to watch all the dirt and crap in my motor drip off... And yes, this will dry your hands because the stuff is volatile and will evaporate easily, so I take a glove from the box of 300 clear plastic gloves I have for one hand that I hold the motor in.
But yeah, brushless is an answer to this problem too. I am trying to go brushless asap, (waiting for a used MM ESC or the Sidewinder...)
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 11-15-2007, 01:43 PM   #20
Soapy water (dish washing soap), followed by a rinse with isopropyl alcohol.
For more thorough cleaning of sealed motors, run the motor at 3 volts while immersed in the soapy water for a minute, then run it again for a few seconds in the alcohol.
The alcohol rinse is important, as it gets rid of the soapy water.
Blow the alcohol out with compressed air.
I've not tried it on sealed 540 motors, but I do it all the time on sealed slotcar motors.
clockworks is offline   Reply With Quote
Old 11-15-2007, 07:11 PM   #21
doriftu's Avatar
i may be off topic a bit but since we are on motor cleaners i have a question after blasting the motor and amature with the cleaner...
what should be the next step? comm oil? lube the bearings?
what do u guys suggest if i do not have comm oil?
thanks!!
doriftu is offline   Reply With Quote
Old 11-15-2007, 10:23 PM   #22
wallyedmonds's Avatar
i use now kia brake parts cleaner
good stuff
wallyedmonds is offline   Reply With Quote
Old 11-16-2007, 09:10 AM   #23
trjracing's Avatar
Originally Posted by Evilstealth View Post
Does anyone know what electric motor cleaner is? Is it a watered down degreaser? Anyone found a cheaper alternative?
Adam
I use contact & circuit board cleaner on my electric motors, It work's great and never had a problem with it. Also I never had any bad reactions to it.
GOD IS GOOD, LIFE IS GOOD... I AM THE BAD BREED... B.B.R. BADBREEDRACING... Rest In Peace Marshall G. Winston America's Hobby Center, You will be missed...
trjracing is offline   Reply With Quote
Old 11-16-2007, 09:53 AM   #24
QuickRC's Avatar
Exclamation
Besides brake parts cleaner being bad for you, all the ones I have used will melt plastic parts. Before you spray that stuff in your motor try it on a scrap piece of plastic of some sort and see if it starts melting away at the plastic. I'm sure ALL brake cleaners don't do that but just be safe and test first.
Brad
www.QuickRC.com
QuickRC is offline   Reply With Quote
Motor Cleaner /Brake cleaner PRO 2 RACER Australian Racing 9 10-10-2006 04:44 AM
Ka Boom as a motor cleaner Ducati-Rider Electric On-Road 0 03-20-2006 03:53 PM
motor cleaner anthony390 Electric On-Road 43 02-05-2006 05:50 PM
Brake dust cleaner or Nitro Cleaner? TurboLancer Electric Off-Road 10 12-04-2004 05:47 AM
Motor Cleaner Substitue jedi Electric On-Road 14 04-23-2003 05:44 AM
