Running-in ball cups? >
Old 05-30-2003, 01:11 PM
fatdoggy's Avatar
Default Running-in ball cups?
I got some RPM ball cups today and they are rather tight on my original ball ends. Granted I should go and get new ball ends but I can't be stuffed. Is there any way to get them to be freeer?
Thanks.
fatdoggy is offline
Old 05-30-2003, 01:24 PM
iron chef's Avatar
i think rpm ends work best with associated ballstuds. I had the same problem trying to use losi ballstuds and tried to work them around a little to get them to free up and wound messing them up. Basicly it didnt work, you are probably better off with a little slop than a binding turnbuckle until you can get the right ballstuds.
iron chef is offline
Old 05-30-2003, 02:43 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I used the Losi Titanium ball studs with RPM cups, and it binded very little, I would personally like them tight than sloppy, dont want them to pop off too easilly.
Randy Caster is offline
Old 05-30-2003, 04:10 PM
I'd much rather have them a little tight than sloppy. I went exclusively to RPM ball cups on all my HPI cars to tighten up the steering. Use a little powdered graphite as a lubricant. Works great, won't attract dust like a liquid lubricant will. Be careful not to scratch the balls as this will definately affect how smooth they operate.
calvin is offline
Old 05-30-2003, 04:53 PM
HYDRAMATIC99's Avatar
You can try to gently squeeze the cup where it snaps on to the ball with a pair of needle nose pliers. This will help free them up some, but don't do it too hard or you will develop too much slop.
HYDRAMATIC99 is offline
Old 05-30-2003, 07:59 PM
Aurra Sing's Avatar
Pop the ball cup on a ball stud and use a rotary tool to spin the stud in the ball cup for a few seconds. It runs-in ball cups very well.
Aurra Sing is offline
Old 05-31-2003, 07:56 AM
seaball's Avatar
yup, use the dremel. if your balls are aluminum, they will be polished in the process too.
seaball is offline
Old 05-31-2003, 04:15 PM
fatdoggy's Avatar
Thanks for the help.
Nice and free now.
fatdoggy is offline
