Old 11-11-2007, 11:12 PM   #1
Default 1/12th Scale and Lipo
Hello all,
I've been running off road for many years, and have an interest in dabbling with some carpet racing. I've seen some guys at my local track running 1/12th scale cars, and they've really caught my eye.
In my preliminary research, it seems that most 1/12th scale cars run 4 cell NiMhs.
My question...Are there any battery manufacturers building Lipo packs for these cars? Are there mods you can do?
Any help would be appreciated. Thanks!
Eggman is offline   Reply With Quote
Old 11-12-2007, 07:51 AM   #2
A LiPo equivalent for 4 cells is pretty much a no go. A 1S pack is 3.7v (not enough voltage) and a 2S pack is 7.4v (way too much). You could probably put in a soft sided 2S pack (wouldn't recommend it for safety reasons) , but a beat up stock motor would probably be faster than a well tuned mod due to the voltage difference.
I think there are a couple of guys that tried it and abandoned the idea.
Chris
ckearns is offline   Reply With Quote
Old 11-12-2007, 08:42 AM   #3
Rick Hohwart's Avatar
Chris
Yes, there is no way a 3.7V LiPo would be competitive against an NiMH 4-cell pack. But I think a 3.7V LiPo cars racing against each other could be a very interesting class.
Rick Hohwart is offline   Reply With Quote
Old 11-12-2007, 08:46 AM   #4
Trader Rating: 27 (100%+)
hmmm...that would be interesting
convikt is offline   Reply With Quote
Old 11-12-2007, 08:49 AM   #5
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I was looking into driving a pan car, but once I found out that no one uses lipo AND brushless in them, I also abandoned the idea.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 11-12-2007, 09:10 AM   #6
syndr0me's Avatar
Trader Rating: 32 (100%+)
The oval guys hve been experimenting with using 7.4V LiPo in their pan cars with Novak 21.5 motors. SWTour would be the right guy to give you details, but I think they've found them to be very similar in speed to a 27T+4cell car. In fact, nearly identical as I recall. So, maybe there's some hope for LiPo in 1/12 in that regard?
As far as battery placement, I wonder if you could get away with using smaller cells that are usually intended for 1/18th scale? There's a guy around here using them in a T2R with a silver can motor with pretty good success. How much capacity could a 21.5 brushless use in an 8 minute race? Again, just something to consider.
Anyway, LiPo in 1/12 is problematic at the moment for a number of reasons, but it seems like there's some possible solutions out there for people willing to give it enough effort. If I were messing with it right now, I'd probably go down the 21.5T/7.4V LiPo road and see where that leads.
http://www.shopatron.com/product/par....15996.0.0.0.0
syndr0me is offline   Reply With Quote
Old 11-12-2007, 09:17 AM   #7
AdrianM's Avatar
I think so too. With 3.7V all you have to do is motor up a little to get back to the same speeds....the cars will be a lot lighter after all. Stock speeds could probably be met with a 10.5 instead of a 13.5. Mod would motor up from a 4.5-5.5 to a 3.5.
Adrian Martinez
Old 11-12-2007, 09:21 AM   #8
syndr0me's Avatar
Is the 3.7v enough for electronics, or would a receiver pack be required?
Old 11-12-2007, 09:40 AM   #9
You would probably need one. But most 4-cell racers use one anyway.
Old 11-12-2007, 10:05 AM   #10
kwik-kid's Avatar
Send a message via MSN to kwik-kid
funny you should bring this up, i wanna make a brushless lipo pan car soon that should go like a rocket, iv been reserching and for a 540 size can, a mamba max 5600 kv 3cell lipo is so far the best combo, iv found a few others but i dont know enough about them to use them
one more thing, a good high quality pan car is VERY VERY expensive
ps3 tag name:- kwik-kid -: add me =]
kwik-kid is offline   Reply With Quote
Old 11-12-2007, 10:10 AM   #11
AdrianM's Avatar
Josh Cyrul told me there was a guy at his track that was running 2-2100mah cells in parrallel to make a 4200mah 3.7v pack. With a Novak 3.5 he can race with the guys running 4 cell and 5.5T BL mods.
Adrian Martinez
Old 11-12-2007, 10:48 AM   #12
linger's Avatar
I once tested a 3.7V lipo putting a bunch of smaller cells in parallel for 4.0Ah worth of capacity. I used a smaller 170mAh lipo and Novak regulator as a receiver pack. Even with a 7 turn - it felt as slow as a 1/12 scale stock car. I couldn't gear it high enough as the bigger pinions pushed the motor against the T-Bar. I should revive that experiment and test with brushless since they seem to do better under low voltage compared to brushed. I think it's really a better solution to go 7.4V and motor down - 21T brushless or even mabuchi.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 11-12-2007, 11:15 AM   #13
gacjr0's Avatar
Trader Rating: 15 (100%+)
I am very happy with my 7.4V/mabuchi:
1/12th Scale and Lipo-lipo-12.jpg
gacjr0 is offline   Reply With Quote
Old 11-12-2007, 11:41 AM   #14
joe of loath's Avatar
well the A123 cells are 3.3v i think... a bit closer to 4.8v
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 11-12-2007, 01:29 PM   #15
We've seen a Mamba Max (1/18th) motor run on 7.4v LiPo, and that has definite possibilities. I think it was a 6800Kv motor, and it went as fast as a 19T. The car didn't need a receiver pack, and weighed in about 500g.
There wasn't any time to adjust handling in depth, so it wasn't a perfect comparison. However, you can see that with the right adjustments to springs and other settings, the car would be very fast round corners, even if it (currently) lacks a little top-end against a Mod.
To continue the 12th appeal of low(er) cost and easy maintenance, this is an excellent avenue to explore, giving access to both LiPo and BL technology without any large expense for either the existing driver, or the new driver. I'd like to see this taken up and developed, as it would cost much less, and be easier to run, than any other option for LiPo and BL.
SlowerOne is offline   Reply With Quote
4 cell 1/12th Scale Stock Parity with LiPo Radio Active Electric On-Road 34 09-13-2008 02:37 AM
1/12th Scale LIPO artwork Colorado Racing 0 08-15-2008 03:19 PM
12th Scale (and oval) and Lipo - Making it work soon. Mason Electric On-Road 46 02-27-2008 05:20 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
lipo for 1/12th scale ptjonesus Electric On-Road 5 09-23-2007 05:40 PM
