Old 05-30-2003, 01:04 AM   #1
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Default PCM no good for Electric Cars
Hello im in the process in trading my stuff for a PCM recievers, only
to find that one of the experienced racers in my area told me there not good for electric becuase the response would be preety slow, is this true ??
FUK_WRX is offline   Reply With Quote
Old 05-30-2003, 01:56 AM   #2
Diva's Avatar
Send a message via Yahoo to Diva
The problem is not good or bad to electronic. It's the usefulness. I have both HRS and PCM on my several EP. Frankly speaking, I can't tell the difference.
Diva is offline   Reply With Quote
Old 05-30-2003, 04:41 AM   #3
FUK_WRX's Avatar
Default noticable
Ok, i thought the lag would be noticable. Anyone else ??
Old 05-30-2003, 05:07 AM   #4
dtm
dtm's Avatar
Send a message via ICQ to dtm
No lag with PCM.....anyone telling you this must be reading too many books....tell them to stay there and keep out of RC....
dtm is offline   Reply With Quote
Old 05-30-2003, 05:45 AM   #5
can't see what the problem with pcm is, if there is any delay it will be in microseconds which Michael Schumacher himself would not be able to tell the difference.
sanj
schumacher is offline   Reply With Quote
Old 05-30-2003, 07:44 AM   #6
FUK_WRX's Avatar
Default i respect him
The person who told me this is very professional i have a geat deal of respect to him, thanks for your response ill be doing the deal i guess its worth swapping my TC2 for 2 PCM1024 plus cash what you guys think ??
Old 05-30-2003, 08:11 AM   #7
sosidge's Avatar
You do realise you need a PCM transmitter as well?
Old 05-30-2003, 08:25 AM   #8
FUK_WRX's Avatar
Talking OFCOURSE
I dont think i would waste my time going through all this trouble if
i didnt have PCM tx
Old 05-30-2003, 08:27 AM   #9
don't multiplex have a pcm set.
just wondering if they would be compatible as the sampling rates might be different.
sanj
Old 05-31-2003, 11:55 AM   #10
Apparently the PCM1024 & HRS doesn't work well on electric cars. There is a lag on PCM due to the conversion time but you probably won't notice this lag. The main issue is that the PCM and HRS detect possible glitch and lock your radio, the detection process is too sensitive for electric car. Any slight interferece from your electric motor can cause a short lock-up. Go to a big race and look at the top 20 cars, how many are using PCM or HRS?
RickyIS300 is offline   Reply With Quote
Old 05-31-2003, 01:34 PM   #11
CypressMidWest's Avatar
Everyone at my track who uses the 3pk is currently using HRS in their electric cars. We have some guys on 75mhz who do occasionall experience "hits" but at no point are their receivers locking up. PCM is perfectly acceptable to use with electric cars, PCM is designed to help combat interference. The reason it's so popular in NITRO racing circles, is because Nitro cars, with all their metal on metal contact, generate way more RF Noise than Ep cars do. For years on the big Velodrome Ovals here in the states, Oval racers have sworn by PCM because the Tracks are a 1/4 mile driving line. There's nothing wrong with using PCM in your electric car.
As has been previously stated, there is a slight delay....... measured in MICROSECONDS. If you were Masami or Joel, you might notice it on carpet with a 12thscale car, but a mere mortal will only feel a difference if he believes the difference is there.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 05-31-2003, 02:26 PM   #12
Masami Hirosaka's Avatar
ok i see
Masami Hirosaka is offline   Reply With Quote
Old 05-31-2003, 04:55 PM   #13
PCM and HRS work fine in electrics. If you own a 3PK you can see in the manual that there's a section to help setup an ESC to work with the faster frame rate of the HRS. PCM isn't the same as a dual conversion receiver which does take a few milliseconds longer to process. PCM is simply Pulse Code Modulation or digital instead of analog PPM (FM) the signal isn't processed any longer than a regular FM signal. Also you don't need to activate the fail-safe if that is your preference and indeed it isn't necessary for electrics at all (ever see an electric run away at WOT?).
The problem is that perhaps someone thought that they would see a huge difference and when they didn't feel the faster response (and who can?) they start dissing the radio. Mine seems to be working as good as any other high quality radio does. I've tried the Mars R and it is the same as the 3PK, both are wonderful radios.
AreCee is offline   Reply With Quote
Old 05-31-2003, 08:49 PM   #14
If they're so good, how come none of the top drivers are using PCM in electric?
Old 05-31-2003, 09:09 PM   #15
dtm
dtm's Avatar
Normally in big races the TX are collected and the use of them is very well controlled....therefore, the chance of glitching from clashing frequencies is zero! Thats why these top drivers do not use them..coupled with he fact tha FM RX are smaller than the PCM as well.
really good cars eman12 Wisconsin & Illinois Racing 3 08-21-2013 09:14 AM
good ? about cars shawn17 Chat Lounge 15 03-14-2007 07:05 PM
Good Cars MassiveMods Australia For Sale/Trade 0 02-19-2006 09:22 PM
AE electric cars F/S Turbo9000 R/C Items: For Sale/Trade 1 10-06-2004 09:06 PM
Stuff for sale Electric 1/10 Cars and Gas cars.. MaxPower R/C Items: For Sale/Trade 0 07-08-2003 09:04 PM
