Old 11-09-2007, 08:56 PM   #1
ijump's Avatar
Default 1/12 tires
Does anyone know if any companies make rubber tires for 1/12 pan cars. If not then how long would fomies last on pavement
Thanks,
Colin
ijump is offline   Reply With Quote
Old 11-09-2007, 10:05 PM   #2
Budman's Avatar
Trader Rating: 22 (100%+)
BSR makes them for oval.
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 11-10-2007, 02:40 PM   #3
Rubber capped tires are generally used for oval...they tend to shred on asphault.
As for foams how long they last will depend on what compound you use and how much traction you have on the asphault so it is pretty difficult to say how long they will last for you.
Old 11-10-2007, 07:41 PM   #4
AdrianM's Avatar
In Florida we run asphalt 1/12th all year. We run Double Pinks front and rear. If you are on a budget start your tires at 1.8" in front and 1.9" in rear. On a decent track that is relatively clean, slightly sugar watered and a well setup car you will loose ~.020" (.5mm) in diameter per run in stock and 19t...a little more in mod.
I normally have 3 full sets of tires that I rotate throughout the day. This way I dont have to change ride height with wear. Rotating 3 sets I can get 3 race weekends out of a set of tire before they get too small.
FYI, when ture are too small on asphalt (under 1.70" front and under 1.75" rear) they are perfect for carpet racing
Also, for running faom on asphalt you use regular black paragon for 15min then a coat of white runny suntan lotion for another 15min to 30min depending on the time you have between runs. I prefer Target brand SPF 45.
Trust me after 20 years of racing pan cars on asphalt NOTHING is better then suntan lotion.
Adrian Martinez
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 09:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
