Norway suspends Electric RC racing >
Old 11-09-2007, 03:56 PM
  #91
Default Blown Battries
We just had a rash of batt blowing up also and now have a dedicated gharging rack at the track . All the many years of racing and all the racers here that we have raced with we never had aproblem before , seems like its the Cs doing all the exploding . Think maby the MFG have made a bad batch or the amfg cut corners or the are using dif materals to save a buck . Just some thoughts as this has just started happining at this level
Just some thing to think about
dmowery is offline
Old 11-09-2007, 03:58 PM
  #92
adamge's Avatar
Duratrax Ice has 0mV, and I use it. Any more and the pack gets damn hot at the end of the charge, as the charger pumps power into a pack that is fully charged. All that power just turns to heat - not good for the chemicals inside.
adamge is offline
Old 11-09-2007, 09:52 PM
  #93
Dan the Man's Avatar
Trader Rating: 41 (100%+)
Can you even get matched packs of 3800's anymore?
Dan the Man is offline
Old 11-09-2007, 10:57 PM
  #94
Originally Posted by billjacobs
The battery wasn't in an insulator. The battery was on top of the foam block. The block is similar to the trinity battery stand.
I love how everyone always blames the user of the batteries, as if everyone here watches the batteries charge. It takes 30-40 minutes for a battery to charge, much of the time, the driver is no where near the battery when it peaks. Even though the instructions tell you to watch the batteries and never leave the batteries while they are charging, who actually does this?
A better idea is to use batteries that haven't shown a propensity to blow up.
Did we have these problems with the gp3300? How about the issue of the batteries self discharging overnight and going bad? Or a good number of single cells in a pack simply dying after a few cycles or new out of the box?
The facts are simple. IB and EP have pushed the limits of the sub-c shape and size too far. The result is a fragile battery that cannot handle the repeated high amp charge and discharge cycles. Add to that the messaging of the batteries by the matchers, and you have the problems we have now. But instead of going back to 3300 and 3800 batteries, the push continues to 4600mah, etc.
When brushless racing takes over brushed racing, you simply won't need the capacity that these batteries have for a 5 minute race. Since brushless is so much more efficient that brushed, a good 3300 or 3800 pack will be plenty.
If it was on top (rather than inside), that's fair enough.
I recently changed from unbranded stick packs to building my own. I don't need the max runtime (carpet racing stock motor). I looked around the forums and read posts about IB and EP cells being fragile. I decided to go for GP3700s.
I charge them at 2.5A, 20mv peak (for the pack), 40 degrees cutoff. The max temp reached is usually 15 degrees above ambient.
clockworks is offline
Old 11-10-2007, 12:01 AM
  #95
Suspended
Originally Posted by wyd
Well I don't think many could do any worse than we have now.
The Goverment should worry about other things going on in the world like lets say off the chart gas prices, heating oil prices, lack of jobs, illegal aliens, and so on no some freaking R/C car batteries. I can see are congressmen debating on that subject..........can you see the smoke now......oh wait it was an IB4200 blowing up and starting a fire.
"The Government" didn't do anything here!!
It was the Norwegian Federation that banned electric racing. The Norwegian Federation is not the government...it is simply a sanctioning body just like ROAR!!
403forbidden is offline
Old 11-10-2007, 08:27 AM
  #96
So Ole, you tell me what the official press release from the Norwegian Association means...
All it says to me is that they are waiting for the EFRA list to come out. Other posts by Norwegian Association members says they hope this will be by January. You tell me what they are actively doing to investigate this problem. If I read it on the Internet, then it will be true.
SlowerOne is offline
Old 11-10-2007, 09:37 AM
  #97
Did you see the part about EFRA saying you can NOT direct solder batteries to any electronic devices?
BullFrog is offline
Old 11-10-2007, 09:38 AM
  #98
OleC's Avatar
@SlowerOne: That the press release does not cover the work beeing done to uncover what has happened, why and how to improve the safety in races, does not mean that nothing is beeing done...
Since no officials have said what the federation is doing to investigate, you automaticly presume that nothing is beeing done...
Well, since you havent told us wether you called your boss today and told him you quit your job, like I told you to do, I'll just presume you did.
So now you are officially unemployed. You know its true, you read it on the internet.
OleC is offline
Old 11-10-2007, 11:04 AM
  #99
Yoy have to use plugs, and it can not be a battery bar and the plug,
The heat are killing the cells, you can not solder direct any more on the cell
or the battery bar.
Alf
alf.skaar is offline
Old 11-10-2007, 12:58 PM
  #100
Jack Smash's Avatar
Trader Rating: 35 (100%+)
or the battery bar.
Alf
That makes no sense. My cells get way hotter from running than they ever have from soldering and de-soldering the wire to the battery bar
Jack Smash is offline
Old 11-10-2007, 01:02 PM
  #101
sosidge's Avatar
I believe EFRAs intention is to allow a rapid way of disconnecting the battery pack in an emergency.
It is a safety precaution rather than concern about heat from direct soldering onto a battery bar.
sosidge is offline
Old 11-10-2007, 01:41 PM
  #102
Shop Owner
nnick's Avatar
or the battery bar.
Alf
The reasoning behind not allowing direct soldering is exactly this
nnick is offline
Old 11-11-2007, 07:53 AM
  #103
Anders Myrberg's Avatar
Love this one!
Anders Myrberg is offline
Old 11-11-2007, 09:56 AM
  #104
Ole, that is the most pathetic post I have ever seen. I did not read the Norwegian Press Release on the Internet, so I assume it's true. It does not say that anything is happening. What's your conclusion?
I do not need to tell my boss I am fired, as I am my own boss. I make about $350k per year, live in my own house in 30 acres of land and drive a very expensive car. So, as you can see, I am not fired and I am not out of work. I'm guessing you have to work for someone else, who can fire you, which is so 20th century.
Which still doesn't explain what the Federation are doing apart from waiting for a list. I think if you have your own stereotypes of people who post on here, it would be better if you didn't tell everyone what they are, and then be shown up to be a pillock!
Old 11-11-2007, 11:36 AM
  #105
Suspended
You drive a very expensive car?
You are a god!!!!
