Old 11-07-2007, 09:13 PM   #1
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Questions?? Help with gearing for TC4 RTR
I got a TC4 RTR without a motor and I am wanting to put a Peak Performance Raven 15T Double Motor http://www2.towerhobbies.com/cgi-bin...2&I=LXJHH3&P=K Can someone recommend a size pinion to use with it?
Drift_Buggy is offline   Reply With Quote
Old 11-08-2007, 01:03 AM   #2
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
its always hard to recommend gearing to someone.... first of all will you be racing? bashing? etc etc. Also what spur gear will you be using?
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 12-01-2007, 03:42 PM   #3
Will be using the standard 72 tooth pinion. Wont be racing as there is no track in my town but probably just parking lot racers with my mates. I think it comes standard with a 17t motor running a 23t pinion but I bought it as chassis only
Old 12-01-2007, 06:44 PM   #4
Or is there a site that has info on gearing? What final drive ratio should I be after?
Old 12-01-2007, 08:51 PM   #5
If you really want some rip with your TC4 try a 66t 64 pitch and a 45 through 50t pinion.Tats what we used to run blacktop and carpet.And that will work great with a 27 or 19 turn.If you want mre run time try a 72t 48pitch with a 35 pinion.Hope this helps.
8up-racing is offline   Reply With Quote
Old 12-01-2007, 09:55 PM   #6
35t seems pretty big, the standard rtr comes with a 17t motor and a 23t pinion with the standard 72t spur
Old 12-01-2007, 09:57 PM   #7
Send a message via AIM to Carpetracer92
yep i use to run a 33 with my tc4 ft in carpet and it wasnt so hot.
Check out Long Island Low N Slow
Garage= Slammed g37,Full Exhaust
Carpetracer92 is offline   Reply With Quote
Old 12-01-2007, 10:03 PM   #8
Oh and I am just using 3200mah nimh, not lipo or anything big yet
Old 12-01-2007, 10:04 PM   #9
So when you get a faster motor you are mean't to run a higher pinion?
Old 12-01-2007, 10:14 PM   #10
In the manual it recommends a 30t pinion for a 19t spec and 27-28 for a 24-degree stock motor. Is the Peak 15x2t motor a stock motor?
Old 12-01-2007, 10:41 PM   #11
No the 35t is not very hot for racing,thats why I said if he wanted more "run time",not speed,if he is just bashing.
Old 12-01-2007, 10:47 PM   #12
also try gearchart.com
Old 12-02-2007, 07:55 PM   #13
ILDRVR's Avatar
I have been racing my TC4 in club races and I usually ran around a 21 pinion with a stock spur and a 27 turn trinity motor. I am putting a 13.5 SS Novak system in it, what should I consider when switching to a brushless? Should I consider changing my spur gear to a smaller size? What are the advantages?
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
ILDRVR is offline   Reply With Quote
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
