Old 06-09-2003, 09:49 PM   #46
Aurra Sing's Avatar
On the wheel hub, there is a small set screw that you can loosen with a 1.5mm size hex driver. Loosen it and it will uncramp the aluminum wheel hub so you can take it off.
Aurra Sing is offline   Reply With Quote
Old 06-10-2003, 03:12 AM   #47
John Doucakis's Avatar
In case you have the simple silver wheel hubs, that are without a set screw then do the following:
1. Take the black O ring or rubber ring,(call it as you want)
2. Push the pin out.
3. Try pulling the wheel hub. It should come off with ease.
John Doucakis is offline   Reply With Quote
Old 06-10-2003, 07:24 AM   #48
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
hey thanx
stupid me i forgot about taking out the pin.
on hte manual it looked like take out the pin after
Calvin Ng is offline   Reply With Quote
Old 06-13-2003, 09:55 AM   #49
evaa's Avatar
i.m racing my 414M tom. the track is carpet with a nice technical layout. we use sorex 20 tires. i changed the wheelbase, made it short, to give me better handling and less overteer. i'm using extra stiff springs with 80wt oil in front, blue stab bars using the wcr stab kit, in the rear i used medium springs with 40wt oil and no stab bars.
tested the car with the adjustments a made yday and the car was planted. most of the racers use traction compound, what i did was i tried the set-up without traction compound and was shocked to discover how planted the car was, no oversteer whatsoever.
by the way, shock mounting position i used was no. 3, front and rear, front and center one ways, no belt tensioner.
do u guys have any experience running on carpet? hope u can share set-up tips, i enumerated my set-up, hope u can comment on them, i want to improve by experimenting, a little help please. tanx
evaa is offline   Reply With Quote
Old 06-13-2003, 01:09 PM   #50
try using this
front;
40w shock oil
blue springs
standard wcr roll bar
5 hole on shock tower.
outer shock mounting on wishbones
rear
45w shock oil
blue springs
blue roll bar
5 hole on tower
outer shock mounting on wishbones.
dont us any kick up or anti squat [no spacer under ANY of the suspension pivot blocks].
this should be good.
trf racer is offline   Reply With Quote
Old 06-13-2003, 07:09 PM   #51
evaa's Avatar
Originally posted by trf racer
try using this
front;
40w shock oil
blue springs
rear
45w shock oil
blue springs
blue roll bar
5 hole on tower
i'll try running my set-up then l8r in the day, probably the second heat i'll try changing the set-up to what u recommended then i'll get back to u for the results, tnx
Old 06-14-2003, 03:19 AM   #52
the only thing is it may roll a bit in turns.if it does put white springs all round.because the set up is softer it should give more grip.also use standard wheelbase settings.front wheels fully back and back wheels fully back.
Old 06-16-2003, 12:44 AM   #53
evaa's Avatar
ola!
tanx 4 d set-up tips guys, well sad to say the race didnt push through, someone forgot the software for the lap countng system or something so what we did was we just ran our cars.
anyway, i tried my set-up and it seemed to work well, the only thing was i noticed that the ar had a tendency to push, but later i found out that instead of using the correct tires, i mistakenly ussed sorex 36s instead of the sorex 20s that everyone used.
i'll ru again this wednesday and this time i'll make sure that i use the correct tires, then i'll post the results again.
Old 06-16-2003, 02:34 AM   #54
try my setup above it will work good.
trf man is offline   Reply With Quote
Old 06-26-2003, 11:05 AM   #55
Default kINETIX
Originally posted by Aku-Man
Well, my 414 is not wcr, but its fully hop-up.
pic 1 front
I just saw in your pics that you have KINETIX BAT.
I just baught stage 3.
R U satisfied?
Old 06-26-2003, 12:10 PM   #56
Registered User
Calvin Ng's Avatar
whats this kinetix thing?
Old 06-26-2003, 01:41 PM   #57
Default kinetix
kinetix are batteries.
www.kinetixrc.com
Old 06-27-2003, 03:42 AM   #58
evaa,
Heres my setup for rubber tyres on a really high grip, and tight carpet track:
FRONT
white springs
50wt oil
blue roll bar, possibly stock 1.6mm wcr bar to smooth out steering
0 deg toe
1 deg camber
2nd hole from outer
2mm under front susp. block, 3mm under rear
one way
REAR
white/blue springs
45-50wt oil
blue roll bar
2.5 deg toe
1 deg camber
center hole
3mm under front susp. block, 2mm under rear
stock front wheelbase setting, 2mm shorter on rear
center one way
CS27
LRP blue factor(addative) full coat
...and im almost unbeatable using this setup
TRF414WCR is offline   Reply With Quote
TRF 414m2 cheehtae R/C Items: For Sale/Trade 0 02-24-2007 12:41 PM
Trf 414m2 merc-blue R/C Items: Wanted to Buy 3 02-08-2005 10:21 PM
TB Evo III and 414M2 Jack R/C Items: For Sale/Trade 13 12-02-2004 05:00 AM
414m2 Dougnuts55 R/C Items: For Sale/Trade 6 09-06-2004 07:24 PM
414m2 Dougnuts55 Electric On-Road 2 09-03-2004 05:39 PM
