Old 12-20-2007, 07:33 AM   #31
burito's Avatar
As MrC (this is Andy, he works at LRP as well) explained in this thread already above:
The Sphere Competition 2007 Edition does have 8 power profiles in BRUSHLESS mode while it has only 6 power profiles in BRUSHED mode. Same goes for the TC-Spec.
The former version (2006 Edition of Spehere Competition) does have 6 power profiles for brushless and brushed.
So, if you have no brushless motor connected to the speedo, it will only show you 6 power profiles since it switched to brushed mode automatically.
I'm quite sure this is the "mistake" you did, sorry if it is not explained well enough in the manual.
Reto Koenig
burito is offline   Reply With Quote
Old 12-20-2007, 07:38 AM   #32
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
it only has six while hooked up to the motor, blinks six times, hit it again and it starts over
loopedout is offline   Reply With Quote
Old 12-20-2007, 09:20 AM   #33
burito's Avatar
I assume you have the power wires and the sensor wires hooked up when you connected it, right?
If that's the case and it only has 6 power profiles, indicates "2007 Edition" on the packaging and you bought it with an intact factory seal, then I'd have to apologise because there would have happened a mistake on our end and you did not get a "2007 Edition".
I'd suggest you speak to your LHS first (or wherever you bought it) about it.
Reto Koenig
Old 12-20-2007, 01:11 PM   #34
I have a question, after all this discussion has anyone actually done a real back to back test of the 2006 versus 2007? If so will you share the results please.
And, what are the exact dimensions of the caps, 06 versus 07.
It appears some people have six and some have seven mods and they all think they have 07's. Can a LRP rep tell us a little more than see you LHS please.
Ted Flack is offline   Reply With Quote
Old 12-20-2007, 02:07 PM   #35
burito's Avatar
@Ted: what else do you need to know? I think I explained what modes are normal and what are not, if I have not done that in a good way then please let me know your specific question.
I have not heard of any other 2007 Edition speedos with this "6 power profiles in brushless instead of 8" apart from the one loopedout mentions here so this is definitely not something common.
2006 has a small external cap (don't have the dimensions to hand here at home) but it's about 1/3 of the size of the one from the 2007 Edition, so it can be easily recognised.
Reto Koenig
Old 12-20-2007, 02:46 PM   #36
Thanks for responding, I thought I had a 2007, it has the big cap, the box came with the yellow page of instructions, and a white page, but it only has six profiles...hence my question. The instructions only have six profiles as well. So what is it? I know it is not a TC, it doesn't have a fan.
It works fine but I am wondering how much if any performance I am giving up, I run 10.5 and 13.5.
Old 12-20-2007, 03:18 PM   #37
Send a message via ICQ to Jan Larsen
If you're only running 10.5 max, then you aint missing a thing. The TC has slightly less resistance and slightly more profiles, but that dosen't warrant buying it if you already have a Sphere. You simply wont notice the difference.
I run the Pro Sport for brushed 19T, simply because it's the lightest LRP speedo made for 1:10 competition racing. Gotta be careful with weight here...1350 weight limit (or 1400 by 2008)
Jan Larsen is offline   Reply With Quote
Old 12-20-2007, 04:41 PM   #38
yeah sensor wire hooked up on a novak 8.5 (already have my order in on the LRP 8.5, patiently waiting) and yeah has the 2007 sticker on the box, my LHS just ordered it for me. ok, looked in the box, there is the yellow paper, but I just double checked and only has six profiles. ah well just wondering, still fast
Old 12-20-2007, 10:29 PM   #39
darnold's Avatar
Doesn't the standard Sphere simply say "Sphere, Brushless + Brush" and the 07' Sphere say "Sphere Competition" on the ESC?
Team Top Racing USA,Team MaClan ESC, Pro One Tires, Hot Race Tires
darnold is offline   Reply With Quote
Old 12-20-2007, 11:25 PM   #40
yeah I think so, but the 07 is just on the box, comp has thicker wires and a cap, if they have a heatsink on its hard to tell sometimes
LRP Sphere Competition Question JSJ Racing Radio and Electronics 2 05-09-2008 03:39 PM
Different Between LRP sphere and the LRP sphere TC SPEC [email protected] Electric On-Road 3 09-29-2007 04:09 PM
Sphere Comp and Sphere TC Differences Paul_67 Electric On-Road 4 08-20-2007 03:27 PM
LRP SPHERE OFFROAD QUESTION mach51 Electric Off-Road 16 09-25-2006 08:15 PM
sphere/gtb question PAPAMAC Electric Off-Road 4 07-16-2006 11:32 PM
