Old 11-01-2007, 02:48 AM   #1
Default Batts runtime
Do u guys have any idea, what is the runtime for these batts:
1800 mah Nicd
2400 mah Nimh
3000 mah Nimh
3800 mah Nimh
Ive topcad 1700mah nicd that last 20mins and IB3300mah, last ard 30mins, run continuously. Both are 2nd hand and boths run with TT01.
Gonna get a new batts.
Many thanks in advance.
~PeaceNoWar~
intrance is offline   Reply With Quote
Old 11-01-2007, 09:02 AM   #2
Joel Lagace's Avatar
Well if your buying new batts anyway skip anything below a 3800.
If your getting 20-30minutes with those 2 packs you own now i can only assume your running a silver can 540 motor? OR your geared really low. Eitherway your not having run time issues.
So expect the same run time and more with more power running 3800,4200+++ Look for something in your price range in a nihm pack betweem 3800 and up. Look for cells by GP(goldpeak)-very reliable, IB(intelect)-powerfull but delicate, EP(EAST POWER)-powerfull,reliable.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-01-2007, 06:31 PM   #3
hi Joe..
many thanks for ur reply..
how true u are.. yup im using stock motor and stock gear.
so if im using sport tuned motor for example.. does that mean my batts runtime will become shorter?
Will have look around with ur recommended batts.
TIA
~PeaceNoWar~
Old 11-01-2007, 06:38 PM   #4
YEs a hotter motor with less turns will run more power and lower run times. It just depends on how fast u want to go. I can tell your a tamiya guy but skip the tamiya brand motors they are expecive for what you get. A nice tuned 27turn motor such as the CO27 will give you plenty more speed without using much more run time or stressing your stock ESC
www.rcottawa.com
runtime? aus jd 2703 Electric On-Road 4 02-26-2008 05:24 PM
Best Fuel for Runtime???????? dsl Nitro Off-Road 13 10-27-2007 11:58 AM
Runtime... surrealmaterial Electric On-Road 5 10-12-2006 08:29 PM
Fusion 1.185 415 runtime Joe B R/C Items: For Sale/Trade 9 08-24-2005 02:05 PM
Runtime with 6T mod Tbevofreak Electric On-Road 13 05-18-2005 10:48 PM
