Old 10-31-2007, 04:49 AM   #1
Default Understanding tire size for touring car
I am looking to purchase foam tires for my Tc4. GRP makes 26mm, 28mm and 30mm tires. What is the norm size wise? I am not sure which ones to get. Thanks
Ginsu is offline   Reply With Quote
Old 10-31-2007, 05:57 AM   #2
Trader Rating: 16 (94%+)
I'm not too familiar with GRP Tires, but first you need to be sure you're not buying Nitro Foam's. These typically come in 26mm Front and 30mm Rear, and are listed by Shore Rating. A Higher Shore Rating = Harder Tire.
Indoor Carpet Foam tires are usually 26mm and 28mm and are listed by color for Foam Softness/Hardness. All brands are somewhat different, but a general rule of thumb is, darker color = harder foam. The most common are Pink and Magenta compounds.
Before you drop money on tires, check with the other local racers at your track and find out what brand and compounds they are running. When you go outside of the norm on tires, you could easily end up wasting your money.
kn7671 is offline   Reply With Quote
Old 10-31-2007, 06:15 AM   #3
scootr117's Avatar
Also check if there is a truer at the track you can use....Out of the box tires are normally are cut down in diameter to reduce "chuncking" and side wall flex....I ran them at 2.2" for touring car
I was told one time GRP and Parma use the same foam so the colors should match between the two...
scootr117 is offline   Reply With Quote
Old 10-31-2007, 10:09 AM   #4
swopemike's Avatar
I believe (don't have box in front of me) that Parma Pro 53 say on the box "made by GRP for Parma." If not correct, somebody with a box can post the correct wording.
swopemike is offline   Reply With Quote
Old 12-03-2012, 07:24 AM   #5
Default Change in size
Hi,
Next year legal mesuraments (EFRA) of Touring Electric cars has changed to 28mm wide, does anyone knows any brand that have 28mm wide rubber tires?
duartev is offline   Reply With Quote
Old 12-03-2012, 11:22 AM   #6
KC10Chief's Avatar
Gotta check with the club, dude. In my club, we run indoors on carpet, but we use the 26mm nitro tires all the way around the car. Usually 32 shore in the rear and 37 to 40 shore up front.
EDIT: Just realized that this zombie thread is 5 years old.
KC10Chief is offline   Reply With Quote
Old 12-04-2012, 05:02 AM   #7
hei, its old, but is there anyone else that does know 28mm wide rubber tires?
as the rules changed I think many tire manufacter will change!!
tire and rim size not fitting desertbird Nitro Off-Road 11 05-22-2008 08:57 AM
belt size rc touring cars ??? PizzaDude Electric On-Road 5 11-27-2006 03:44 PM
What size wheel for touring car Ginsu Electric On-Road 6 11-18-2005 07:34 PM
Foam tire size? mtc3od Electric On-Road 7 10-21-2004 07:15 PM
1/10th Touring Car Wheel Size??? doublest Electric On-Road 1 04-22-2003 02:25 PM
