Old 11-23-2007, 12:40 PM   #16
radio_car_racer's Avatar
Originally Posted by HappyHippo View Post
More pics on www.rc50.com
This looks good
so do these
pic 1
pic 2
pics from rc50
radio_car_racer is offline   Reply With Quote
Old 11-23-2007, 06:11 PM   #17
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
There are a lot of features that you cant really see on here that are dialed. For instance look at the center shock. It is actually a threaded shaft so you can adjust shock length without taking the shock off. Just use a turnbuckle wrench.
EA
EAMotorsports is offline   Reply With Quote
Old 11-23-2007, 09:59 PM   #18
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
I have tried the one dampener tube on my car and got chewed out for it too. How funny now.
CarlosG. is offline   Reply With Quote
Old 11-24-2007, 02:18 AM   #19
I like the new front end...should take care of the uneven arms issue, be more accurate in adjusting ride height, and be universal left to right with the lower arm.
Old 11-25-2007, 08:54 PM   #20
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
http://www.rc50.com/modules.php?name...lbum=46&page=9
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 11-26-2007, 11:25 PM   #21
nashrcracer's Avatar
R/C Tech Charter Subscriber
you should of seen the other prototype that I wasn't allowed to take pictures of. I have to thank Bob for allowing me to take pictures of that one. let's just say the "other" car was a serious departure in normal associated design. bob has some great ideas. lets hope thunder tiger lets him build it. I didn't get any particulars on release. it could be 6 months from now or next month. but bob did say the front end was designed to be either sided. so you don't have all onesided arms from breaking them in the sweeper. and the tplate was y shaped so you could move the motor futher foward in the pod to put a bigger pinion on and not hit on the center screw. it did do very well in stock with cochren putting it 5th in stock "A" you can't go by bob's finish as he had the "other" car. still some very forward thinking from associated.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 12-01-2007, 08:31 PM   #22
RacinJ's Avatar
Just wanted to know if anyone had more info on the Associated prototypes?
RacinJ is offline   Reply With Quote
Old 12-24-2007, 08:40 PM   #23
rosko's Avatar
anyone know release date rumors or definite dates on availability of the car
rosko is offline   Reply With Quote
Old 12-24-2007, 09:10 PM   #24
trailranger's Avatar
I like the center damper idea, if the piston is centered it should have the same dampening either way. The offset springcups really help, they may find there way into 1:10 oval racing since most Micro VCS shocks have the springs really bound up. The Bottom end of the shock where you normally just screw in a ball cup looks excessive. I just use Durbo heavy links to gain extra freedom of movement and quick removal of the shock. The adjustable shock tower is good too. No more using spacers like on my CRC 3.2, but that is an off the self item for oval racers, no R&D needed there.
The frontend looks changed I wonder how that compares with the new CRC front end or the switch to IRS lower arms.
To be honest, I am already looking to buying a DB12R but I may just hold off and buy the upper pod plate and convert my MX2 to having one dampener tube/shock.
trailranger is offline   Reply With Quote
Old 01-27-2008, 12:24 PM   #25
tpczx6's Avatar
And Carlos you where more then 5 laps off the pace and wanting to know why your car does not work. No one chewed you out you just do not want to beleave that your car was not working.
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 01-27-2008, 06:38 PM   #26
CarlosG.'s Avatar
Funny thing was the car was fine the night we ran the club race. That is the way I ran it that night with one damper tube. I did end up third that night with an "ill handling car", also with my servo flat on the chassis till the main event when I had to change the servo out cause it got knocked loose.
Old 01-27-2008, 07:03 PM   #27
Ike
Ike's Avatar
Just an FYI, the very first car with a damper tube (Trinity Revolver 12) only had one as well.
Ike is offline   Reply With Quote
Old 01-29-2008, 10:29 PM   #28
deleted pics, they were too big
here is the links
http://www.rc50.com/modules/coppermi...8/PICT6455.JPG
http://www.rc50.com/modules/coppermi...8/PICT6458.JPG
Old 01-29-2008, 10:34 PM   #29
Looking at the hardware, I belive this may be the 12L5 (RC12R, Dropping the "L ")
Check out those links!!!! massive and better than the ballcup links.
Ball cup links get loose after a while.
I see a alot of new stuff and the plastic stuff is molded. Given that the parts are molded not milled, I would say the production has already started.
Old 01-30-2008, 01:59 PM   #30
thans Nash for the pics!
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
Pictures of Team Associated RC12L5 Prototype kv!n Electric On-Road 2 11-23-2007 06:00 PM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
